Question about Pioneer AVHP7490DVD Car DVD Player
Meu dvd automotivo pioneer mod:AVH-P7490 não esta recebendo comando do controle remoto obs: o controle esta funcionando normalmente. o que pode ter causado esse problema?desde ja agradeço.
  • 91 Answers
SOURCE: pioneer AVH-P5000DVD
I had the same problem, you will only be able to play DVD's from your region.
Posted on Jun 17, 2008
ward_knutson
  • 64 Answers
SOURCE: pioneer AVH-P5700 instalation
You can find a wiring diagram for your 87 monte at http://www.modifiedlife.com/1987-chevrolet-monte-carlo-car-audio-wiring-schematic/ You can refer to the installation manual for your deck at http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF Since you are removing a shaft style radio and installing a DIN style you will need to perform extensive modifications to your dash. The Pioneer manual provides the dimensions.
Posted on Nov 25, 2008
dj x
  • 61 Answers
SOURCE: watch a dvd while driving pioneer AVH-P4000 DVD
Hi Dave
No ....go to a hardware store buy a toggle switch than get a single speaker wire (small wire) attach it to the red wire on the back of your pioneer deck (make sure to leave the red wire in back of deck as well) and attach it to the power on the toggle switch do the same with the black wire (ground wire) the black wire will go into the toggle switch under the power wire. finally install the parking break wire from the pioneer unit to the last slot on toggle switch and this should do the trick if not swap the ground spot for the brake spot on toggle switch >>>> MAKE SURE THE TOGGEL SWITCH HAS 3 HOOK UPS to do this correctly (your system will provide sound with the toggle switch off (Blue Screen) but when toggle switch is on you get video while driving) good luck
Posted on Mar 04, 2009
  • 3 Answers
SOURCE: problem wirings for Pioneer AVH-P6500DVD Car DVD Player
very easy fix. you can pay thirty bucks on ebay and buy the bypass kit or make it yourself. but the light green wire on the harness has to be hooked up to ground. just hook the light green wire to the chassie of the car and you will be able to see dvds all the time. If you want to buy the kit its not really needed I have a toggle switch on mine just for turning it on and off when I am driving. simple as putting a wire from your chassie of the car(Ground) and then the other from the unit(light green wire) to a switch. hooking it up from Supply to Acc on the switch.
Posted on Mar 25, 2009
Ruff_Racer
  • 49 Answers
SOURCE: have a pioneer avh-p3100dvd, how can i make the
YOU NEED TO BUY A SWITCH FROM WALMART($3), 2 OR 3 PRONG, CONNECT THE GREEN(PARKING BRAKE WIRE) TO THE POWER PRONG ON THE SWITCH AND CONNECT A GROUND WIRE FROM THE GROUND PRONG ON THE SWITCH TO ANY PEICE OF METAL ON YOUR DASH...FLICK THE SWITCH TWO OR THREE TIMES AND NOW YOU CAN WATCH VIDEOS WHILE IN MOTION.
Posted on Jun 25, 2009
E8 error message midea ceiling cassette
MEU CASSETE MIDEA DE 36000BTUS ESTA DANDO U CODICO DE ERRO NO DISPLEY QUE E8 O QUE PODE SER?
Jun 07, 2013 | Heating & Cooling
Não sei configurar meu ipaq
we are English web site,
this 1715 is obsolete now, totally.,
ask here at hp, so they can laugh.
the REAL HP is here. post in English. and win.
https://h30434.www3.hp.com/
Aug 15, 2017 | HP iPAQ RZ1715 Pocket PC
NAO CONSIGO USAR MAIS O CONTROLE REMOTO, COM ISSO NAO CONSIGO FINALIZAR O DISCO......QUANDO TENTO USAR O CONTROLE APARECE NO DISPLAY " CHECK REMOTE ". E NAO SAI DESSA.
