Question about Frigidaire Ovens
Frigidaire electri clean selfcleaning feature
We have bought a condo with an older oven that has the selfcleaning...but cannot find any buttons or levers to lock the catch for that feature. The knobs all turn appropriately but no lock. Help?
It locks automatically. You can download the manual from Frigidaire here (as I just discovered while trying to figure out how to use the self-cleaning feature :) ): http://www.frigidaire.com/support/manuals.asp?NewSearch=New+Search
You don't need to type in the whole model number. For example, if the model number (found in the upper left when you open the oven door) is RSE37BAW*4, you only need to enter RSE37BA.
Posted on Aug 23, 2008
Oven on lock. How do you unlock
most likely the door locked due to an overheat situation. It's a safety feature on most ovens made today. It may be caused by a fan motor not running properly thus allowing area above oven cavity to sense extreme temperature, blockage in air flow pattern, or a bad temperature control.
Whatever the cause, it's best to have a tech take care of this issue for you to prevent danger to you and your family.
Jan 29, 2015 | Kenmore Elite Stainless Steel 40" Dual...
Oven door won't close
if you look around under the handle or under the top of the stove on the front there should be thin lever. This lever is designed to lock the oven door closed tightly when you are activating the self cleaning oven feature. It is likely that someone accidentally lock the lever while the door to the oven was open. Simply find that locking lever return it to the unlocked position and your door should shut fine.
Dec 26, 2013 | Ovens
Used the selfcleaning feature. now it won't stop beeping and the oven door is locked. we have tried to unplug the oven, still nothing has changed. there is an error displayed. Please help!
HI- Sorry-No good news here. Techs call this feature 'Self-Destruct'. On site diagnosis is required to determine what components are affected. Best case is a burned out door switch, worst case is a burned out control. Find a good tech to check it out. And avoid the self clean 'feature' unless you have an extended warranty. Too many people believe the salesman when he says; "Clean? Just touch this button!"  Let me know if this explains what has happened, and if you need more info, just ask. Thanks-- Ed
Mar 18, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Can not activate the self cleaning cycle
Before you try to use the self cleaning feature please read this tip....
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
You out to see all of the problems that come here everyday because of the selfcleaning feature on ovens....
Heatman101
Mar 08, 2010 | Viking Ovens
How do I get self clean to work on older fridgidare stove
Move the safety lock/lever at the top of the oven door to the right and press the self clean button on the oven control panel, it is an automatic cycle so it will lock the door from opening and then will proceed with the auto clean cycle. Good luck !
Jan 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The door lock will not release after a selfcleaning cycle. the cancel button has been pushed.
the motor may be jammed.try to unplug the unit for a few minutes and plugit back in if this does not work you may need to replaced the main control board
Sep 17, 2009 | Ovens
Try to use selfcleaning feature on range and as soon as door locks it stops and goes to F9
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%
Jul 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchenaid superba oven stovetop oven door will not open after se
When the oven goes into clean mode the door is automatically locked as a safety feature. I would put it back into clean mode again, let it clean for a while and then hopefully when it cools down the door will open. good luck .
Mar 20, 2009 | Ovens
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
1,536 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
