Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Help my Sony KP-46WT500 46 in. Rear Projection HDTV-Ready Television picture is like a tunnel the display channel numbers and video has a shadow of itself curved, bent,bowed??? it lookes as if the screen still works sound and picture. the left and right sides of the screen are green about 2 inches towards the middle of the screen. Any Helpful answers i would be very thankful..
    President:
  • 3,130 Answers
You need to have the convergence IC's replaced. A repair like this should run you about 300 bucks or so. In most places.
Posted on Apr 28, 2008
Video input channel stays on screen in upper left hand corner of my sony 57in hdtv rear projection
WITH AN ORIGINAL SONY REMOTE HIT THE DISPLAY BUTTON TO REMOVE THE INPUT ON SCREEN DISPLAY---IF YOU leave it on long enough it will burn that image into one or more of the 3 picture Tubes.
ALMOST ANY SONY TV REMOTE WILL WORK FOR THIS FUNCTION.
sd tech
Oct 09, 2009 | Sony KP-57WS520 57" Rear Projection...
I have a sony projection tv KP-46WT500 and have red/green shadows around the people plus some double word image that are red & green. On the tv guide the station #'s are double and green and red.The...
Replace Both of your convergence ICs STK392-??? they are big black ICs will have part number on them also CK pico fuses they look like resistors but are fuses they will be yellow or green will be around ICs.
Aug 08, 2009 | Sony KP-46WT500 46" Rear Projection...
Shadow
The sony convergence Kit Type 1 available at the following link will usually repair that issue. The kit contains the parts plus a CD with detailed instructions to do the repair.
www.tvrepairkits.net
Jun 25, 2009 | Sony KP-46WT500 46" Rear Projection...
Picture is distorted, double vision, looks like 3d.lines are arched or curve. colors don't line up. screen is bowed or warped. its a sony kp- 57ws600, 57 in. rear projection television. can you help me...
Try going into the video section of your menu, and pressing RESET on your remote control. If this doesn't fix it, try your quick start guide for setting the convergence and focus.
May 17, 2009 | Sony KP-57WV600 57" Rear Projection...
SONY Widescreen rear projection. Channel ( top right corner ) stays on. Will noit go out during program.
You need the remote control. Pressing the DISPLAY button turns the channel display on and off.
Mar 22, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony projection tv kp-53hs30 made nov.2003
do you think you can take a picture and send it to this website
Aug 08, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-51WS520 Stand by flashes 5 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
This means that there is something wrong with the video.
When you get this error, several IC and components concerning the video signal must be tested and eventually replaced.
Mar 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony Wide Screen Projection TV 46"
Can you post a picture of what the screen looks like? It could be convergence amps or a pincushion problem. The pic would help clarify the diagnosis.
Feb 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Red Shadow
UNDER THE FRONT DOOR PRESS THE BOTTOM BUTTON "FLASH FOCUS" AND SEE IF IT FIXES IT. IF NOT AND YOU SEEN RED DOUBLE OF THE IMAGE, THEN THE SET PROBABLY NEEDS THE CONVERGENCE CIRCUIT REPAIRED.
DON.
Feb 01, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
110 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
