Question about Troy Garden
6.75 HP 190CC lawnmower.cuts out. checked air filter.is there an internal fuel filter to it? and is there anyplace to find pics to locateit to fix it or replace it?
  • 100 Answers
What sort of engine is it?? does it have carby below fuel tank or sitting on fuel tank?
Posted on Aug 14, 2010
How can i fix my slow running lawnmower
Sounds like the air/fuel mix is off.. there should be a adjustment screw on the side of the carburator use a screw driver and turn it slowly one way or the other till it starts running right
Jun 22, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Lawnmower looses power. Sounds like it is running on one cylinder. Have changed spark plugs, air filter, gas filter, drain gas, pulled fuel cylinoid from bottom of carbarator and drained. Replaced and...
Hi, first check the oil. If it smells like fuel, change the oil. Secondly if oil smells ok, check the valve clearances and adjust if incorrect. Let me know if the oil smells like fuel and I will help with a fix to stop it happening again. Regards Phil.
Aug 05, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
Where is the carburetor on the Craftsman 675 Series 190cc 22" cut self-propelled lawn mower?
The carburetor would be located BEHIND the air filter housing and air inlet tube. The air filter housing should have a removable (by screw or clip) cover.
Apr 13, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
I have a new 650 sears craftsman self propelled 22" lawnmower that will not start. I have gone through the prime bulb instructions, still no luck.\r\nAny ideas? Walter in Alberta Canada.
could be the priming bulb gasket between the air-filter assy. and the carb.
I have the same lawnmower and if I prime with gas from a can it will start but stop after a few seconds. When I push the bulb I can hear air leaking in this area. You can replace the gasket by removing the back half of the air-filter assembly. I am looking to buy a gasket today I let you know how it works out! Thanks Ron
Oct 24, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Lawnmower starts but cuts off every time i start it
It is not getting fuel or air. Depending which engine it has on it, the carburetor jet may be clogged or a carburetor diaphragm needs to be replaced.
Check spark plug; Air filter; fresh fuel; and of course make sure the engine has oil in it.
Sep 28, 2009 | Craftsman Garden
6.5 hp push mower, not self propelled, starts and shuts off a second later.
sounds like a carb problem try to clean the air filter and replace the plug also remove fuel bowl nut on bottom and see if fuel is gettting into the bowl most of the time its a sticking needle and seat or a bad float or clogged carb/ports? you can also just go to your local lawnmower shop for like $75 they can rebuild it ?
Aug 29, 2009 | Garden
Fix scott bonnar lawnmower Prisma 37 model
Start by replacing the fuel filter and connecting hose at the leak point. It is important to use "fuel hose" and fuel hose clips - which are different to standard hose clamps.
If you have problems with mice - use a steel braided fuel hose - as they can't chew through these ! -
http://www.vehicle-wiring-products.eu/VWP-onlinestore/hoses/hoses.php
May 14, 2009 | THQ The Lawnmower Man
Petrol lawnmower cutting out.
try changing the spark plug. if that doesnt work check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal.
Aug 29, 2008 | Garden
Garden Logo
143 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
