Question about Car Audio & Video
The rear dvd player seems to wired into the factory harness. is their an adapter? or how do i locate the wires in the harness to the rear dvd so i can connect them to the video out of the pioneer?
  • mrpag53 Aug 06, 2010
    this doesn't give me specific instructions for my setup. can i locate the wores in the harness for the rear dvd or do i have to by an adapter?
    i'm trying to make the problem as clear as possible. the rear dvd player was wired to the factory radio through the factory harness. there are no obvious RCA video cables that can be hookd to the video out of the pioneer 920bt. i either have to know which wires in the factory harness go to the video in on the rear dvd player or i need a conversion cable from the factory harness to the video out of the pioneer unit.
    Genius:
  • 1,456 Answers
In most European vehicles,the wires are labeled on the factory radio itself. For most domestic vehicles, these wires are the same wires that feed the speakers.
Posted on Aug 06, 2010
  • 4,323 Answers
Hi
Please provide me with Make and model number of your DVD player, Pioneer and for your car as well. As this will help me to give you model specific information. Usually no adapters are used with dvd players.
Thanks
Daniel
    the dvd player is the factory installed rear player in a Buick Enclave '08. the unit i installed in the dash is a Pioneer Avic x920bt.
  • Daniel Scott
    Daniel Scott Aug 06, 2010
    Hi
    Please make sure you wire the pioneer as per the following wiring color codes--
    Car Radio Battery Constant 12v+ Wire: Blue
    Car Radio Accessory Switched 12v+ Wire: Yellow
    Car Radio Ground Wire: Brown
    Car Radio Illumination Wire: Gray/Blue
    Car Stereo Dimmer Wire: N/A
    Car Stereo Antenna Trigger Wire: Red/Brown
    Car Stereo Amp Trigger Wire: Red/Green
    Car Stereo Amplifier Location: Located behind the left rear speakers.
    Car Audio Front Speakers Size: N/A
    Car Audio Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): Blue/White
    Left Front Speaker Negative Wire (-): Brown/White
    Right Front Speaker Positive Wire (+): Red
    Right Front Speaker Negative Wire (-): Brown/Red
    Car Audio Rear Speakers Size: N/A
    Car Audio Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Brown/Red
    Left Rear Speaker Negative Wire (-): Blue/Green
    Right Rear Speaker Positive Wire (+): Blue/Green
    Right Rear Speaker Negative Wire (-): White/Black
    Also, make sure that the DVD player must be rewired with the Pioneer player as given in the below manual--
    Pioneer AVIC 920BT Installation Instructions and wiring details
    Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
    Daniel
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow links…
http://www.ehow.com/how_2026389_install-dvd-car.html
http://www.ehow.com/way_5751134_wire-harness-instructions.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
I have a 97 toyota tocoma ext.cab. and am putting in my new cd player although my wires are not the same colors could you tell me what wires i need to match
Hello... I will try and help you with your problem. I am assuming that you have cut the factory harness off in the truck? If you have and you can reconnect it, I would recommend doing this and then you can purchase a wire harness adapter and then just match the colors. The benefit in using an adapter harness is the ease of the installation, and the more you change the radio in the truck, the shorter the wires will get. If you do not have the factory harness, or cannot reconnect the old one, here is the hardwire code:
Wire purpose: Truck color: Alpine harness:
Constant 12V+ Blue/Yellow Yellow Switched 12V+ Gray Red Ground Brown Black Illumination Green N/C Dimmer n/a N/C Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Pink White Left Front (-) Purple White/Black Right Front (+) Light Green Gray Right Front (-) Blue Gray/Black Rear Speakers 6 1/2" Rear Corners Left Rear (+) Black Green Left Rear (-) Yellow Green/Black Right Rear (+) Red Purple Right Rear (-) White Purple/Black
Hope this helps!
20 year car audio/video installer
Bay manager
Apr 06, 2011 | Alpine 16 Pin Original Head Unit Harness
How do you replace the radio and insert a cd player?
Hi, pull the trim plate off the dash around the radio. The trim may go all around the instrument panel. With the trim plate off, you can see the factory radio screws. Take the screws out, pull the radio out and remove the connectors, including the antenna wire.
You will need an adapter to fit the aftermarket radio snugly into the dash. They sell these wherever they sell aftermarket radios. I recommend you also buy the cable adapter. If you don't, at least buy the antenna adapter of you will no be able to plug your antenna into the new CD player.
