Question about Sony Handycam CCD-TRV57 Camcorder
Voice records but no picture...
Of course it happens when you least need it to! There's no picture at all but the tape is moving. Thank you for any help.
  • CinC Apr 27, 2008
    will try that and let you know. thank you!
  • 186 Answers
My best guess would be that the video head needs cleaning. Check with your local Radio Shack or video store for a video cleaning tape.
Posted on Apr 27, 2008
Hello may be you try to say what type of tapes used your unit, if yes it is a micro cassette size see link for some available for your unit.
May 02, 2014 | Craig Electronics Craig Micro Cassette...
Wont record,tape gets bunched up....sounds like it working but will not record
please check rubber roller on the top side of tape that keeps it moving,that need to be replaced
Dec 10, 2011 | Radio Shack MICRO44 (184320 MB 3 Hours)...
How do I erase tapes
to erase tapes all you need to do is record over the stuff already recorded on the tape. There isn't any easy method to simply erase a cassette tape, unless you have access to a strong electro magnet
Jan 13, 2011 | Philips Pocket Memo 281 Handheld Cassette...
The unit is eating up the tape!
Generally speaking, there are two reasons this happens.
[1] tape recorders have to move tape past the record/playback heads at a highly consistent and accurate rate of speed. What makes this possible is a rubber "pinch" or pressure roller and a spinning metal spindle. Tape is routed between the roller and the spindle, and when the recorder is in RECORD or PLAY mode, the roller presses the tape against the spinning spindle, causing the tape to move from the feed reel to the takeup reel. When the pinch roller and/or the spindle become coated with oxide particles shed from old tapes, they get sticky and the thin tape will begin wrapping around one or the other. THE SOLUTION is to get some cotton swabs and rubbing alcohol and clean the oxide (brown from cheap tapes and dark gray from better tapes) from both of these parts.
[2] many tape recorders use rubber belts and pulleys to turn the feed reel and the takeup reel. If the tiny rubber belt that makes the take-up reel turn is stretched, it will not wind moving tape fast enough, which causes tape to bunch up. If this is the problem (you will not be able to see the belts without removing the recorder's outer case), then you might as well junk the recorder.
If you see that the part of the rubber drive roller that contacts the moving tape has a ring of brown or gray coating on it, you
Feb 19, 2010 | Sony TCS-580V Handheld Cassette Voice...
I cannot erase a tape
Audio cassette tapes are not erasable.
You must record over the recorded portion or side of the tape you want to delete. You can of course record silence if you want a "clean" or "new" tape (turn the volume all the way down and then press the record button).
I found that I could do very fast with some recorders by pressing the record button and simultaneously pressing fast forward.
Oct 25, 2009 | Olympus Pearlcorder S701 Handheld Cassette...
DVD Player/Video Cassette Recorder
Hi It sounds like possibly there is stray RF getting into your video signal from your DVD/VCR combo to your tv. Check that your cables are ok, but also, if you can, try moving the unit in relation to the tv, if it is underneath, try putting it on top or beside the tv, I've seen the effect you describe be cause by lack of sheilding in both the tv and DVD/VCR, and moving the unit could cure it. Good Luck!
Apr 02, 2007 | Sanyo VWM-900 VHS VCR
There is no voice when I replayed the camcorders
What happens to the audio when you play the tape in another machine? Does it still drop out? Check the tape visually when it has no sound and see if the edge of the tape is creased. Also is the picture OK when the sound goes off. Does it jump around ans lose sync. If it does it means that the tape is mistracking. It's possible for the tape guides to go out of alignment but usually this is accompanied by picture breakup too. If you've never done it before don't attempt to realign the guides youself, you can really put it out of alighnment and it will damage the tape. Is the microphone built in or removeable? if it's the latter then check the connections and make sure nothing's broken. If there's a switch to go from internal mic to external mic see if it's switched to the proper position, it could be half way between internal and external. I'm opting for a tape problem, Either way a trip to a repair shop may be the best bet. BMW
Jun 02, 2006 | Sony Handycam DCR-TRV22 Mini DV Digital...
Sony Handycam CCD-TRV57 Camcorder Logo
50 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
