Question about Webroot Software Antivirus With AntiSpyware for PC
Had to get new hardrive I need to reinstall without a disk. I have the number only
  • 396 Answers
Click on the below link and download the free trial.
http://www.webroot.com/En_US/consumer-products.html
Enter your serial number and your trial will become a full version.
Posted on Aug 06, 2010
Acer Aspire one 722 windows 7 netbook. "Check cable connection" and "no bootable device--insert boot disk and press any key" are two common things appearing. The computer recognized hardrive, hardr
Hello, it looks like somehow the master boot record was erased from the hard drive, maybe viral? You mentioned the hard drive was recognized in the bios correct? If you need data from the hard drive the easiest way would be to pull the hard drive out and use an external hard drive enclosure to remove the data before you erase everything from the hard drive. If you dont need anything thing you can proceed to do a new install of Windows 7. Turn the computer on then hold alt and the f10 key to perform a factory recovery. This will erase everything and reinstall Windows 7. If this doesnt work then you will need a new hard drive and a bootable usb drive with Windows 7 on it. Hope this helps.
Feb 22, 2013 | Computers & Internet
My hardrive recently died, and so I bought a new PATA drive to go with my Soyo KT333 Dragon Lite motherboard. I get an error message when I try installing the drive, saying a disk read error occured, hit...
Is your hard drive being properly recognized/ identified in your Bios you may have to check in there
as far as partitioning goes you should be able to do that when you reinstall the Operating system in the advanced mode depending on what operating system of course.
Dec 21, 2010 | Computers & Internet
As soon as turn computer on it says operating system not found -- i can get it to go to one other thing and it ask for HDD user password which i have no earthly idea what it can be
1. i hope you have backed up of all your data from the HDD.
2. format the HDD and reload the OS - but this time, make sure that you have atleast 2 partitions.
3. keep all your important in the second (non-system) partition.
4.after you have reloaded the OS, please get a good anti-virus and anti-spyware application and scan your computer regularly with them.
Nov 19, 2010 | Acer Aspire One PC Notebook
My hardrive "simpledrive" model 96300-41001-156
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 03, 2010 | SimpleTech SimpleDrive Portable USB 2.0...
EXTERNAL MAXTOR HARDRIVE WAS ISLIGHTLY DROPPED. NOW WHEN CONNECTED TO COMPUTER (USB) DOUES NOT DECTECTED. POWER ONLY FLASSHED (LED), AND MAKE A SMALL CLICK HARDRIVE SOUND, LIKE IT IS TRYING TO SPIN OR READ...
I think that your disk-drive is "SLIGHTLY" dead. :-(
Disassemble the enclosure.
Get the model-number and serial-number from the label on the disk-drive.
Access Maxtor's web-site, and check the warranty-status of the disk.
If the warranty still is valid, Maxtor will replace the disk-drive, at minimal cost to you.
If the warranty has ended, buy a new, compatible, disk-drive, and install it into the enclosure, to "reconstitute" your external storage-device.
Oct 28, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
A530 hardrive died installed new one need set of disc to reinstall have xp sticker but cant find disk can i buy a rebuild set
Contact the manufacturer with the complete model and serial number.
I don't know about Balance, but HP charges about $10 for a new restore disk for a specific PC.
Dec 06, 2009 | Dishwashers
The bios test of hard disk test is failed wht can i do now
If the hard disk has failed, and you want the data off of the hard disk, you have two choices..
Purchase a extender to allow you to read the hard disk and also purchase a data recovery program to get the data off the hard disk...
Or google data recovery service and find one that can retrieve data of of bad hard drives..
Either way afterward you will need to purchase a new hard drive.. They have drives as low as 30 dollars online that can be purchased and then installed.
You will need to reinstall windows on the new hard drive you get..
Ultimately you will have to weigh the cost of repairing the computer ( purchasing a hardrive and purchasing a new copy of windows)
Versus purchasing a new computer.
Oct 31, 2009 | HP Compaq nx9030 Notebook
Mavis Beacon Teaches Typing 17 Deluxe Does not start
Assuming you have not switched to Windows Vista with the new hardrive - as Mavis Beacon 17 does not work in that platform - then-
it sounds as though the file is corrupted. I would uninstall and reinstall the product. Unfortunately, difficult to do with out a cd or good original disk to start from. If you have your order number or purchase numbers when you bought your download, then customer support should help you get a clean download.
Here is some information on system configuration- it is similar for the setup of Mavis beacon 17
http://www.broderbund.com/store/broder/Content/pbPage.ProductSupportMain
Mar 27, 2009 | Encore Mavis Beacon Teaches Typing 17...
Hi CAn anyone Help I have a Dell Latitude D610 When I start up I see the windows xp logo and then the screen go blue Its freezes with the following message... A problem has been detected on your hardrive...
You need to do the following:
test a different RAM module, even if this does not happen frequently a faulty RAM can give same problem.
The problem is more likely a defective system or a faulty hard disk drive.
Try reinstalling Windows, do a full installation with hard disk formatting (do backup of your files first).
If that still does not work, then the hard disk has a faulty sector, replace the hard disk.
Dec 23, 2008 | Dell Latitude D610 Laptop Computer -...
MX6425 PC Notebook. After a system crash, I had to format my hardrive. I cannot find the original OEM disk to reinstall. I cannot get the downloaded drivers to install for the modem. Is there a install...
Gateway.com has all the drivers that were orginally installed on your computer at their site.
Just open http://gateway.com - click on support then put the serial number of the machine in the blank. it will take you to the site to download all the drivers you need for that computer.
Jul 03, 2008 | Computers & Internet
Webroot Software Antivirus With AntiSpyware for PC  Logo
Top Webroot Computers & Internet Experts
Mike
Jerry
Jerry
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