Follow the instructions on putting the adapter together--it's made for a lot of different cars. You need it to screw into your dash where the screws came out.
If you buy the wire adapter, follow the directions that come with it. I recommend you solder the wires, but you can use those crimp connectors if you don't have soldering equipment.
If you don't buy the adapter cable, use the factory wire colors below to match up the aftermarket wires to your factory wires. Wrap any solder connections with electrical tape and carefully plug everything back in, including the antenna adapter and antenna cable. With the adapter plate attached to the new player, carefully push the wiring aside to get the player into the slot and then screw it in. check the system for proper operation and then replace the trim panel.
Enjoy your CDs, and let me know if you have any questions.
2002 Chevrolet Silverado C1500 Radio Wiring Instructions
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Ground Wire: Black
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jan 16, 2011 | 2002 Chevrolet Silverado 1500
Wire harness to switch from stock stereo to cd player will not fit the wires that are supposed to? so what wires are the speaker wires
Not sure I understand your question. Did you buy a harness adapter for GMC, or are you trying to just cut the connector off the factory radio and solder it to your CD player? If the latter, below is the color code for your factory wiring.
1994 GMC Sierra C1500 Car Radio Wiring Schematic
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Amp Trigger Wire: N/A
Nov 20, 2010 | 1994 GMC Sierra
How to install a flip down dvd player in a 2001 chevy venture minivan
If you go to any Car Audio shop, you can get the installation kit, wire harness, and antenna adapter. 90% of the installation can be done at the kitchen table, then pull the factory radio and the new unit will plug into the factory harness and bolt into the factory locations. Make sure you have the vehicle with you when you get the parts so they can look at the factory radio and make sure you get the right parts. If it a factory Bose system, let a professional do it, there is rewiring that will have to be done. Hope this helps
Jun 18, 2010 | Clarion VRX745VD Car DVD Player
I do not know how to wire nenwood kdc-422 to a 94 buick century?
You should have a wire harness pigtail that comes with your kenwood.
you can also purchase a harness adapter plug/pigtail at most audio auto stereo shops to fit your car make and model.
Be sure to save the packaging because the plastic bag has the color/codes for the harness. This harness is designed to plug right into the factory plug inside the dash just like the stock radios do.
All you need to do is splice the kenwood cables to the adapter plug pigtail you purchase for your car.
match up each wire as described here:
1994 Buick Century Car Stereo Wiring Schematic
Car Stereo Antenna Trigger Wire: Pink
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Apr 22, 2010 | Kenwood KDC-422 CD Player
Need a wiring diagram for 2002 chev, caviler stereo hooking up aftermarket stereo
ARE YOU AWARE THEY MAKE A VERY INEXPENSIVE ADAPTER HARNESS THAT HOOKS UP TO THE FACTORY HARNESS, NO WIRE CUTING,CAR AUDIO SHOP CAN GET THE ONE U NEED, ABOUT $12. HERE IS THE WIRING COLOR BREAKDOWN OF THE DASH HARNESS.
2002 Chevrolet Cavalier Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Ignition Switch (The radio harness does not provide a switched power source. Run a wire from the Ignition Switch.)
Car Stereo Antenna Trigger: Pink
Apr 13, 2010 | 2002 Chevrolet Cavalier Coupe
96 dodge caravan radio wires
see an auto sparks ,or take to a local radio fitting shop ,no good telling me here because colours of wires can vary between manufacturers of both the radios and the vehicles
Aug 07, 2009 | 1996 Dodge Caravan
What am I doing wrong? 94 jeep GCL caska 1605 dvd
OK, HERE IS WHAT I SHOW.
DID U KNOW THEY MAKE AN ADAPTER HARNESS THAT ALLOWS YOU TO PLUG DIRECTLY TO FACTORY HARNESS? NO CUTTING WIRES. THESE ARE AVIL FROM ANY LARGE RETAIL STORE LIKE BEST BUY. PLEASE RATE MY HELP, THANKS!
1994 Jeep Grand Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Green/Red
Car Stereo Antenna Trigger: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Blue
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
Aug 03, 2009 | Car Audio & Video
Radio/CD player Wiring
Here are the correct factory radio wire colors with definitions.
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Illumination Wire: Green
Car Stereo Antenna Trigger Wire: Black/Red
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Red
Oct 17, 2008 | 1996 Toyota Camry
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
