Question about Midland WR-100 Weather/RDS Radio
Our radio has never sounded an alert. It is programmed for Wabash County, Indiana, code 018169, and is plugged into an outlet. It has no batteries in it. Does it require batteries to work? The Weather/Snooze button works OK. We've had severe storms in our area, but the radio has never sounded an alert. Please help. Thank you!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 164 Answers
The answer to your first question is no, but the company that made this product and even I suggest that you put 3 AA batteries in the radio for back-up just in case you have a power outage. Maybe you had a power outage and that's why it didn't sound an alert. The possible answer to your second question is that it the storm itself may have not been severe enough for the NWS to issue a severe storm. You should check these websites for more information- http://www.crh.noaa.gov/lsx/?n=nwrfaq & http://www.weather.gov/nwr/nwrwarn.htm. FAQ #10 on the first website listed should give a clarification to you problem. They have certain criterias for issuing a warning and sounding an alert. The second website should give you a clarification on when the NWS sounds an alarm.
Posted on Sep 20, 2010
Fips codes
FIPS are 5 digit codes..the 1st two codes are for the state: the last three are for the county. This link allows you to find both state and county for your area: http://www.epa.gov/enviro/html/codes/state.html
Apr 21, 2013 | Midland Radio Midland WR11 Desktop Alarm...
Tip
How To Program Your Radio To Send You Alerts To Only Your County
To cause less confusion when getting alerts on your radio, you should program your radio to send you alerts to your county only. To do this, press the MENU button and press the up button until you see "SAME SET" on your screen, then press SELECT. Make sure your screen is presenting "SINGLE"; if it's not, use your UP or DOWN arrow until you see "SINGLE" presented on your screen, then prees SELECT. Next you will see "SAME 01" presented on your screen, press SELECT and type in the S.A.M.E. code for your county (if you do not know the S.A.M.E. code for your county, go to this website- http://www.nws.noaa.gov/nwr/indexnw.htm, choose your state and find your county in the listings. Make sure your S.A.M.E code matches the frequency channel of your area as well.). When you are finish with that, press the MENU button four times to exit out.
on Nov 08, 2010 | Midland WR-100 Weather/RDS Radio
My midland wr100 is going off for the wrong county, sometimes not for a county that isn't even programmed!!!
Press the menu button once until you see "TIME", press the up arrow until you see "SAME SET", press select, you should have "SINGLE" selected if you are only wanting to get alarms on one SAME code. Press "SELECT" the screen should go to SAME 01, press select again and confirm that you have the correct SAME code entered. "MULTIPLE" will allow for more than one SAME code to alert and "ANY" will set the unit off for any SAME code alert.
Oct 17, 2012 | Midland WR-100 Weather/RDS Radio
How do you program your local weather county codes?
This radio doesn't have the facility to be programmed for your local weather county code.
When set to alert it will pickup on the strongest alert signal in your area.
May 05, 2011 | Eton Solarlink FR600 AMFMWeatherSW Radio
Why does my weather radio just beep, no voice, no lights? I have put in all codes for my county
Good morning, afternoon, evening or night; whatever time of day you are viewing this. You want to know why your weather radio just beeps and no voice or lights function properly. This has nothing to do with the codes you put in for your county. This has to do was the type of alert setting that is programmed into the radio. The alert setting that you have programmed into the radio is probably that TONE alert type. When this is selected, the alert will sound for 5 minutes or until any button is pressed except for the Weather/Snooze button. If you want your alert type settings changed, press MENU and use the up and down directional buttons until "ALT TYPE" is displayed on the screen. Use those same directional buttons to choose the alert type of your choice. If you choose DISPLAY, a text alert will scroll on your screen and no audio alert type will be sounded. If VOICE is selected, an alert will be sounded 8 seconds and you will hear the voice of the weather broadcaster for 5 minutes. These are the only other alert types you can choose other than TONE. Once you have chosen your alert type, press SELECT and and press MENU to exit. Remember that the NWS will only alert you if the storm meets their serve weather criteria (meaning the storm has to be able to cause a certain amount of damage or life threatening to "Wake someone up in the middle of the night"). With this radio functioning properly, it can really help you out in the long run by alerting you with the lastest information of what's going on in your area. Thank you for choosing FixYa as your one-stop solution spot for your problems and thank you for reading my solution.I hope this is the solution to your problem and it clears up any confusion you may have. Have a good morning, afternoon, evening or night; whatever time of day you're reading this.
Apr 04, 2011 | Midland Weather/Hazard Radio with SAME...
My Midland Weather Radio is alerting on central Florida Counties when I live on the nature coast (Citrus County). Do I have to prgram in my ZIP for it to know where I reside?
You have to program what is called a "SAME" code specific to your county. These weather radio SAME codes are available from the National Weather Service website. Look up your state, then your county - it will give you the 6 digit code for your country, AND what frequency if closest to you as well. You will want to delete the unused counties, which is the whole idea behind these radios - program ONLY the one or two counties CLOSEST to you. There is also a phone number for these codes. You can also email you local NWS office on their website for assistance. The 6 digit code made up of a 3 digit number for your state and the 3 digit number for your county, making it specific to your location. Let me know if you need more info. Regards.
Apr 17, 2009 | Audio Players & Recorders
How to program for just your county
Hit Menu Push up to Same set and click select then select single type in your code found on midland.com under that model and find county code then click your state followed by finding your county
Mar 29, 2009 | Midland Weather/Hazard Radio with SAME...
Program county weather code
Sorry, but your radio does not have that feature, which is known as S.A.M.E. When set on ALERT your radio will receive all alert messages broadcast by the NOAA station that you are tuned to. The only fix, unfortunately, is to purchase a set that has the S.A.M.E. feature.
Bill B.
San Antonio
Mar 28, 2009 | Eton FR400 Radio
Not receiving alerts anymore...
My wr-100 came with a special note inserted with the instructions that the WR-100 was programmed to not give off an audible alert on tests. This is to supposedly protect you from thinking you have a real emergency. Mine is new. Maybe the older ones had an audible test alert. I assume yours gave an alert at one time??
Feb 06, 2007 | Midland WR-100 Weather/RDS Radio
Midland WR-100 Weather/RDS Radio Logo
203 people viewed this question
Top Midland Audio Players & Recorders Experts
Van Allen II
Van Allen II
xxxxxx xxx
Are you a Midland Audio Player and Recorder Expert? Answer questions, earn points and help others
