Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Need help setting up ultra 200
I have just installed the dish and a get good Signal but poor Q, it keeps jumping from 20 to 60 then sometimes 100 the zere, i wonder if this is normal, please let me know
  • 186 Answers
Not on my dish. It usually hangs around 50%. Do you have a neighbor's tree waving in the way? Take a look and let me know what you find....
Posted on Apr 27, 2008
2001 Ultra Classic Battery went bad had to jump it quit charging. have a new battery now only shows 10-12 volts on the meter tried a different regulator with same results. tried to check stater with...
usually it is either the regulator or stator that dies
firstly check stator...(alternator)...set multi mtr at 500ac volts
connect probes (red/blk) to both wires from stator..output voltage should read between 100 acv mid revs to 150 acv mid revs
output to battery should be 13.5v -14.75v dc...if not then regulator is RS ...I used to fit Honda regulators 30amp type with 2 red and 2 green wires ..because it is a 3 phase regulator just disconnect one yellow wire
harley regulators are of poor quality...they have no on off switch like the japanese ones other words when you turn off your ignition the harley regulator is still on
hope this helps
Mar 08, 2015 | 2001 Harley Davidson FLHTCUI Electra Glide...
My gz 125 starts sometimes the carb has been cleaned out but its got a poor spark why please help
The carb has nothing to do with your spark, you need to check the spark plug, spark plug wire ( for sparks jumping to ground ) and coil/magneto.
May 24, 2014 | 2002 Honda XR 200
ViP612 DVR-HD poor play back of recording
Thank you for bringing that to someone's attention as I would love to help you with it! If you need the receiver replaced, you can feel free to email me your account number so I can see about getting a replacement shipped to you! My email address is and I'll look forward to the opportunity of getting this taken care of for you so you can start to enjoy your programming!
Dec 18, 2012 | Televison & Video
Have new E370VL hooked up to Dish Network via coax. The picture jumps/blips? Connections are tight. Help.
This can happen when there is radio interference near the coaxial cables. Sometimes the interference is behind walls. The solution is to try a different combination of modulation and channel than what the DISH receiver is current set.
The DISH menu screen for this setting is Menu-6-1-5. With dual-tuner receivers, typically "TV 1 Out" is the TV that is connected in the same room as the receiver is located. "TV 2 Out" is the tuner that is fed to the remote TV via backfed coaxial signal.
All that needs to be done is to change the channel and mode going to the effected TV to something different. If your channel/mode is currently set to Air/60, try changing it to Cable/73. When you change the mode/channel in the DISH receiver, you need to set the remote TV to the same mode and channel.
Keep in mind that with some TV companies like VIZIO, they call their "Air" mode "Antenna". With VIZIO's the TV must be set on TV input and then go into the Menu to the Settings, Tuner Settings. Change mode type to match what you are trying on the DISH receiver, exit the VIZIO menu and manually enter the channel number.
Eventually with trial and error, you will find a mode/channel combination that isn't effected by your particular environmental interference.
Jan 03, 2011 | Televison & Video
Decoder keep scanning
well, firstly. u have a sat finder!! great!! now lets see if i can teach u how to use it, when you hook it up there will always be some sort of signal, (other electronic waves in the air) the best way to check is to put ur hand in front of the LNB (the square box in front of the dish) if he signal goes down, the signal was fine to begin with, if it goes up, the dish is out, if nothing happens... dead LNB, which in my experiance, the most likely cause, dont for get to reset your decoder once you have solved the problem.. good luck
Apr 27, 2010 | DISH Network DVR-625 DTV Receiver /...
Got signal going to dish but not to reciever
contact u service provider they will provide u with the settings u need .it will be LNB and frequency settings
Apr 18, 2010 | Fortec Star Lifetime ULTRA
Changed from single to twin LNB, no signal
Here is a suggestion! Try SKEWING the LNB around a few degrees. Looking at the front of the dish, turn your LNB to the LEFT slightly (that is anti-clockwise).
Sometimes it's the little things that matter most where installation is concerned. It is also possible that due to the weight of the new LNB, the alignment may be out.
Nov 21, 2009 | Fortec Star Lifetime ULTRA
I have Dish sattelite and it won't work with memorex under cabinet. They said I need a cable box in between the dish receiver and the tv. Why is this?
You need a receiver for each TV you want to receive the reception on. Your dish receives the broadcast signal from the network and your receiver decodes and recodes the signal to view on your TV. The companies have created their own proprietary equipment to accomplish this to keep anyone and everyone from simply installing their own dish and receiving all of their broadcast channels for FREE. In the olden days when satellite and cable TV was new, that is exactly what people did. Remember those gigantic dishes some people installed in their yards? They would intercept the signals coming from the satellites and hook up directly to their TVs. The companies got smart and started to scramble the signals going up to the satellites to make these home owner dishes obsolete. Because the signals are scrambled, you now need a receiver to un-scramble the signal. I hope this helps and good luck. Please remember to vote d368a18.jpg if you found this helpful. Thanks.
Oct 31, 2009 | Memorex MVUC821 8 in. Under Cabinet TV
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
20 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
