Question about HP Compaq nc6000 Notebook
Cant log into computer. it needs a hard drive password and l dont have the password
  • 408 Answers
You will probably have to replace the hard drive.Hard drive passwords are virtually impossible to remove even if you try it with another computer internally or externally
Posted on Nov 20, 2011
I dont have permission to open my files
It sounds like you need to 'Take Ownership' of the files on your new computer - this is something you can do with a Hard drive formatted with the Windows / NTFS File system (You will need to be logged on with Administrator privileges on your new computer) - Connect your old hard drive to your new computer (using a USB interface / or directly via SATA / IDE) Open your 'My Computer' Folder using windows Explorer - Right Click the drive representing your old hard drive and choose Properties > Security > Advanced > Owner --- Click the Edit button and change the owner to the account you are currently logged on with -- then save and close the security properties dialog - The Next time you open the security properties dialog you should be able to change the level of access to "allow everything" - If this is applied to an entire Hard Drive and you choose to change the owner on all sub directories and items within them it may take several minutes or even longer with a large drive 500 GB / 1 TB etc...
Nov 24, 2013 | Western Digital WD Passport 250GB Portable...
Hitachi sata 120 gb hard disk lock & password
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also if this is a desktop computer
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jul 29, 2011 | Hitachi HTS542520K9SA00 200 GB SATA Hard...
I forgot my password and i dont have any backup.. please.. help me how to resolve my problem.. please ;(
if this fails
i have used this software and no that it works although you might have to get a computer with an internet connection to download and burn it to a disc
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive) Hope this helps
May 02, 2011 | Buffalo Technology MiniStation Stealth 500...
Dont have adnimastraighter password and want to reboot my laptop from manufacture sales
i hope you mean manufacturer (factory default settings)if so
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
as for the password
When you boot up to the log in screen type in administrator to log in if you cant log in
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
control panel user accounts
on the users tab,click the name of the computer administrator you can change the password there
Hope this helps
Jan 02, 2011 | Computers & Internet
I have windows xp that is not working keeps looping thru logo start up options do not work need to boot cd rom ctrl /esc works but that option does not have the + next too it boot cdrom so need to get into...
first try this before attempting to change password
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
or
hope this helps
hope this helps
Dec 14, 2010 | Gateway Solo 5300 Notebook
I bought a laptop at a garage sale for 50 bucks. It is an hp pavilion ze 4500. Its hard drive seems to be wiped clean which is fine but now at start up it asks for a password which I dont have and cant get...
Well, you have two options. If it is still running XP as an OS, then you can use the backdoor. When you first start up the computer, and you come to the log in screen, press ctrl + alt + del twice, and the screen should change to a different log in area. Here, type in Administrator as a username, and leave the password blank. This should bypass the need for the regular user password. Once you log in, I would recommend going to control panel, and under user account (or something similar), change the username and password of the account that could not be logged into.
Your second option can be done with any windows OS. You can reinstall the OS, and, if you desire, keep the data on the computer. Obviously, this will be much more time consuming. You will also need an installation disc, or a device with the equivalent software to one on it.
Actually, you can always upgrade your OS too, if desired. Although, you might now be able to keep the data on the computer.
Hope this helps.
Feb 28, 2010 | Computers & Internet
Getting a blue screen stop error, but cant log
Please try to start from the beginning and reformat the hard drive by shutting down the system with the cd drawer open. Then insert the windows disk and turn on the pc then the drawer closes and when it tells you boot from cd press enter. Then windows will load. It will give you a couple of options. Always choose format partition. Then you should not have any problems. Unless your hard drive is bad.
Dec 14, 2009 | Microsoft Windows XP Professional With...
Need help to reset a note book i bought on bootsale, i cant log on windows, it does come on, but i have to enter the password, which i dont have, help
If the password it's requesting is the BIOS password then there's not way around it. You may be able to reflash the BIOS via a program downloaded from ASUS but there's not guarantee.
If the password is Windows, the easiest way around it is to reformat the hard drive and re-install a fresh copy of windows.
Sep 01, 2009 | ASUS Eee 4G Notebook
Forgot password ,cant log into windows can that be bypassed
well u need to get out the CMOS battrey from the computer and it get it back in.U will find it on the mother board.
If u dont want to play with the hardware,u can do a recovery on the computer.
Jun 21, 2009 | Dell Latitude C840 24X CD-R W/ DVD Combo...
I cant log in my friendster account
be sure to copy the code in your email and paste it to the password in friendster..
May 30, 2009 | Ahead Software Nero 6.0 (60045) for PC
HP Compaq nc6000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
