Question about Creda Cooktops
I would like to replace the spark module i live in southern california thank you
  • 8,197 Answers
You can order parts for your cooktop by calling this # 1-877-477-7278
Good Luck
Posted on Aug 07, 2010
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
My Dacor PGM365-01 main burner continues to spark after I place a pot or pan over it. I just replaced the spark module - still happening. Valve? Micro-switch? Clean the burner?
What is your altitude?I have the same problem and was told by Dacor that I should have the high altitude version. I'm at 5000'
Feb 14, 2015 | Dacor Cooktops
Piezo igniter won't quit
Possible stuck burner switch or failed spark module. Unplug unit. Remove wires from burner switches at module and plug back in. If it starts sparking, replace module. If it stops, then replace switch harness.
Jan 18, 2011 | GE 30 in. Profile JGP932 Gas Cooktop
GE Profile nat gas cooktop, Model No JGP636BEV3BB won't ignite
If you can hear the clicking sound but are not getting a spark then there is probably a short in the ignition system. Check for any loose wires on the ignition system. Make sure all the wires are properly seated. Make sure the spark module is properly grounded. As far as testing the spark module it should be generating a spark of course. The problem is that the average voltage for the spark module is 15,000 VDC so actual testing of that voltage can be difficult. Is the spark erratic?(should spark evenly). An erratic spark timing is a sign of a bad spark module. Is the spark slow? Check the polarity of the electrical plug. If it is clicking evenly then it is probably arcing somewhere inside the cooktop and you just need to find out where. Also be aware that if you get water into the cooktop that can cause possible grounding of the spark module or ignition system.
Jan 18, 2010 | GE Profile JGP636 Gas Cooktop
Have Jenn-Air 36" gas cooktop w. 5 burners, black. Mdl JGC8536ADB. Plastic knobs keep splitting, even if we remember to push down before turning. Have replaced two sets and now we're down to two working...
Hi
Thanks for using FixYa. There are a few things to check for. Make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and not a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it.
The switches or the range control knobs may have got wet and are completing the circuit to the spark module thus causing it to continuously click or fire off sparks continuously. Use your hair/blow dryer and blow some hot air around the spark module area.
This is a typical spark module wire diagram--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 31, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Mar 09, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Recived spark module for 6 burner gas stove on DCS gas oven/
I want to gas geyser using sparking unit (ckt Diagram)
Feb 28, 2009 | DCS Cooktops
I need a user manual
I need access to the spark plug module for replacement. The plastic stove top seems sealed to the metal housing. How do I gain access? Creda GH 102 series cooktop. Spark Module Replacement.
Apr 15, 2008 | Cooktops
Electronic igniter stopped working
I recorded video to let u see how its done. Problem Was : non of the burners would ignite (no sparks when knob is turned on). First sigh of bad spark module, but I got spark switches(they harness) as well just in case - One of the spark switches was bad - Check my video how I replaced them. Non of the screws was coming out.
Nov 15, 2007 | KitchenAid 31 in. KGCS105 Gas Cooktop
Cooktops Logo
164 people viewed this question
Top Creda Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Creda Cooktop Expert? Answer questions, earn points and help others
