Question about Garden
Running irratikly - Garden
  • 11,896 Answers
Many machines do this when the carb float is sticking. Revs up and down over and over again.
Try tapping on the carb bowl with a screw driver handle. Sometimes it helps.
The best thing to do would be to pull the carb off and apart and clean it all out with carb cleaner or let the parts soak in parts cleaner for an hour.
Then let it dry and put it back together and you should be good to go.
Posted on Aug 06, 2010
Tip
How to replace a run capacitor
A Run capacitor has 2 terminals, they go to the Run and Start winding terminals, in this case the Line 2 leg of power is wired to the Run terminal on the run capacitor, that is due to the fact this is a single speed motor and speeds are on the Run winding, had there been 2 speeds, the Line 2 leg of power could not be wired to the Run capacitor but would be going to the High or Low speed terminals, conversely the Run terminal on the compressor can accept only 1 lead.
All electric motors get 1 leg of power directly to the Common lead, the remaining leg of power Always goes to the Run winding or speeds on the run winding if a multispeed motor.
Some compressors have a shared capacitor with 3 terminals, they share the leg of power to their Run windings however to Hermetic it will be say 30 MFD and to Fan it will be say 5 MFD, but as to capacitor theory they get Run and Start Always
Power can be wired to Run on the capacitor as long as the motor is a single speed.
But power ALWAYS goes to Common directly while the remaining leg of power goes to the Run winding or Speeds on the Run winding as in High and Low speeds.
on Oct 14, 2013 | GE 1 Pcs. Of 50uf 370v Ac Motor Run...
Tip
If you're troubleshooting HVAC electrical problems 230 volt single phase ac The...
The Common wire or circuit on an A/C or heat pump never has a run capacitor in that line.
The Run wire always has the run capacitor in that line or circuit.
115 volt ac
The Run or Hot wire has the run capacitor and the neutral wire does not.
So if you are tracing wires out in a circuit, if there's a run capacitor, it's the Run wire or Run circuit.
The Start wire always goes to the opposite side of the run capacitor than the Run wire and it is the only wire on that side of the capacitor.
The Run wire goes to the run capacitor, then goes to contactor, compressor, start capacitor or fan, so there's usually two wires on the Run side of the capacitor.
on Jan 07, 2010 | Heating & Cooling
Why is my new AC running all day and then losing a degree or two
Is outside unit running? If it is not that could be the reason. If it is running then you could be low on Freon. Check to see if outside is running if it is put your hand over the fan if its warm or hot the compressor is running if it is cool then your compressor is not running. Check this out because your inside unit will run even if the outside is not running.
Jul 07, 2014 | Heating & Cooling
I've just started running. Do I need to buy a stopwatch?
It's a good question - it really depends how seriously you want to take your running and what kind of running you are doing. Is it jogging for exercise, sprinting, marathon running? Check out this answer from running.lifetips which should help you figure out if you need to buy one. http://running.lifetips.com/faq/130138/0/should-i-buy-a-stopwatch-for-running/index.html
Aug 20, 2012 | Exercise & Fitness
Tip
A Tip to Remember when Electrical troubleshooting
115 volt ac
When furnace runs blower won't run.as soon as furnace stops blower runs. They never both run.
Sounds like fan limit switch/fan timer
This will cause the main burner to run untill the over tempreture switch is tripped therefore shuting gas supply and running fan on high till over heat condition is resolved then it will restart burner and repeat
continuing to run heater like this will cause heat exchanger split.
May 13, 2010 | Heating & Cooling
It runs good thin it bogs bown and flutters
what fuel mix are ya running you should be running 40.1 or 50.1 somethings causing the engine to get to hot to run it should run cool to keep running
Nov 02, 2009 | Poulan Featherlite Gas Blower, with Low...
Dayton Motor and capacitors for Carrier AC Unit (model # 38ck030300)
The 2 brown wires to the cap in first legend is how they are wired electrically,inside that motor the run winding is common to that brown one they cappped off in the 2nd option, but the powers still going to Run.ommon and run get the juice either way, its just another way to do it, but electrically as to sides of power and where they go is no different, just different way to do it.you can run power in on the Run terminal on the run cap, the run winding and run cap and start cap if equipped are Run to Run to Run.So the hot leg for the run winding also goes to run on the caps, run to run to run.,run winding to run cap to run on start cap.
Apr 07, 2008 | Carrier 38CKC036 Air Conditioner
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
