Question about Mtd Garden
Model 136h450f522 12/38 changing bearings on deck and when i unhooked deck spring that holds deck plate that back 2 hooks attach to fell off and i am not sure how it hooks back up. I see where the front end hookes to but the hook on the back fell down and i am not sure where it goes. thank you ROB
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
SOURCE: Reattach mower deck spring instruction
I have a 13.5 Yardman, MTD I can figure out how to reattach the deck springs? please help.
Posted on Jul 18, 2009
  • 257 Answers
SOURCE: Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Posted on Aug 15, 2009
  • 61 Answers
SOURCE: Spring Ext Elect Clutch became disconnected
look for a slot in an arm on deck this should have a pulley on it.
Posted on Sep 07, 2009
jdlipscomb41
  • 157 Answers
SOURCE: The large spring running from
look on the rearend for a brakett hanging down to hook one end and on the deck look well and you will see another brakett with a small hole the other end hooks in
Posted on Oct 26, 2009
What is proper procedure for replacing all 3 pulley/ blade drive assemblies. Had trouble getting blade mount plate off of bottom off spindle shaft.
OK I HOPE THIS WORKS I HAVE A T-13560 GUESSING THEY'RE CLOSE, I HAD TO PULL OFF THE TOP COVERS SHAPED LIKE A "V" WITH ONE NUT HOLDING IT ON ,FIRST REMOVE THE CENTER BLADE BOLT UNDERNEATH ...THEN YOU'LL SEE THEIRS 4 1/4-20 HOLDING THE BLADE DRIVE ON BUT FOR ME I ACTUALLY TOOK THE FOUR BOLTS OUT HOLDING THE ENGINE MOUNT OUT IE. THE CENTER OF THE DECK TO EXPOSE THE TOP OF THE CENTER PULLEY (MY BAD ONE) AT WHICH POINT I COULD TAKE AN IMPACT WRENCH TO REMOVE THE PULLEY NUT ...THEN UNDERNEATH REMOVE THE BLADE MOUNT ....MY BOTTOM BEARING FELL APART SO I COULD PUT THE SHAFT IN A VISE , HEAT IT UP AND TURN IT COUNTER CLOCKWISE ...THEN REASSEMBLE GOOD LUCK
Jul 07, 2015 | Swisher T14560 T - 60" Trailmower with 14...
I changed the belts and a spring fell off the top pulley, where dos it go
Hi Cookie:
The spring will probably attach to the bracket that holds the idler pulley against the belt. With the engine off, have someone move the control levers. Watch to see which pulley moves back and forth. That one should have a hole in the mounting bracket that the spring will hook into, and the other end of the spring will hook into another hole or notch.
Patience...... You'll find it.
May 25, 2015 | Garden
Where does the spring on the craftsman 1000 hook
If you are talking about the spring that allows you to dissengage the deck blades, the back end attaches to the hook or hole on the lever and the front attaches to a hook or hole on the front of the top of the deck.
Oct 04, 2014 | Craftsman Garden
Blade still running after lever is disenagaged on Sears Craftsman LT2000 2010 riding mower.
the moveable arm that the blade engage pulley is attached to has a hole for a spring as well as the deck (or at least an attached immoveable bracket). spring goes there to bring the blades to a stop when putting the lever in the off possition.
Jun 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Intertherm model nomenclature
Look for 2 plates on top of carb. Rear plate, rear hole should be spring attachment.
Jul 31, 2013 | Husqvarna 675 hp 21" Honda Rear Bag Push...
Kitchenaid deluxe 5 edition stand mixer runs on speed 10 and after 30 sec stops I thought it was the speed control pannel then I order one online and change it but that work 2 times and i have the original...
In the Artisan mixers the problem can be caused by two different parts. First the speed control plate. When you remove the end cover from the mixer the first thing you see is the speed control plate. There are 3 screws on this, two at the top, one on the bottom. Try adjusting the top two screws, to adjust, turn in the control plate adjusting the screws an equal amount.
Also check to see if the control plate spring is unhooked. Remove end cover, and check control plate spring. If unhooked, attach to bottom of the control plate and squeeze the spring end.
It can also be caused by incorrect wiring, check the wiring, the last page of the service manual will be a wiring diagram for your mixer. Here is a link to the service manual. http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Last, if the control plate is properly adjusted, the control plate spring is hooked correctly and the wiring is correct you will need to replace the speed control phase board. With the line cord disconnected, pull the t-bar contacts to open and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run. If it operates at full speed, the phase control is defective and needs to be replaced.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 27, 2013 | KitchenAid KSM150PS Artisan Series Stand...
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
Drove without deck something went bang and I found a big spring on the ground
it hooks to the rear of the deck and the bracket on the transmission. i just took this picture. i have three the same way.
Mar 28, 2017 | Yard Machines MTD Gold 185 HP Lawn Tractor...
I am replacing the backing plates on my 2003 silverado and need ti unhook the emergency brake cable so I can install the new backing plate. The spring is very heavy and I have to compress it inorder to...
they make a tool but you can use a pair of needle nose locking pliers. push the springs up and lock the pliers to hold it there so you can change what you need to.
Sep 21, 2010 | Chevrolet Silverado 1500 Cars & Trucks
Long drive belt cant remember how to put spring back on
The 'j' hook hooks over the transaxle and just hangs there. The spring attaches to the stabilizer rod (reference # 43) and the other end attaches to the "j' hook hanging on the left axle.
Jun 20, 2009 | Mtd Garden
Garden Logo
208 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
