Question about Samsung ML1740 Laser Printer
When I do an install it says that the printer is not connected or the power is not on. Both are on and attached, If I do the install with out being attached when I go to print I get an error message,
  • 146 Answers
Check your usb connections or try another usb port.
Posted on Aug 06, 2010
I have a lexmark x63 and everytime i try to print something it says the device is busy try again later. i click on the printing icon that pops up in the bottom right hand corner of my screen and there is...
hi Cavschick104.
this is all i could find out.
COMPLETELY uninstall the printer and
reinstall it..... It may have occurred if you have your printer connected
during the installation of XP.... it is normal practice to keep the printer
disconnected during an upgrade or clean install.... and then correctly
install it afterwards.
This from the Lexmark site:
Remove the USB cord and the power cord from the back of the printer, and then remove
the USB cord from the back of the computer.
Uninstall the printer/scanner software from the Program menu and restart the system.
Check the part number on the setup CD. If it is not P/N 13H0350, you need to download
the XP driver from the Lexmark web site, www.lexmark.com.
When the PC has restarted, log in as an administrator and insert the setup CD into
the CD-ROM drive
Click OK and Install now.
Follow the setup instructions to install the scanner software. When you see Connect
the USB Cable to the printer on the screen, first attach the power cord to the
printer, then attach the USB cord to the printer, and finally attach the USB cord to
the computer.
Follow the setup instructions on the screen to complete the printer software
installation.
If you want technical support of Lexmark, you can contact us on Lexmark Printer Support 1-866-877-0191. We are always available with technical experts for your help. For more information, click https://goo.gl/bpBgcR
Lexmark Printer 1 866 877 0191 Help Support Service...
Nov 27, 2017 | Lexmark X63 InkJet Printer
Connect x2580 Lexmark printer to toshiba laptop
Hello chuck01438 ,
  1. Remove the printer out of the box and connect the power cable to a power adapter.
  2. Install the drivers and necessary software. Enclosed with the printer package should be a driver CD-ROM for the printer. It might also contain some print enhancement software supplied by the manufacturer of the printer. Follow the instructions for software installation.
  3. Connect the square end of the USB cable to the printer and the rectangular end to your laptop.
  4. Turn the printer ON. Your laptop should find the newly attached hardware, and recognize it as printer.
  5. Open any document or picture and click on Print in File menu or click on a printer icon in the toolbar.
Mar 26, 2008 | Computers & Internet
How can i install my mp 780
Here are few steps on "HOW TO INSTALL THE PRINTER" mp780
1. connect the Power Cord.
- Connect the one end of the power cord at the rear end of the pronter.
- Connect the other end to the AC outlet.
2. Use the << / >> button on the printer to select the machine languange will be use.
3. If the printer display prompted you to "Install Cartridge". This means that the printer has no cartridge installed and you may need to do it manually. Go to Steps 4-A for the guidance.
4A. Press the Open Button to open the Paper Output Tray of the Printer. Then lift the Scanning unit unitl it locks into place.
5. Open the two inner cover inside the printer.
- The Printer head Holder will move into the center.
6. Raise the lock lever.
7. Remove the protective cap on the in k cartridge .
8. Insert the Cartridge into the holder.
You must have the installer CD available with you.
Let me hear from you again for further asssitance.
Apr 06, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Printer is connected but does not print
Hi
Thanks for using FixYa. Please check the following things first---
· The printer cover is closed and the rear access door or optional duplexer is attached.
· The printer is connected to the power source and turned on.
· The cable connections are secure and the cartridges are correctly installed.
· The paper or other media is correctly loaded in the in tray.
Now check the printer cable connection: If the printer cable is attached to a USB hub, a printing conflict might exist. Use one of the following methods to resolve the conflict:
· Attach the printer USB cable directly to your computer.
· When printing, do not use other USB devices that are attached to the hub.
Now verify if the printer is connected to the correct USB port: If the computer is configured to use both the back and front USB ports on the printer, then you might be printing to the wrong port. The computer has two versions of the printer driver: one for the front USB port and one for the back USB port. If you are connected to the back USB port, but select the printer driver that is associated with the front USB port, the printer will not print. In the application that you are printing from, click File and then click Print. The Print dialog box opens. The Print dialog box displays two versions of the printer driver. Select the version that is associated with the port to which you are printing. The issue will be resolved.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 12, 2009 | HP DeskJet 6540 InkJet Printer
Dell laptop shuts off
Try reinstalling the printer and any drivers or programs that are related to the printer.
Dec 22, 2008 | ASUS A8Js Notebook
Printer 6540
First of all u need to assemble the printer and need to ensure that the printer has a steady green light on Power..
If any light blinks it means there is some problem with the printer..
To connect the printer with your Laptop u need an USB cable which has a rectangular connector at one end wich will be connected to the Laptop's USB Slot and the other end of that cable will have almost square connector wich will be connected to the printer...
Before connecting the printer U need to install the Software on the Laptop and connect the printer when system prompts..
remember the printer should be powered on while connecting to the system..
