Question about GPX ML648B MP3 Player
My digital audio player starts playing a song for about 5 seconds and than saying BYE. can anyone help me fix this problem? thank you.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 96 Answers
You may have a problem holding a charge. If you've tried charging the device and it still does this you may have a faulty battery or a faulty charging cord. Sorry.
Posted on Aug 31, 2010
My Sylvania MP3 player only plays the first 10 seconds of a song
this is actaully a feature called intro, go into the repeat menu and select normal, you get there by clicking mode while a song is playing. this should fix it. hope this helps
Nov 13, 2009 | Sylvania Audio Players & Recorders
Jump to the other song
The problem is that your MP3 player has selected INTRO. This will play an introduction of every song in your folder. To FIX this simply
1. Play a Song
2. Press MODE (button on the left bottom side)
3. Select PLAY MODE
4. Select NORMAL
Problem solved!!
I had this same problem when I first got mine, I really freaked but a couple hours of fiddling around brought me a solution. Hope this helped.
Jul 11, 2009 | GPX ML648B MP3 Player
Mp3 plays few seconds of song.
Do you mean it plays a few seconds then skips onto the next song? If that is the case then most likely you have "Intro" play set which only plays a few seconds as a introduction then skips to the next time.
To fix this, during music playback, press the [menu] button, then there should be an option there to change it from "Intro" to "NORMAL" instead.
Hope that helps.
May 18, 2009 | Konaki MP4-NS MP3 Player
Song starts to play and then stops and says format error
Try reformatting the drive first. If this doesn't work then you will need to reset.
To Reset, put the slider into the locked position and then press a pin into the reset button on the back of the player.
If none of this works, return it to the store you bought it from.
Mar 27, 2009 | Element Electronics Zr-Element Digital...
I have a Element Mp3 2GB While a song starts its 17 seconds it goes to the next one and keeps going also sometime it turns off
In the Menu Where it says "Repeat" I was activated to play the intro only of a song I now fixed it but thanks tho!!
Dec 01, 2008 | Audio Players & Recorders
ONLY PLAYS PART OF SONG
enter you menu and turn off review. Review plays 5 or 10 sec of every song on your player if its turned on. Trun it to normal and you should be ok....
Rate this solution if it helps.. Thank You...
Nov 03, 2008 | Nextar MA933A MP3 Player
Can't get my 3847 to play
Hi Debbie!
Had same problem. The hold button on the side is not for POWER. To turn ON simply hold down on the play button, but you must make sure the hold button on the left side of the player is in the OFF position first. All the button on the left is for is to hold your song while it is playing so it does get paused or changed.
To turn your player OFF do the same thing, just hold down on the play button it will say stop first and then bye. Again make sure your hold button is in the OFF position.
Hope this helps!
Oct 22, 2008 | GPX MW-3847 MP3 Player
Can't turn off
You have to hold the button in for about 5-7 seconds, and then it will say "Bye" and shut off normally.  If it won't shut off because it has frozem, then reset the device. If it continues to freeze, run a "Repair" in the Philips Device Manager: Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Sep 13, 2008 | Philips GoGear SA3125/37 MP3 Player
Sansa Shaker
Hello Cindy im KBFC id like to say that your not doing anything wrong. see i also have a sansa shaker and what i can say to you that it dosent always play all the songs in it, simply because they are not supported its quiet dissapointing but the sansa dose play most mp3`s put into it. i dont know if its a long time scince you have posted this letter but if its not too late mabyee you can still take it back in exchange for something else. HOPE I SOLVED YOUR PROBLEM BYE!
Jul 02, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Ringing sound when playing music
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 22, 2007 | SanDisk Sansa e260 MP3 Player
GPX ML648B  MP3 Player Logo
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
