Question about Whirlpool LER4634J Electric Dryer
Dryer heats, interior light goes on, hit the start button, and nothing. Checked the belt, and it is intact. What next?
  • 347 Answers
Unplug unit remove back of unit and check continuity of thr thermal fuse mounted on housing about 1 inch long ,white and hase 2 blue wires going to it .if no continuity replace.
Posted on Aug 06, 2010
My dryer wont stay on if I push the start button it turns on and heats up but once I let go of the button it sits of rite away.
what's the brand name and model number,if it's a kenmore or whirlpool and says even heat with the lint filter inside most likely a bad even heat computer board or the motor relay both are up in the top console,if it's a g.e. you have a broken belt switch,there's a switch down next to the motor and belt pulley,it's just a cherry switch,it has a button that sticks out of the switch that hits the belt pulley,if the belt breaks then the dryer will only run when the start button is pushed in but the switch can break causing the same problem,also on the newer whirlpool it also can be a broken belt,good luck with your dryer
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
Nov 10, 2013 | Dryers
I have a front loader fridgidaire dryer its a couple yrs old today when i put clothes in it to dry i usually hit the start button and then hit the start button again to start it but today I did it just...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 23, 2011 | Frigidaire Electric Dryer
Dryer will not start but light comes on, heats drum okay. The dryer heats, the light goes off when the door closes, checked the drum and the belt is okay. When the start button is pushed nothing happens.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Apr 30, 2010 | KitchenAid KEYS750LQ Electric Dryer
When you hit the power button it does not cut on i checked the breaker and when you open the door the light comes on
had this same problem... to fix it .. was easy enough... first the drum belt was broken which the pully flips and switch in the base.. so make sure belt is ok .. next i had a corroded wire on the heating element .. i had to fix that connection... once i fixed these two items .. the controls work fine agian and the dryer worked fine ...
P.s. the expert help here that i paid for .. was a complete waste of cash.
Mar 12, 2010 | GE Profile Harmony DPGT750EC Electric...
Kenmore dryer electric doesnt start
It sounds like the dryer drum belt is broken
there is a drive belt that goes all the way around the dryer drum and when you press start the drum starts turning unless teh belt is off or broken
You can change the belt or call and have service technician change it
Jan 04, 2009 | Maytag HYE3657A Electric Dryer
My Maytag dryer won't start when I hit the start button
It sounds like that you have found the problem yourself. Remove the power cord and replace the terminal ends, or replace the entire cord.
Dec 28, 2008 | Dryers
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
My dryer light comes on for my Maytag SDE4606AYW dryer when you open the door and I can hear the timer clicking but when I hit start the motor doesn't even attempt to start but there is obviously power. My dad just installed a new power cord to the dryer but this is a seperate issue as we were obviously unable to check the motor before we got a cord for it. He has years of electrical experience so I'm assuming he connected the new cord right. Any ideas on fuses in the dryer or why it may not be getting power?
Jan 15, 2008 | Maytag PYE2300AY Electric Dryer
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
