Question about Brother FAX-8360P Plain Paper Laser
My Brother 8360P is stuck in sleep mode, and will not TX or RX faxes. I have reset the Sleep mode hold to 99 minutes, so that it comes online, but still no activity. Any ideas?
3 Suggested Answers
  • 320 Answers
SOURCE: our fax doesnt want to recieve it sais sleep mode
have you tried to turn it of then on to reboot the fax machine! if that will not work you may have a bad main board
Posted on Jan 16, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: brother 8360p has faxes in memory but will not
I have seen a few Brother faxes do this. I fixed them by turning off the power, holding down the clear/stop button and keep holding it down while you turn the power back on. Keep holding it for a few seconds then release. This will clear what ever is in the memory that is locking up the memory print. Note: you will lose any received faxes in memory by using this procedure.
This may help you restore your fax to a operation condition.
Good Luck and Thank You for using Fixya.
Posted on Aug 19, 2010
How to take off sleep mode
Sleep Mode
Setting the Sleep Mode reduces power consumption while the machine is idle.
You can choose how long the machine is idle (from 00 to 99 minutes) before it
drops into sleep mode. The timer automatically resets itself after the machine
receives a fax or PC data, or makes a copy. The default setting is 5 minutes.
1 Press Menu, 1, 8.
2 Use the Dial pad to enter the length of
time the machine is idle before it drops
into sleep mode (00 to 99 minutes), and then press Set.
3 Press Stop/Exit.
Oct 10, 2011 | Brother Office Equipment & Supplies
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
The fax continually registers as being in "sleep" mode. Says it's in "Sleep" mode all day even when it is receiving and or sending out. How do I correct that?
You can choose how long the machine is idle (from 00 to 99 minutes) before it drops into sleep mode.
1 Press Menu, 1, 8.
3 Press Stop/Exit.
Jun 15, 2010 | Brother IntelliFax-4100e Fax
We have a Brother Intellifax 4100e, business class laserfax, superg3 fax machine in our office. When the fax machine goes into sleep mode, we can't get it to come out of sleep mode unless we unplug it and...
Try changing the sleep mode settings. Sometimes it's set too long or too short. You can try the perimeter reset as well. The instructions I have for that is as follows:
hit the menu button and numbers *2864 (star before the four numbers)
then hit 91(set) wait a few seconds for the maintenance screen to return
then hit 99(set) when it beeps saying completed that could fix your problem.
Hope this helps.
Jan 29, 2010 | Brother IntelliFax-4100e Fax
How to stop sleep mode?
Sleep Mode
You can choose how long the FAX/MFC is idle (from 00 to 99 minutes) before
it drops into sleep mode. The timer automatically resets itself after the machine
receives a fax or PC data or makes a copy. The default setting is 0 minutes.
1 Press Menu/Set, 1, 7.
time the machine is idle before it drops into sleep mode (00 to 99 minutes),
and then press Menu/Set.
3 Press Stop/Exit.
Dec 01, 2009 | Brother IntelliFAX 2800 Laser Fax
My fax machine sends faxes, prints, and received faxes but the faxes are blank. We have been trying to figure out the problem and while fiddling with the machine have actually received a successful fax???...
Probably not. You can change that setting in the user modes in menu/function and set it to 99 minutes. HAve you tried another drum unit? Your charge corona wire in the drum unit maybe broken!
Aug 28, 2009 | Brother IntelliFAX 4100 Laser Fax
UNABLE TO REMOVE SLEEP MODE
you can't take it off of sleep mode. the only thing you can do is set it to go into sleep mode anywhere between 0 to 99 minutes. you do that by pressing "menu, 1, and 8." there, you can input how long you want sleep mode. no way of completely disabling. i'm thinking that somehow, it must have gotten set to 0 minutes.
hth,
razors
Mar 30, 2009 | Brother IntelliFAX 4100 Laser Fax
Our fax doesnt want to recieve it sais sleep mode
Jan 10, 2009 | Brother IntelliFAX 2800 Laser Fax
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Sleep
You should be able to send and recieve faxs in the sleep mode. You need to reset the machine, pull out the plug, hold down the menue key while you plug the machine in. When maintanence comes up in the display enter 01 and wait. Whwn maintanence comes up again press 99. DO NOT PRESS ANY OTHER NUMBERS OR YOU WILL DAMAGE THE MACHINE BEYOND REPAIR. Your fax is now reset and completley empty, you will have to put in your name etc and sleep mode will be set to "0" minutes
May 15, 2007 | Brother IntelliFAX 5750e Laser Fax
Brother FAX-8360P Plain Paper Laser Logo
738 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
