Question about Panasonic HDC-SX5 DVD Camcorder
Sound loss through conversion to MPEG
Hi, hopefully this is a simple problem, when i copy from my SD card onto my PC with HD Writer 2.0E SX/SD then convert the file MPEG i loose the sound altogether. I still get sound from file in HD format but not MPEG.
Thanks
Andrew
    Genius:
  • 1,226 Answers
You need a audio codecs to support your video conversion, Download and install the codecs that is needed to your video conversion. such as Ffdshow and other codecs needed.
i google it and here is the result http://www.google.com.ph/search?hl=en&q=audio+codecs&meta=
may this help
melnavz
Posted on May 02, 2008
    Genius:
  • 3,422 Answers
HI,
It can be the software problem.I'll give you another software conversion tool to mpeg.
Goodluck..
  • Priya darshan May 02, 2008
    Well there is no software available rigtht now for it.But CLICK HERE and you will get all the steps as what you will need to do to convert the file.
    If you want to rate or accept my solution as fixya then my solution no. is 2.
Cannot upload video from my samsung camcorder as it tells me that the camera is empty however the card is full. My samsung camcorder is using mpeg and the program is mediashow it shoul;d be simple
Hi chucky56846
I'm not familiar with your system but since your camcorder is using mpeg files , Windows should be able to open them without a third party soft . Whith the camcorder connected to your pc and set on " play " , it should appear in the computer folder and you could normally copy the mpeg files on your hdd from there . Launch Cyberlink when done , using the copied files .
I hope this helps .
Best regards ,
fanaudi .
May 29, 2011 | CyberLink MediaShow 4 for PC
Hd writer on mac
please check if you are using DVD-R to the hd writer...
if you are using it .then its not possible
You can only use DVD-RW and must format the disc to VR format, not Video format.
Mar 22, 2008 | Panasonic HDC-SX5 DVD Camcorder
How do you download music on a dsi
Hello sherribaxley
As far as I know, there is no direct way to download music onto your DSi. In order to listen to songs on your DSi, you will first need to copy the songs you want to listen to onto a compatible SD or SDHC card. Not all songs are compatible with the DSi. Some songs may be copy protected and will not work. The DSi is compatible with AAC audio files with a filename extension of .m4a, .mp4, or .3gp.
WHAT YOU'LL NEED
- A compatible SD or SDHC Card. The DSi is compatible with SD cards up to 2 GB and SDHC cards up to 32 GB.
- Compatible music files stored on a PC or MAC.
- An SD Card slot in the PC or MAC, or an external reader/writer
WHAT TO DO
1. Insert the card into the slot.
2. Open Windows Explorer (for PC) or Finder (for Mac) and select the drive being used by the card to open it.
3. Open another instance of Windows Explorer or Finder and navigate to where the music is stored.
4. Highlight the desired file(s) and/or folders, copy them, and then paste them into the first instance of Windows Explorer or Finder to create copies on the card.
If you need to convert the format of your music files, there are many freeware applications available to download on the web. I personally would suggest using iTunes, as it has a built in AAC converter.
Hope this helps. Please don't hesitate to contact me should you require any further assistance.
ajblaj
May 03, 2010 | Nintendo DSi Matte Blue Console
Workaround needed to import video from Canon HG20 into Studio 12
With advanced HD (High-Definition) video conversion technology, HD Video Converter can easily convert among HD video formats, convert video to HD, convert HD videos to SD (Standard-Definition) videos. The HD video converter supports most of HD video formats such as AVCHD (mts, m2ts), H.264/AVC, MKV, MPEG-2 (ts), DivX, HD WMV, MPEG-4 and Quick Time.
Sep 15, 2009 | Canon VIXIA HG20 DVD Blu-ray Camcorder
HD WRITER 2.0E FOR SX/SD WILL NOT RUN ON MY COMPUTER USING WINDOWS SERVICE PACK 3. hOW DO I UPGRADE THIS WRITER
try this : http://avs4you.com/AVS-Video-Converter.aspx?type=GoogleAdWordsSearch&gclid=CPzqs8yy6JcCFQEpGgodvyWzDA
Jul 16, 2009 | Panasonic HDC-SD5 Flash Media Camcorder
Can't get it to recognize music we added on a new scan disk
All you need is a SD disc usb holder to transfer files from your windows Media player onto it. Use the Windows converter to format your songs to mp3. Just right click on the songs or albums in your library and then select Send to > Windows Audio Converter > A window will pop up that has the songs selected ready to convert, but you need to first use the browse icon to make sure the MP3 SD disc is the output folder you are sending the music to. Just see whether the disc holder is plugged into the g or h drive, then once that has been done you can start the conversion. Once that is done, you should be able to play the music back on your HD Road Tech mp3 palyer. ONe last point, make sure to uncheck 'add my converted files to my library' as that will double up the same music selection in your library. Remember you are just wanting to copy the mp3 files to the external SD disc for your player not make mp3 files for your pc media player. Hope this helps.
Jun 09, 2009 | Harley Davidson Road Tech HA90 MP3 Player
When I tried to transfer my video files from Panasonic HDC-SD100, I get the message 'Cannot find image. It is possible that images which comply to AVCHD specifications were not recorded.'
Jun 06, 2009 | Panasonic HDC-SD1 Camcorder
Conversion from AVCHD to MPGEG with Panasonic HD WRITER
The video formats that your Panasonic HD-SD5 produces is AVCHD format, you you can choose an AVCHD video converter to help you to convert AVCHD to MPEG.
The most easiest and fastest video converter i ever used is Aunsoft MTS Converter which can hel you to convert MTS video files to almost any video format you need.
If your want to join your sapareted video files into one, this software can give you a hand due to its function of merjing video files into one.
http://www.aunsoft.com/mts-converter/
Aug 30, 2008 | Video Cameras
DVD Copy
hi, you are going to need a high def player to view or play this info:
Jul 23, 2008 | Panasonic HDC-SD5 Flash Media Camcorder
Panasonic HDC-SX5 DVD Camcorder Logo
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
