Question about Samsung HLR5667W 56" Rear Projection HDTV
TV won't turn on
Samsung HLR5667W Turn it on--it responds to the remote--timer LED flashes once followed by lamp LED flashing a number of times then nothing. I can hear the motor start up (color wheel or cooling fan) but no picture or sound.
  • mthomsen854 Apr 16, 2009
    Mine does the same thing. I see more replies that think it is the Digital Main Board. The lamp is on bright in the back. The book says all 3 indicators blink when the lamp needs replacing. So I doubt it is the lamp
  • mthomsen854 May 11, 2010
    All 3 indicators should blink if it is the lamp. So that is incorrect.
You need a new lamp. the error is for dead lamp
Posted on Apr 27, 2008
Unplugged tv for storm, plugged it back in now it trys to turn on but won't
plug in a bed side light and see is it working and if it is not then the storm has damaged the tramsformer supplying your house
Aug 08, 2012 | Samsung Hlr5667w 56-inch Dlp Hd Tv
My universal vizio remote needs to be reset to my sony t.v. i have no clue on how to reset it and i dont have the code any more can you help me please?
Hello
Setup code for Sony TV with Vizio Universal remote control is [ 0000 ]
The reomote control is pre-programmed to work with all esisting Vizio TVs. If you want to set up it with Sony TV, do the following.
1. Manualy turn on the TV.
2. Press the [TV2] button on the remote control.
3. Press and Hold the Setup button until the LED light flashes twice.
4. Enter (0000) using the number buttons. If the code is accepted the LED flashes twice after the last digit is entered. If the LED does not flash, repeat steps 2 through 4 once again.
5. Point the remote control at the tV and press POWER button. The TV will turn OFF.
Other four digit codes to check for Sony TVs are: 0128/0013/0002/0071 & 0380.
If code [0000] does not respond with try other codes. Repeatsteps 2 through 4 once again after entering each code listed. The code listed with Vizio universal remote control with Sony TV is [ 0000 ].
OK.
Aug 29, 2011 | Televison & Video
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
Heard a loup pop when I turned the tv on; the timer/lamp/standby/temp lights on the power on button are now flashing; when I pushed the power button again the lamp light on the power button flashes and...
Color Wheel - Pull out the Lamp using a flash light look right into where Lamp was you should see the color wheel turn TV on watch to see if wheel is turning,From what you have said Problem will be the Color Wheel. Encompass Parts Distribution has them 1-800-638-3328
Sep 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
HL-R5667W Picture just went blank, no sound. turn on tv the timer,lamp and stand by/temp light all flash. replaced lamp still same issue heard intermittent whirling fan rubbing sound before it went bad
Sounds that tv got color wheel problem that will be replaced.
If you are handy with electronics stuff repair then replace color wheel in light engine of tv to solve its issue.
Sep 13, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
The Tv will turn on and work for 5 min then shuts down
3 lights on front flashing indicates lamp quit. Could be lamp or ballast.
Apr 10, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Replaced lamp-orange lights still flash.....lame!
Yes, Turn On TV, press and hold Volume Down button on TV front and Split button on remote at same time for 6 seconds to reset lamp timer in TV.
Sep 19, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Samsung HLR5667W 56" Rear Projection HDTV Logo
307 people viewed this question
Jerry Greenberg
Jerry Greenberg
