Question about Disney Mix Max Digital Media Player
Disney mix max
My daughter's mix max won't play & it won't turn off.it is just stuck on the screen as if it is paused. she used it last night and it was fine. i can't find the manual either. help!!
  • annie1221 Apr 27, 2008
    same problem, the mix max starts and plays, then will not turn off and is stuck on "starting up". Have to run the battery out before she can use it again and then is sticks again.
  • annie1221 Apr 29, 2008
    • thanks for the solution with the reset button - worked awesome.
    • next problem: now our Lizzie Mcgure movie stick won't work - it states "file not supported". Pirates of the Caribbean works and so do the music sticks.
    • Any advice on this? Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Did you try the reset button. you have to place a pin point or paper clip in the hole to reset.
Posted on Apr 28, 2008
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
Mix max won't play music, turnoff or charge
If it is not recognizing by the computer, not turning off, or recharging, then you have a problem with the battery in itself (or battery related components).
You probably won't be able to get a battery replacement for that unit.
With anything, when a computer system, router, MP3 player, IPOD, etc. has problems functioning correctly, there is more than likely a power issue with the unit.
Aug 06, 2009 | Disney Mix Max Digital Media Player
How do i play the music
well u have to turn ur mix max on use the little arrows and once its on the big huge head phones then click on play slash pause i hope that works
Jul 21, 2009 | Disney Mix Max Digital Media Player
White blotch on Mix Max
No contact disney they will replace it free of charge it you have your recipt
Dec 27, 2008 | Disney Mix Max Digital Media Player
I lost my disney mix max charger
There are several types of chargers you can use with the mix max....car charger, wall charger, USB to computer (FYI turn your computer off while charging and it stops), and my favorite - the speaker station. Just do a search for disney mix max charger on the internet, amazon, or ebay and several options will come up. I like the speaker station because it is easy to charge with it and lets my daughter use it as a stereo and dance unit if she wants.
Dec 10, 2008 | Disney Mix Max Digital Media Player
Blank screen and weird noise
You can try the instructions located at the link below to try flashing the internal firmware of the player and see if that corrects the issue. If that doesn't work I'd suggest contacting Digital Blue for warranty replacement.
http://digiblue.com/customer-service/faqs/disney/mixmax/MixMaxFirmwareUpgrade.doc
Jul 25, 2008 | Disney Mix Max Digital Media Player
No power
to cut on the mix max you have to press the button with a line in a circle.also you have to have a video to listen to.if that doesnt work than get a refund.
Jun 14, 2008 | Disney Mix Max Digital Media Player
Disney Mix Match
You may need to update the firmware on the player in order to be able to play the Max Clips.
http://digiblue.com/customer-service/faqs/disney/mixmax/14.html
As far as putting songs on the player goes check out the FAQ's page on the manufacturers website. The specific FAQ for adding songs is here...
http://digiblue.com/customer-service/faqs/disney/mixmax/02.html
Mar 17, 2008 | Disney Mix Max Digital Media Player
Disney hannah montana mix max
I have the same problem with my daughters Tinkerbell mix max. Any suggestions?
Dec 27, 2007 | Disney Mix Max Digital Media Player
Disney Mix Max Digital Media Player Logo
184 people viewed this question
Top Disney Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Rick
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