Nov 01, 2008 | HP DeskJet 6540 InkJet Printer
Need help to hook up IBM color flatbed scanner
Attach one end of a parallel port cable to the parallel (printer) port on your computer and the other end of the cable to the computer port on the rear of the scanner. If you have a printer connected to your computer, you must disconnect the printer cable from the computer before connecting the scanner cable.
If you have trouble attaching a cable connector to a port, be sure that you are connecting the correct end of the cable to the correct port.
IF. . . you want to use a printer WITH your scanner, attach one end of the printer cable to the printer port on the rear of the scanner and attach the other end of the cable to the printer.
Plug in power cord and then power up PC.
Power on scanner. Install drivers. Restart PC to activate EZ Station buttons.
Oct 11, 2008 | IBM Color Scanner Flatbed Scanner
USB installation problem
This problem comes somtime when you connect the printer prior to dirver installation.
  1. Rmove your printer driver from Start-> Printers and Faxes
  2. Right click on printer icon select Delete
  3. Re-boot system, before re-boot remove all USB connections.
  4. Start Installation from Setup CD
  5. Don't attach printer to system till Installation finished or Setup says to connect the printer.
Thanks
Iqbal
Apr 15, 2008 | Lexmark X2550 All-In-One Printer
Installation for canon pixma ip 1500
Hey you again, you rated me yesterday Inappropriate. Actually, fixya expert afraid to give some solution because you will rated us Inappropriate even the problem is came from you where you was not clearly stated your problem.
Ok, but anyway I am still to help you, Is it the problem goes to the manual installation you need or the driver instead?
Printers used to be the bugbear of computer users. They were difficult to set up and ornery in operation. That's no longer the case and it's likely you'll have no problems getting your printer up and running. This is particularly the case if your printer comes packaged with your computer system or if you stick to well-known brands such as Hewlett-Packard, Epson, Lexmark and Canon.
Connecting a printer involves four steps:
  1. Unpacking your printer, removing any packaging material and installing the ink or toner cartridge. Refer to your printer's instructions to guide you.
  2. Connecting the printer cable to the printer and to the back of your computer.
  3. Connecting the printer's power cord to a power outlet.
  4. Installing the printer driver and any additional software. The printer driver is a piece of software that tells your computer how to interact with your printer.
If your printer comes as part of your system, you may find that its driver is already installed. In that case, all you'll need to do is unpack it, connect the printer cable and power cord and switch on your computer.
geekgirl.tip: Get a cable One word of warning: Make sure you purchase a printer cable! Often, this is not included in your computer system, despite it being an essential item. You'll need the correct type of cable for your printer: If it's a USB-enabled printer, you need a USB cable (note, the new USB 2 cables work with older USB 1 printers, too; so if in doubt, get a USB 2 cable); if it's a parallel printer, you'll need a parallel cable.
Make sure you get a cable long enough to reach easily from your printer to your computer. However, you should avoid cables longer than 10', because long cables can cause problems with communication between printer and computer. Try to position your printer so a 6' (or shorter) cable can make the connection.
Follow the wizard If your printer's software has not been pre-installed, read any installation instructions that accompany your printer and follow those instructions. If no instructions are provided, follow this procedure:
(Note: This procedure applies to printers which use a parallel connection. If your printer uses a USB connection, you should connect it while Windows is running and it will be recognised.)
  1. Make sure you have your original Windows CD-ROM handy. You may need it.
  2. Switch the computer off.
  3. Connect the parallel printer cable to your computer.
  4. Connect the printer's power cord to a power outlet.
  5. Switch on the printer and the computer.
  6. In most cases, Windows will detect that you've attached a new hardware device and it will launch the Add Hardware Wizard and attempt to search for the appropriate software. If the wizard doesn't launch and Windows appears to ignore your printer, you can launch the Add Printer wizard yourself by clicking the Start button, selecting Control Panel, clicking Printers And Other Hardware, and then clicking Add Printer.
  7. If the printer is directly connected to your computer, select the Local Printer Attached To This Computer option. If you will be connecting to the printer via a network connection, select the Network Printer option, then click Next.
  8. The wizard will first try to search for any Plug and Play devices (these are components that should, by rights, automatically notify Windows when they're first connected). If the wizard discovers your printer, it will display further instructions to complete the installation. You may need to restart your system to finish.
Nov 23, 2007 | Computers & Internet
Install driver without printer?
Most softwares have a custom installation mode you should be able to enter into at the front screen, allowing custom installation (and allowing username changes). If it is a lap top, why can't you install it using network connectivity, in explorer settings, allowing you to connect to other computers, hence avoiding going to her home. It is done over the internet, and it should recognise the printer attatched to her pc at home, and sove your problem. Alternatively, she can invite you on to her pc through same process.
Aug 29, 2007 | HP PSC 2410 All-In-One InkJet Printer
Samsung ML1740 Laser Printer Logo
46 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
