Question about Canon S520 InkJet Photo Printer
Canon s520 My printer is installed, I was using it but now I am getting a orange light blinking 7 times and then one green. I have tried uninstalling,and reinstalling. I have tried reset. I am looking for some solutions to try please and thank you. Shaunna
  • sdhsport Jun 15, 2008
    7 blinking yellows, 1 green. Removed the print head, tried cleaning it, and put it back. Works for a while then the problem returns. Any other solution? Are there reasonable replacement heads?
I had the same problem. tried resetting the "waste ink tank" counter and it didn't work. I ended up taking out the printhead (pull up on the Grey lever) when I put it back in the printer worked! Good Luck!
Posted on May 20, 2008
Canon S300 printer. 7 orange blinks, 1 green. I
According to the manual found here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=330&modelid=6609
7 orange lights represents a bad print head, and the printer will need serviced or replacement. Since printers are so cheap lately, I would just go shopping. Hope this helps! Thanks!
Oct 21, 2009 | Canon BJC S300 InkJet Printer
Canon S520 Printer
try powering it down for a couple of hours for a full reset.
Mar 03, 2008 | Canon S520 InkJet Photo Printer
Cannot get my canon to respond. Has worked fine in the past. I push to bring online and the light still blinks yellow.
Your machine does a longer green flash and then a series of orange flashes and then green again. I need to know how many orange flashes between the greens to tell you the problem..
Aug 03, 2009 | Canon S520 InkJet Photo Printer
Canon S520 printer won't print
there is a encoder strip in the printer to which the cartridge head carriage reads .if this encoder strip is dusty or loose the carriage cannot read so it bangs from left to right.and due to this printer cannot get set to its position.and the orange error light blinks.that transperant long strip with blacl vertical lines on it has to be checked.
Jan 29, 2009 | Canon S520 InkJet Photo Printer
Printer is not responding
This is the error light page from the S520. Not sure about this, but probably the same on the S530. 8 Blinks means replace the ink absorber and reset the counter. I think the ink absorber can be gotten at from the bottom, BUT NOT SURE. Try this at your own risk!
7.1 Service Mode Operation
1) With the printer turned off, hold down the RESUME button and press the POWER
button (the green indicator lights and the desired service function can be selected).
2) While holding down the POWER button, let go of the RESUME button before pressing
the RESUME button again twice in succession. Then let go of both RESUME and
POWER buttons.
(At each press of the RESUME button, the indicator toggles between orange and
green.)
3) During printer initialization, the green indicator blinks. When the green indicator
stops blinking and remains on, press the RESUME button the specified number of
times to execute the desired service function, as listed below.
green.)
Press Indicator Function
0 times Green Power off (Even if there is no print head mounted, the
carriage will return to the home position and lock.)
1 time Orange Service/factory test printout (Including ink sensor check)
2 times Green EEPROM information printout
3 times Orange EEPROM initialization
4 times Green Clears the waste-ink counter (S750/S520)
Waste-ink counter settings (S900/820) (See page 2-34)
5 times Orange Destination (model) setting
After reaching this service function, press the RESUME
button the number of times specified below to set the
destination.
Setting
0 times BJ F900 BJ F890
1 times S900 S820 BJ F700 BJ F500
2 times BJ F890PD S750 S520
3 times S820D
Note: pressing more than 3 times has no effect.
6 times Returns to the function select stage (S750/520)
6~9 times Not used for servicing (S900/820)
More than Green Returns to the function select stage (S900/820)
10 times
4) After selecting a service function, press the POWER button. The green indicator
lights and the service function will be executed. (After each function is executed, the
printer returns to the service function select stage.)
READ THIS CAREFULLY !
Larry
Nov 30, 2008 | Canon S 530D InkJet Printer
Canon S520 blinks 7 times yellow then once green over and over, won't print
Read the info on the link below:
Solutions for flashing lights Issue: Alarm / Power light flashes orange 7 times consecutively (Print head error)
1. Reseat the print head S520 / S750 2. The Print Head may need replacing - S520 3. The S520 may require repair
spacer.gif http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=231&modelid=6611
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | Office Equipment & Supplies
Orange light blinks 7 times then green light once and repeats,
It indicate that your print head may defective probably cause by electrical connection, u can try to unplug the print head and clean the electrical contact part with dry paper and install it back. Make sure the contact part is fix into the holder completely.
YBC (/\)
Oct 07, 2008 | Canon i950 InkJet Photo Printer
Flashing green light prevents printing.
hi!!!!
try to pull out the cardtridge and put it back properly
sometime the cartrigde is place properly on the printer!!!
try to email me ronaldsuboc@gmail.com
Aug 08, 2008 | Canon S520 InkJet Photo Printer
Canon s520 problem
I solve mine (4 Yellow Flash + 1 Green) by pushing on the white gear, located at the end right inside, where the cartridges are cleaning. This help the movement of the gear, it was stuck or gem. Do this when you just turning on the printer, then you ear the cycle noise, Your fingers will sense the movement of the gear. Tips: Push the cartridges block to the left to let you enough space to put your hand inside.Now it work normally.
Feb 12, 2008 | Canon S520 InkJet Photo Printer
My canon s520
The user guide for that product says that 7 flashes means the printhead is defective and that you should contact Canon's customer care. If you've recently replaced the print cartridge(s), try putting the old one(s) back in. If the printhead is truly defective, there may be no choice but to contact Canon or replace the printer.
Aug 21, 2007 | Canon S520 InkJet Photo Printer
Canon S520 InkJet Photo Printer Logo
188 people viewed this question
old marine
old marine