Há algum tempo o meu Gravador de DVD de mesa Panasonic DMR-E55PL-S vinha apresentando a seguinte mensagem de erro sempre que eu clicava qualquer comando através do controle remoto: CHK REMOTE2 Havia entrado em contato com o técnico da autorizada Panasonic de Niterói e ele ficou devendo-me uma solução. Como possuo outros 3 gravadores de mesa (2 Pioneer e 1 Samsung R121), apesar da contrariedade, não esquentei muito a mufa. Hoje, porém, encasquetei, e resolvi tentar, mais uma vez, resolver a má função. Após "ene" tentativas malogradas pintou o insight: - "Cacildas! Se eu faço tanta pesquisa para dirimir as dúvidas dos companheiros, por que não o faço também, para mim"? Assim, digitei no "gluglu": CHK REMOTE2 Panasonic Entre outras dicas, saquei esta: Question: - "Whenever I press any button on my remote control, I get this error message on the front panel display - CHK REMOTE2" Answer: - "Just hold ENTER and press the number indicated on the display for a few seconds, and it will fix the issue". Basta clicar ENTER e pressionar o numero indicado no display do painel frontal do gravador por alguns segundos - isto resolverá o problema. (Clicar ENTER e pressionar o número 2 no controle remoto). Tal dica serviu para o meu DMR-E55PL-S como também para o DMR-E85HS - do **** "flashcode" - devendo servir para outros modelos Panasonic da mesma linha. Soçarba... Mr. Walker
Aug 25, 2010 | Panasonic DMR-E55 DVD Recorder
Ya no funciona el control remoto del tv 37LG30
Necesitarias que cambiar el circuito que recibe los comandos del control remoto;
Abre el enlace y ahi encontraras la parte que necesitas:
https://www.tvparts.ca/tvdetail.php?id=6393
Dec 27, 2017 | LG 37LG30 37 in. LCD HDTV
No sound on my laptop but when i plug in head phone i can hear
Oiie; meu computador também está sem dispositivo de som!
quando eu tento reproduzir alguma música no media player aparece a seguinte mensagem : ' Não é possível executar o arquivo porque há um problema com o dispositivo de som.Ele pode estar sendo usado por outro programa, pode não estar funcionando corretamente ou talvez não haja um dispositivo de som instalado no computador. 'foi_ruim.gif
O computador também não reproduz nenhum outro som.Eu formatei meu computador recentemente e acho que foi esse o problema .fiquei_triste.gif
poor favoor mee ajuudeem.! Meu msn é isalove.css@hotmail.com , caso prefiram. Obrigadaa desde jáa ;D rindo_ate_agora.gif
Apr 15, 2009 | Intel ESS ES1868F Sound Card
En la pantalla aparece set 1 no funciona el control remoto
Presionar ENTER y el boton numerado 1 (por SET 1, 2 por SET 2, 3 por SET 3) por mas de dos segundos.
Mar 02, 2009 | Panasonic DMRES15 DVD Recorder
No lee el disco de dvd
If you wish to get some details; visit the site linked here. Pull up older posts.
May 21, 2017 | Daewoo DVG-8500N DVD Player
Ayuda
Sabes que pasa esta anulada porque quedo pegada la funcion de los ajuste en la pantalla.
Pero esa es la clave de la solucion.
Cuando estes viendo los valores esos que no conoces hay un comando en el control remoto que sirve para ajustar, o cambiar esos valores generalmente es (ADJ) pero en tu remoto no se cual es, fijate que debe haber una tecla que te haga salir de ese menu que es el que estas viendo.
Puede ser o la misma tecla MENU, o la tecla ENTER o la tecla de los canales < > o la del volumen, la que ajusta esos valores, y asi como hay una que los ajusta hay una que te saca de ahi.
Lo unico que tenes que hacer es tratar de salir de ese menu fijandote cual boton te saca.
Ese es todo el problema
Proba de nuevo
Cuando apretas la tecla de volumen
Oct 19, 2008 | Air Tools & Compressors
CONFIGURA??O DE SOM
SALUT I WANT A DRIVER FOR MODEM HUAWEI MOBILE CONNECT MERCI
Jul 14, 2008 | Computers & Internet
Pioneer AVHP7490DVD Car DVD Player Logo
179 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
