Question about Aastra Telecom 9120 Corded Phone (aastraa1263)
When there's an incoming call on the Aastra 9120, the indicator light flashes, Caller ID works, and the call is received when the handset is picked up. But the phone no longer rings when a call comes in. I"ve tried using the manual to restore the ring tone, but it doesn't seem to work. What is the procedure for restoring the ring tone for incoming calls?
  • 3 Answers
SOURCE: Caller ID not working
On your computer just type the brand and model of your phone and it takes you to a help site. It took me 5 minutes
Posted on Jun 08, 2007
  • 4 Answers
SOURCE: CALLER ID ONLY SHOWS "INCOMING CALL"
have the same problem with a Panasonic KX-TG9344T phone bought from USA used in india. is it a local generated problem?
Posted on Jun 28, 2008
ButtFuzz
  • 463 Answers
SOURCE: AAstra 9120 - i am currently using only one line. how do i get
Turn phone upside down and look for a little ***** switch that says 1 -- 2 -- 1+2 and slide it to the "1" position.
Posted on Mar 13, 2009
divatif
  • 39 Answers
SOURCE: handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
Posted on Mar 17, 2009
digitalhubz
  • 109 Answers
SOURCE: outbound caller ID
Telephony configuration might necessary...
Posted on Oct 21, 2009
Aastra voicemail
This Depends on your providers system . If yo go and retrieve your messages and hit 4 3 2 2 this will get you to nowhere you can record a message for incoming calls. If you want to change you message for when some calls you and you are on the phone you would do the same as above but hit 4 3 2 1. That is where you change your "on the phone message" never put a date in that one. Just record " hi I am on the phone at the moment please lease a message at the tone" Hope this helps
Apr 26, 2013 | Aastra Telecom Aastra 9417CW Two-Line...
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
HAVING PROBLEM WITH CALLER ID WORKING
Go onto the menu of the handset and set caller id to on.
Mar 16, 2009 | ATS RA2180BB Cordless Expansion Handset
I have a Panasonic KX-TCA132E but no instructions. I have set up with my phone company for incoming caller id to be displayed, however it is not working. Do i have to use the handset to activate the...
I have had this phone (twin) for quite a few years . If your incoming line supports caller ID it should work immediately. I never had to activate this. I would check if caller ID on your line is working. Check with another phone if you can.
Aug 13, 2008 | Lands Phones
UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Oct 17, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
Sep 10, 2006 | Aastra Telecom Aastra 8314 Corded Phone
Caller ID indicator
Caller ID indicator is probably a new call notification. You should be able to review the incoming calls list even if you do not have caller ID to stop the light from flashing.
Nov 24, 2005 | Panasonic KX TC1881B Cordless Phone...
Aastra Telecom 9120 Corded Phone (aastraa1263) Logo
95 people viewed this question
Top Aastra Telecom Lands Phones Experts
Illimar Saatvali
Illimar Saatvali
Jose Ma DM.
Jose Ma DM.
Michel Laprise Sr
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
