Question about GE GSS20IEP Side by Side Refrigerator
GE TFX22CR Water is pooling and freezing at the bottom of the freezer, inside. Then leaks out through the door. The drain seems open. Any ideas??
SOURCE: Kenmore / GE side by side defrost drain keeps freezing up
Remove back of unit and check defrost heater has not become detached, otherwse the is only two possibilities, one a defrost fault and although you say the defrost tube is clear the only reason it does not flow is due to a restriction, what can happen is that the water backs up the drain pipe and then freezes before the water in the external tray can evaporate. Regards Advisor
Posted on Aug 24, 2007
SOURCE: Water/ice pools in bottom of freezer
The real problem is that the drain which carries the defrost water away from the coils (and down to the external pan underneath where it should evaporate) has become plugged with ice (from having left the door open thereby icing up the coils and the drain). The problem you have now is that the normal defrost cycle was not designed to melt the ice plug that is blocking the drain. Solution: You have to either (1) if you're handy, you can remove the plastic panel over the coils in the back of the freezer and melt it out with a hair dryer or hot water -- or (2) unplug the unit, leave the doors open and let it melt out by itself. I don't know how long you'd have to wait for (2) to completely melt the ice plug -- I'm guessing at least 24-36 hours to be sure. I did (1) and it took me about 2 hours to remove the freezer bin and door, remove the main drawer slides, remove the internal drawers and their slides, remove the back inside panel, find the ice plug (lower left side of the drip tray under the evap coils), melt it out with hot water from a baster, verify that the drain was clear, reassemble in reverse order. But it worked. Problem completely solved -- no water since. By the way the drip tray was completely full of ice - right after a defrost cycle had completed -- so this problem will never resolve itself without intervention. Bear in mind, the whole cycle COULD happen again if the drawer is left open again and the excess ice builds up on the coils again. This is a design flaw in the unit itself. However, I read about a clever solution to prevent a new ice plug forming as a result of the open door. Just loop a length of 10-12 gauge bare copper wire around the defrost heater element and insert the other end of the wire in the drain hole. Heat conducted through the wire during defrost will clear any ice plug that may form.
Posted on Sep 09, 2007
  • 126 Answers
SOURCE: Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Posted on Dec 14, 2007
  • 1314 Answers
SOURCE: refrigerator freezer leaking
your defrost drain is frozen or has algae blocking it its at the back of the freezer behind the evaporator cover. You can see it without removing the evaporator cover. You might or might not see the drain hole because of the ice now you can sit and poor hot water on it till it thaws then get a thin wire and run down the tube till its clear or sit there with a hair drier and thaw it .But if you don't mind a small investment ill tell you the best way to deal with it .Go to Lowe's or some where like that and buy you a eureka model 350 hand held steamer.Trust me it will be one of the best investments you'll ever make. You will find 1001 uses for it besides this and the steam will not damage your refrigerator and all the attachments make it very useful.remove the evaporator cover and take the steamer and melt the ice under the evaporator where the drain pan is. Then you will see the drain hole.Put the curved tip on the steamer an start clearing the drain hole now when you get it melted enough to where the curved tip makes a seal around the drain hole let the steam build then hold down the trigger till you hear it at the back of the refrigerator and your done put the evaporator cover back on then think of all the other uses for that steamer now I told whirlpool about it they tested it and now have it posted on their web site that will fix it easy. I hope this is good enough for a four box rateing lol
Posted on Jan 11, 2008
SOURCE: GE frig just starting leaking water at the bottom of the freezer side door
How do I clear the frozen drain in the bottom of freezer?
Posted on Apr 06, 2008
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Bottom freezer is leaking water. Water seems to
You have a clogged defrost drain. The problem is fixed by unplugging unit from wall, open both doors, blow fan for 24 hours to SAFELY remove the ice covering the drain hole. If you use ANY other method, you may regret it. Once ice is melted, remove debris that is likely blocking the small drain hole, if no debris in drain pan, direct some high pressure air down the drain to block the debris INSIDE the tubing. Furthermore, its a good idea to make the drain hole in the drain pan larger, as sometimes a bubble of water can freeze in the drain hole, and ice could be the cause of your blockage from that bubble.
Jun 28, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
Water is leaking inside the freezer at the bottom. It pools and freezes. Seems to be once per day. Any ideas
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 25, 2010 | Frigidaire FRS23KF7AB Side by Side...
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
GE tfx22r leaks water out bottom of freezer door. Bottom of freezer covered with ice. Vacuumed and cleaned evaporator and coils. ice maker water is shutoff. Water seems to be coming out from behind crisper...
defrost drain is clogged, remove back panel, and pour hot water down drain and blow it out with pressure of some sort until water passes freely
Nov 01, 2009 | Refrigerators
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Ice is forming on the bottom of the freezer (Kenmore).
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator/freezer. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Sep 05, 2007 | GE GSS25JEMWW Side by Side
GE GSS20IEP Side by Side Refrigerator Logo
259 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
