Question about Tomtom GPS
How do you attach TomTom One to the windshield?
  • 525 Answers
Ask question to your local retailer
Posted on Aug 06, 2010
How exactly do i fix the suction back onto the windscreen please? I have just bought a tomtom and don't understand the drawings!
Tomtom GPS devices come with a variety of windshield suction mounts. All have in common that the windshield and the suction cup both must be clean; use a mild soap dispersed in some warm water to remove any dirt. Rinse properly. Sometimes it helps to keep the cup a little moist.
Make sure the cup is not warped due to previous exposure to heat, and check for any nicks in the rubber. Small damage may easily make the mount unusable and you'd need to get a replacement.
Models with a lever mechanic: open the lever (cup becomes flat), press the cup against the windshield and while keeping pressure, close the lever. It will lift the middle of the cup away from the windshield, causing a vacuum.
Models with a ring around the cup base: Turn the ring all the way counter-clockwise (cup becomes flat), press cup against windshield and while keeping pressure, turn the ring clockwise 90 degrees. This requires some force, but in my experience these mounts stick more reliable,
Dec 31, 2010 | Tomtom ONE GPS Receiver
Mount no longer sticks to windshield
Well a new mount suction cup will need to be purchased. you can grab one at radioshack.com you alsmo might want to wet the plunger then try to stick it. Or clean of that dirty windshield and try again.
2 solutions
1. clean the windshield and apply a little water to the back of it.
2. Buy a new suction cup.
thats all I hope you to stop by and rate it thanks.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 16, 2010 | Tomtom ONE GPS Receiver
Suction cup does not stick to the base of the tom tom..Everytime I try to attach the suction cup, it just falls over. Help
  1. If you will stick the suction cup to your windshield make sure to clean it first use dry clothe and put pressure while rubbing it to the windshield.
  2. After cleaning it before you stick the suction cup to the windshield make sure the lock is release and then put a pressure and then while pressing it then that's the time you will lock it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Feb 06, 2010 | Tomtom ONE GPS Receiver
I got the standard mount with TomTom GO 730 and it just does not seem to work. The first time I had placed it on my windshield which I was later told was the wrong place to put it (the included maual in...
This is a fairly common issue especially with aftermarket tinted car windscreen 'film'.
You can try prolong the suction by wetting the suction cup with water of very slightly soapy water before applying it to your 'clean' windscreen area.
As for the dashboard, for some models, TomTom provide a plastic circle to which the suction cup attach to. The plastic circle is first 'permanently' attached to your dashboard with double-sided adhesive tapes.
Hope it helps: let me know how you go.
Jan 08, 2010 | Tomtom GO 730 Car GPS Receiver
For some reason, I didn't get a home charger for my Tomtom One 130 when I got it for Christmas. Will my Motorolla phone charger work? Also, I cannot understand the diagram for installing it to the...
The plastic suction cup attaches to your windscreen. You can see more of the device in www.tomtom.com
Your Motorola phone charger will not work and it may even damage your GPS! In the package you have a cigarrette lighter adapter for your car - the home charger (AC-charger) you have to purchase separately.
Jan 06, 2010 | GPS
How do I install the tomtom in my car. It cam with a big round disk with adhesive on back that I assume goes on dash or window.. But ho do I mount the tom tom to that disk? The modle did not come with...
Some TOMTOM have the EasyFold attachment: It has a large ring that you push against the back of the GPS while twisting it a bit. In some TT GPS, notably the GO series, the windshield or dashboard attachment ends in a rectangular shaped piece that slides on the back where the speaker is located.
Dec 31, 2009 | Tomtom GPS
Won't stick to windshield
The suction cup mount should be attached on a clean, flat surface. If the windshield is too dirty or curved you'll have problems. Try first to find as flat spot as possible and then clean the glass with dish-washer liquid (the type you use for hand wash - not for the dish-washer machine) or similar agent.
Dec 27, 2009 | Tomtom XL 330 Car GPS Receiver
630 tomtom dashboard afix
When I put on my Tom tom Hands signals comes on with red cross seems like Memory card accpetance problem i have done Reset click and have tried to adjust the card inside but to no avail please advise
May 22, 2009 | Tomtom GO GPS Receiver
How to attach tomtom xl to windsheild?
usually you don't attache the GPS to the windshield. it is too heavy. you can attached to the dashboard or in-front of the console. there are attachement that you can get from any of the place that sells GPS. or cell phone.
Oct 20, 2008 | Tomtom ONE GPS Receiver
Unable to attach my new tomtom 930 go to the windshield mount, how do you unscrew the mount site at the back to fit into the nmount?
I have owned an off brand GPS unit for about 3 years and wanted to upgrade to a TomTom GPS unit. I have recently purchased a TomTom ONE XL. The TomTom will not stay mounted to my windshield. I have cleaned the suction cup and the windshield and nothing has helped. After the unit has been mounting for about 30~45 minutes it will fall off the windshield. I am afraid if this continues my TomTom GPS unit will be damaged. I have never had this problem before and as I mentioned earlier, I have owned a GPS unit for about 3 years. I noticed that the TomTom mount is very cheap built. Can you send me a better mount for my TomTom One XL? I am very disappointed in the unit so far and I only owned it for about 2 weeks.
Aug 18, 2008 | GPS
GPS Logo
37 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
