Question about Kodak EasyShare C875 Digital Camera
How do i formatt my new memory card for my kodak c875 camera
    Genius:
  • 1,234 Answers
Hello There
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    My Kodak C875 digital camera says internal memory full how can I fix it
    Do you have the optional sd memory card instaleld in the camera?
    Have you formated the sd memory card or MMC card as suggested on page 37 of the user manual.
    on page 36 on image storage settings = If set on Auto it uses the external card if there is one installed rather than the internal memory.
    You need to have a memory card installed in the camera !
    see page 5 of the user manual.
    http://resources.kodak.com/support/pdf/en/manuals/urg00594/C875_GLB_en.pdf
    Jan 03, 2015 | Kodak EasyShare C875 Digital Camera
    What memory card can i put in my easyshare c875 kodak
    The C875 works with MMC and SD cards. MMC cards are going obsolete, so you'll probably not be able to find many of them. When getting an SD card, make sure it's not an SDHC card. SD cards top out at 2GB while SDHC cards start at 4GB and go up from there. SDHC cards will not work in the C875.
    Aug 29, 2011 | Kodak EasyShare C875 Digital Camera
    Lost my book,,, how do I formatt my new 2G memory card?
    Press the MENU button. Use cursor-up/down to select the wrench icon and press the OK button. Use cursor-up/down to select "Format" and press OK.
    You can view/download the user guide at
    http://support.en.kodak.com/app/answers/detail/a_id/18693/kw/c875/selected/true
    Aug 12, 2011 | Kodak EasyShare C875 Digital Camera
    I cannot format a new 4 GB memory card on my Kodak Easyshare C875
    The C875 works with MMC and SD cards. Your new 4GB card is actually an SDHC card. While it fits into the slot it is electronically incompatible and will not work. You need to use SD cards, which max out at 2GB.
    Aug 09, 2011 | Kodak Cameras
    INTERNAL MEMORY IS FULL EVEN A NEW SD CARD
    Go into the camera's menu and transfer the contents from the internal memory to the SD card. the camera has a card inside it with limited memory which is seperate from the SD card.
    Regards.
    Dec 12, 2010 | Kodak EasyShare C875 Digital Camera
    Does Kodak c875 support high speed memory card
    Yes, but it's largely irrelevant. Faster cards will work in the camera, but they won't make the camera work any faster. Faster cards will make the download process go faster, if your card reader can handle the speed.
    Jun 28, 2010 | Kodak EasyShare C875 Digital Camera
    Memory card compatibility. camera won't read or
    The C875 works with SD and MMC cards, which max out at 2GB. It will not work with larger SDHC cards.
    May 14, 2010 | Kodak EasyShare C875 Digital Camera
    I just received a SanDisk, ElitePro, 32GB memory chip for my Kodak C875 camera. Upon chip insertion LCD says, "disc requires formatting", "continue", "formatting will delete everything on memory card",...
    This camera's software will accomidate up to 2 GB SD card, or up to 8 GB SDHC card. Check your camera manufacturer's Help Page to learn the card capacity of your camera
    Dec 25, 2009 | Kodak Cameras
    My C875 Kodak Camera will not read the memory card, but it will read the internal memory
    make sure that the internal memory is sets on Auto, for you to check that first...
    -Press menu button and look for setup then press Ok button
    -Under setup look for IMAGE STORAGE it should be on auto if its Internal memory you need to select the image storage press ok button the select Auto then press Ok button again.
    -make sure the Memory card that you are using is just 1GB or 2GB SD card only do not go over than that because it will not be compatible on the camera C875
    GudluCK!
    Nov 03, 2009 | Kodak EasyShare C875 Digital Camera
    Kodak EasyShare C875 Digital Camera Logo
    27 people viewed this question
    Top Kodak Cameras Experts
    Jerry Greenberg
    Jerry Greenberg
    Computer Links
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
