Question about Whirlpool Dishwashers
I have Model #DU1050 and I need to know the reset code. The clean light keeps flashing.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The clean light flashes, pauses and then repeats due to the dishwasher not sensing water temperature increase, it stops working, locks the functions and clean light flashes. It does this as a safety measure in case the element is broken and feeding electrical current into the water. To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it). Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 06, 2010
Clean light flashes and dishwasher will not work
when the clean light flashes its displaying a fault code based on the number of times it flashes...if it flashes 7 times then pauses then flashes 7 times again its displaying error code#7 if 4 times then pause its code#4 ect.
This tip i wrote will tell ya how to reset the board since sometimes its just electrical anomilie..reset the board and if it again flashes let me know how many times in a row it flashes and i will determine which error code it is , heres that tip to reset the control board http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
GENE
Sep 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
How to reset check engine light?
Go to your local O'Rielly's or Autozone. They will tell you the code and reset it for free. Otherwise take the negative battery cable loose for about 10 min. This will clear the ECM, but you won't know what tripped the light! Best Wishes, TJ
Aug 06, 2011 | 2007 Hyundai Azera Limited Sedan
The "clean" light blinks
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Whirlpool 24 in. DU1050SS Built-in...
Clean button will just flash need to know how to reset
The clean light is flashing due to a failure in heating the water properly. Follow the link below for instructions on resetting the control and information on what may have caused the failure. Let me know if it was helpful.
Clean light flashing
May 30, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Some lights are flushing and the dishwasher does
If the clean light is flashing it is an indication of the water not heating up. I have attached a link to a sheet explaining what might be causing it and how to reset the control so you can use the dishwasher again.
If other lights than the clean light are flashing that is an indication there is a short circuit in the keypad control and that part would need replaced. Let me know if you need details on replacing that. If so I would need the complete model number from the tag on the dishwasher just inside the door.
May 02, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Printer wont print ink keeps blinking on system
Hi
You not say what make of printer you got so not can gave you much help, because there is a reset code for different printers, the flashing lights you may be getting it because your, waste ink pads need changing and after this you need the reset codes for it but some times just the reset code will do the trick for it to print again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 07, 2010 | Office Equipment & Supplies
Flashing clean light
try opening the door and closeing it to aknoldge you know they are clean and is there a lock symble under the green light
Feb 10, 2009 | Kenmore Dishwashers
Air bag light
You can't reset it. It's flashing a code. If you tell me the code, I can tell you the proceedure to isolate the fault.
when you start up, there is an 8 second system test and the light is on during this period. Then it flashes out a 2-digit code. The first group of flashes is the first digit and then there is a pause before the second group of flashes which represent the second digit.
flash-flash-flash-pause-flash-flash-flash-flash-flash-flash = code 36
What code is your system flashing?
Jan 18, 2009 | 1996 Ford Aerostar Extended
I need to reset the mother board on my Kenmore dishwasher. Do you know the code for the Kenmore model 665-17032402. I was told by sears that they used to give this out but, because of a fire hazard they...
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again.
Apr 19, 2008 | Kenmore 17024 Built-in Dishwasher
Dishwashers Logo
85 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
