Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Every time i put it on any cycle it starts then F1 shows on the screen.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 06, 2010
Laptop white screen
Maybe the lcd screen is going bad. Try an external monitor. if the external monitor works fine then your lcd screen on the laptop is going bad. If the external monitor behaves the same way, then the Video Card on the computer is going bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
May 01, 2012 | Compaq Computers & Internet
It has an F1 error code. It will start the water flow for about 2 seconds. Stops and beeps f1 on the screen. I hit the stop button and start again and have to repeat this 3 times before the wash machine...
The manufacturer has issued a remedy for the F-1. What you do is empty the machine of water and unplug it. Open the control panel and remove the pressure hose. Blow out the hose to remove sediment . Re secure it to the control and retry. No parts needed. F-1 Error infothemobilian_1223.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 01, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Error code f 1
Hello, our carbio began flashing the F1 error code at 18 months. I have to hit the pause/start 4 or 5 times to get the cycle to begin. It also flashes occasionally at the rinse cycle (17 min.) I have called Whirlpool 3 times with little satisfaction. They have offered to pay for the part, but I will be responsible for the service call, diagnostic fee, and labor. I am not satisfied with this offer. It is obvious to me with so many others experiencing the same problem that Whirlpool has a quality issue with this machine. The sales rep who sold me the machine said to call Whirlpool everyday until they are sick of hearing from me. The more calls logged about the complaint, the better chance of a recall on the machine. If this is not resolved, I will NEVER buy Whirlpool again.
I have started a petition to be sent to the CEO of Whirlpool Corp., Jeff Fettit.
Follow the link, and please sign it! The more the better! Spread the word!
You may also copy and post it to any other groups/discussions about this problem.
http://www.petitiononline.com/cabrio08/petition.html
Thank you
Jul 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My kenmore oasis shows the f1 upon starting the machine and at 23 minutes and often shows th ul why is this
Mine is doing the same exact thing. Just after I press "Start", the F1 starts beeping. Then at 23 minutes into the cycle, it does it again. So frustrating! What is wrong with this machine?
May 20, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Error 00161 00163 unit comes on and shows this screen any imput would be great thanks
According to the error codes, you have a dead backup battery and the time is not set.
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key.
WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1" This will get you into the bios "setup." You should check the date
The "hardware maintenance manual" shows you how to maintain this machine, and it explains the meaning of the error codes.
This will get you started on looking for the manual:
http://www-307.ibm.com/pc/support/site.wss/multiplefiledownload.do?validate=true
Nov 21, 2009 | IBM ThinkPad 600E 2645 Notebook
F1 code on Fisher and Paykel dishdrawer
It would seem to be in an endless loop (firmware glitch). Initially, pls try:
  • unplug from the mains or switch off the breakers for a couple of minutes;
  • plug back in/switch on the breakers say after 20 minutes;
  • press POWER to turn drawer on;
  • Press and hold (at the same time) both the POWER and ECO buttons for a few seconds;
  • a five minute demonstration wash cycle will come on;
  • press POWER again to put unit on standby, all the LCD segments will start flashing (and light up);
  • press and hold START/PAUSE for a few seconds to hear confirmation beep/tune.
Alternately, should you have the two-drawer, open any drawer and look at the wash intensity/economy buttons. Now press them, one at a time, alternating between the two, at even timing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
12 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
