Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
I have a Lawn-Boy model: 10682 Tecumseh engine model : LV148EA/LV195EA Engine will not start. Don't think it's getting fire to the plug. It has a safety switch where the bag attaches. It seems to be ok. Shear pin looks good on flywheel. Air filter new. Gas is new. Primer bulb is good and puts gas on the spark plug. Tried starter fluid and still won't fire. Any suggestions?
4 Suggested Answers
  • 885 Answers
SOURCE: can you run your lawn boy mowers without the
Yes you can. The only reason small engines have the primer button/bulb is to get gas to the carburator to make it easier to start it. If your mower starts OK without using the primer bulb you will not harm the mower.
Posted on Apr 14, 2011
GodBlessU
  • 3513 Answers
SOURCE: i changed oil, blade, spark
Hi
Make sure the blade and shaft can easily be moved by hand. First, remove the spark plug wire from the plug. Reach under the mower and see if the blade will turn or if something is stuck between the blade and the mower. Also remember that you have to hold the safety bar when you are starting the mower or the engine won't turn. It is possible that the cable from the safety bar to the engine brake has come loose. Follow the cable from the safety bar to the engine and make sure it is working.Also check whether the line from the gas tank to the engine is crimped?
Also check this link to troubleshoot your problem:-
http://www.ehow.com/how_7363405_troubleshooting-push-mowers.html
Posted on Aug 04, 2011
  • 316 Answers
SOURCE: Am looking for a tecumseh ULT50 manual
hello, since you checked all of that there ,what is the compression,should not be below 60 lbs any thing lower and will not run,check for a bad head gasket and proper compression should be between 60 to 130 lbs,hope this helps,
Posted on Feb 20, 2012
I have lawn boy mower Model 10682. Everythng works very well on it, except occasionally the engine will reeve up to a very high rate. Only happens when not cutting.
Sounds like you may have a air leak on your intake manifold. Check all the manifold to carb bolts and manifold to cylinder bolts.
Oct 12, 2016 | Garden
How do I change the belt on a bolens 3.5 25 cc model lv148ea
The LV148EA is the model number of the Tecumseh engine.
Please look again for a Bolens model number.
Sep 21, 2016 | Garden
How to test a Lawn Boy ignition coil
you will need a spark test about 10 to 15 dollars hook the tester to it on the plug try to start it watch to see if it sparks the other way is to do without spark tester is to pull the plug out and lay it on engine block try to start it and watch to see if plug sparks
Aug 07, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Have Lawnboy Kohler 149cc smart choke 6.5ft lbs engine bought last year won't start doesn't seem to be firing?
REMOVE THE SPARK PLUG, RECONNECT THE CABLE AND WHILE THE SPARK PLUG IS RESTING ON THE BLOC OPERATE THE STARTING PROCEDURE AND SEE IF THE PLUG IS SPARKING.
May 09, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
After about 15 to 30 minutes, engine starts pinging (for a few seconds) then dies
Not familiar with tecumseh lawn boy. Lawn boys I worked on were 2 stroke, if this is the case the crank seal is sucking air after engine warms up. New seal would fix. If you can't do it you're self may not be economically worth it.
Sep 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn Boy mower will not start. New gas and plug.
Is the plug getting wet? if not, try introducing fuel to the intake and attempt to start it again, the interlock on the handle works by killing the ignition fire and applying a brake to the flywheel, this should be a Tecumseh engine, carb troubles are quite prevalent on these, by substituting fuel to the intake you are acting as the fuel supply, if it starts and runs briefly you have confirmed a fuel system issue
Jun 01, 2010 | Garden
Engine will not start, no spark
Try taking of the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs that are really close to the fly wheel. Use fine sand paper or emery cloth. Then check the spark plug wire for rust (clean if any). Try replacing the spark plug if it is old.
Let me know if this helps.
roundo4
Aug 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
977 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
