Question about John Deere Garden
John Deere 445. I would like someone who knows about this tractor answer the question as to why after replacing the camshaft why the motor backfires through the carb. If you read through all of my questions and solutions, you will see the solutions are not accurate. Please help
  • 248 Answers
It sounds like the camshaft timing is off. Did you have some marks to match up when you put in the new camshaft?
Posted on Jul 09, 2014
I would like to know the proper way to time the camshaft gear with the crankshaft gear - John Deere Model 445
Posted on Aug 14, 2010
  • lagol Aug 14, 2010
    If I take a compression on the two cylinders, if it is 100psi (I am not sure what the compression is) would that be sufficient enought to make sure the valves are OK. What happens when I remove the camshaft and rotate the crankshaft 360 degrees?
    Sniper:
  • 197 Answers
Of the 100+ camshaft replacements that I personly have done on the 425/445 and John Deere Gators I have come across 3 that backfired when completing the replacement.2 were do to bent valves coming in contact with the piston after gear failed and 1 was from a sheared flywheel key.The only other time I had this same injected engine backfire was on a John Deere gator 620i that had a faulty computer and fired @ 90 derees off.Do a compresion check and that will help out alot.
Posted on Aug 07, 2010
  • James Brown
    James Brown Feb 04, 2016
    USE A DIAL INDICATOR ON INTAKE VALVE AND A TIMING WHEEL ON CAMSHAFT. After learning how and why to use these you will find out 2 things: intake valve is burned/not burned and/or 2) valve is opening too soon thereby letting combustible charge leak back into carb and fire when plug fires. Good Luck derfly
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
445 john deere-temp gauge flutuates between hot and normal
Try replacing thermostat.might have trash in it causing it to stick on occassion.
May 18, 2014 | John Deere Garden
John Deere Model 445 garden tractor. Replaced plastic cam shaft gear, tried to start motor and it backfires through carb. I just removed front cover of engine to check the timing marks on both the camshaft...
Hi
Please check for the anti back fire solenoid in the front of the carb. Check whether the wiring to it is fine and if it is getting +12 V. If yes then you maybe required to replace the solenod.
However, if this doesn't resolve the issue then you would need to adjust manually so that decompresser works normally. Inspect the flywheel key as well, it may have sheared.
Check the carb filter and the make sure there is no sign of water in/around the carbeurater. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Aug 04, 2010 | John Deere 420,1020,2010,2020,2510,2520...
JD Model 445 - Plastic gears. After replacing the new camshaft I need to adjust the valves. Does anyone have the specifications?
Remove the plugs. Turn the engine so the pistion is at top dead center for cylinder. Clearance should 0.010 when adjusting rocker to valve. Repeat for other side. I just replaced my cam shaft if a 1993 JD445. I'm planning to run for a couple of hours then check cleanace again. Hope this helps, Gerry
Jul 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
How can I tell the year of my John Deere 445 lawn tractor. Product # M00445C096237 ?
1993: 010001
1994: 020001
1995: 030001
1996: 040001
1997: 050001
1998: 060001
1999: 070001
2000: 080001
2001: 090001
http://www.tractordata.com/lawn-tractors/000/0/4/45-john-deere-445.html
Mar 10, 2010 | Garden
Garden Logo
918 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
