Question about Sony Cyber-shot DSC-W55 Digital Camera
What to do if there is corrosion due to water in Internal circuit
  • 3 Answers
Hi, This can be rectified at Sony service Centres, please get in touch with them. In India, you can locate service centres at the following places, link - http://www.sony.co.in/section/servicecentres
Regards,
Sony India Team
Posted on Aug 11, 2010
  • 455 Answers
The corrosion in the Internal Circuit may need replacement to get it work. This can be done at the Sony Authorized/Factory service center. It is better to replace the internal circuitry for complete resolution, better to contact the service center to check if it requires replacement.
Posted on Aug 07, 2010
Codes351/420/442/455 what do they mean
(M) Check Engine Light ("Malfunction Indicator Light" or "Check Engine") will illuminate during engine operation if this Diagnostic Trouble Code was recorded (depending if required by CARB and/or EPA). MIL is displayed as an engine icon on the instrument cluster.
P0351 (M)
Ignition Coil A Primary/Secondary Circuit
Peak primary circuit current not achieved with maximum dwell time.
P0420 (M)
Catalyst System Efficiency Below Threshold (Bank 1)
Catalyst 1/1 efficiency below required level.
P0442 (M)
Evaporative Emission Control System Leak Detected (medium leak)
A 0.040 leak has been detected in the evaporative system. (A faulty gas cap may cause this code). Also see TSB 25-001-02A. Note: The respective Powertrain Diagnostic Procedures Manual will direct the technician to determine if the vehicle evaporative system has an external system leak. Examples of some external system leaks are: a loose gas cap, a disconnected evaporative system hose, or a loose hose connection. Remember that the evaporative system may also have an internal system leak. This internal leak may be caused by an intermittent or permanently stuck open Duty Cycle Purge (DCP) valve. This leak source is considered to be internal because any escaping emissions enter into the engine system and not directly into the atmosphere, unlike an external leak. An internal leak may cause one of the above DTC?s. Possible causes of a stuck open (intermittent or permanent) DCP valve are: 1. Corrosion due to system moisture or possible water intrusion into the system.
P0455 (M)
Evaporative Emission Control System Leak Detected (large leak)
A large leak has been detected in the evaporative system. See TSB 25-001-02. Also, possible faulty or loose gas cap. Note: The respective Powertrain Diagnostic Procedures Manual will direct the technician to determine if the vehicle evaporative system has an external system leak. Examples of some external system leaks are: a loose gas cap, a disconnected evaporative system hose, or a loose hose connection. Remember that the evaporative system may also have an internal system leak. This internal leak may be caused by an intermittent or permanently stuck open Duty Cycle Purge (DCP) valve. This leak source is considered to be internal because any escaping emissions enter into the engine system and not directly into the atmosphere, unlike an external leak. An internal leak may cause one of the above DTC?s. Possible causes of a stuck open (intermittent or permanent) DCP valve are: 1. Corrosion due to system moisture or possible water intrusion into the system.
May 01, 2014 | Jeep Grand Cherokee Cars & Trucks
My car alarm siren will not go off
You have a wiring issue, bad ground, incorrect relay, loose connection, faulty alarm horn... start with the alarm horn as they often fail due to debris build up and corrosion issues at the internal/external contacts... then check ground and make sure the circuit you added is on its own fuse and is not just jumped from another circuit... Post results or additional questions
Dec 30, 2013 | AviStart 5303 2-Way Security / Remote...
When your starter gets wet does that cause your starter to go out?
It could but usually not. Moisture could over time cause the brushes to stop making contact.
Jul 13, 2012 | Dodge Intrepid Cars & Trucks
Hotsprings Prodigy Spa
Assuming there aren't any other faulty electrical components your GFCI will trip as a result of the heater element short circuiting.
Typically this happens when water infiltrates the heater element's protective outer coating and comes in contact with the internal heating coil. The culprit could be corrosion but usually it is a pin sized hole in the element which will lead to a short circuit.
When this happens the element has failed and cannot be repaired it must be replaced.
Feb 17, 2012 | Pool & Spa
Hello, my Canon camera was soaked in sea water and I would like to know if it worth fixing and how much it would cost and if there is somewhere in Surrey. The model is EOS 1000 D and the main circuit, DC...
Sea water is corrosive and continues to damage the internal parts even after it dries. I don't know of any service dept. that would touch it and if they would, the cost would be prohibitive.
Sep 13, 2011 | Cannon Cameras
Sensor remote does not send information to the clock
After some time outside, corrosion occurs on the circuit board, when water enters the unit through the vent on the front of the sensor. The vent should not be blocked, as this will still result in corrosion due to condensation building up in the sensor. Corrosion will be less likely to occur, if the sensor is located away sources of humidity and falling water. I located mine in the shade on my deck, under an upsidedown flower pot.
Dec 05, 2010 | La Crosse Technology TX37UIT 915MHz...
The check engine light produced codes p1150 and p1155 on a 2000 toyota avalon xls.
All cars sold in the US after 1995 use the same on board diagnotics called OBD-II. The codes are the same. Search OBM-II error codes and you'll get a listing.
P1150 Air/Fuel Sensor Circuit Range/Performance. (cylinder bank 1 Sensor 2)
P1150 may mean that one or more of the following has happened:
water or corrosion in the O2 sensor connector, loose terminals in the connector, wiring burnt on exhaust components, open or short in the wiring due to rubbing on engine components, holes in exhaust allowing unmetered oxygen into exhaust system, unmetered vacuum leak at the engine, bad O2 sensor or bad PCM.
P1155 Air/Fuel Sensor Heater Circuit. (cylinder bank 1 Sensor 2)
P1155 may mean that one or more of the following has happened: O2 Heater element resistance is high, Internal short or open in the heater element or O2 heater circuit wiring high resistance
Solution :Replace oxygen sensor and see if the problem goes away.
Nov 16, 2009 | 2000 Toyota Avalon
Vac code came on 0455
Jun 30, 2009 | 2001 Dodge Stratus
Vw passat 1.9tdi
the water in the footwell can make the wiring rotten check under the tape for any corrosion,i have changed a couple of units that have blown due to the water but it is a common fault
Mar 03, 2009 | 1998 Volkswagen Passat
Our Baxi combi 130 HE heats the water OK but will not heat radiators. This has happened after a period of not using the radiators (ie. over the summer)
check the pressure it should be in  the green band, check the pump, inside the boiler cabinet lower right.
Oct 29, 2008 | Heating & Cooling
Sony Cyber-shot  DSC-W55 Digital Camera Logo
53 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
