En un tv panasonic modelo ct-20g8g que valor tiene la resistencia R-804
romsky79
  • 822 Answers
SOURCE: buenas noches soy propietaria de un LCD marca
thanks! but i can't understand your language. please email me at romsky79@yahoo.com
Posted on Sep 01, 2009
  • 11800 Answers
SOURCE: mi televisor es un Plasma
You need to do a new full scan: press Menu, select Setup, select Program CH,in there go into Input setup and select antenna and then Select Auto Scan.
Full user manual
http://service.us.panasonic.com/OPERMANPDF/TH37PX25.pdf
Posted on Oct 28, 2010
walesarumi
  • 6993 Answers
SOURCE: Tengo Un televisor de 27
please can you rephrase this question in English?
I look forward to your reply.
Bye for now.
Posted on Nov 24, 2010
SOURCE: tengo un plasma sanyo 50
Amigo yo tengo el mismo problema con el mismo plasma..y no encuentro solucion...Tu ya pudiste arreglarala?? Ojala pudieras decirme como lo resolviste o cualquier info al respecto...gracias.
Posted on Feb 23, 2011
  • 11800 Answers
SOURCE: mi televisor comenso con
A wavy line and a partial image are a sign that at least the convergence board has failed. The fact that now the entire image has failed means that the video board has failed also. This signals a very severe failure in the tv, most likely it all started with the failure of the power source.
Open the tv and first check that the capacitors on the power source are intact - follow this
http://www.youtube.com/watch?v=YCSNWi3UHf4
Then check that the voltages that should be delivered by the power source are there - measure them. Then repair the convergence board with this kit
http://www.tvrepairkits.com/xcart/product.php?productid=21850&cat=2749&page=1
and then test the rest of the tv with the repaired board in place to determine what else has failed : check the video final board and the tubes - measure the voltages on the tubes and the final video transistors.
Posted on Aug 12, 2011
Necesito programar el control remoto dish modelo 175544 20.0 IR a un tv LG
Hola, para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor comuniquese conmigo a: kimberly.escobar@dish.com
Kimberly Escobar
Social Media Representative
DISH L.L. C
Aug 26, 2013 | DISH Network IR Remote Control
NECESITO EL CODIGO DE UN TELEVISOR SANYO CON UN CONTROL REMOTO DE JVC
These are the codes for Sanyo TV: 0049 0097 0110 0004 0268 0012 0108 0180
Aug 19, 2012 | RCA Universal Remote Control
Como combertir el coyote hunter a 11 metros
  1. Quite la cubierta superior de la unidad y busque las resistencias en la parte inferior de la tarjeta principal
  2. Desoldar, y saque a los que es.
  • Si usted tiene el modelo más nuevo con los Mosfet en que el uso esta conversión
  1. Quite la cubierta superior de la unidad y busque la fila de 15 pines en la parte delantera de la unidad. Desoldar el cable de tiro corto desde el 7. clavijas a los pines 11 y 12 (conectados entre si).
  2. Desoldar el puente de soldadura cortocircuito de los pines 11 y 12 de modo que son pernos independientes sin relacion entre ellos
Un cordial saludo, Tony
Apr 26, 2011 | Connex 3300 240-Channels Base CB Radio
Necesito saver el valor de las resistencias R1013 y R1014 gracias
He needs schematic info about the values of the resistors, R1013 and R1014
I cant find a schematic for this amp. Anybody have one?
Sorry not a solution but might help.
Mar 19, 2011 | MTX Thunder 5-Channel Amplifier 895 Car...
Nececito el valor de la resistencia r5 ya que ésta se encuentra quemada y el teléfono no enciende gracias julio e-mail jucelfo@yahoo.com
necesito el valor de la resistencia r5 ya que ?sta se encuentra quemada y el tel?fono no enciende gracias flora e-mail: facy5@yahoo.es
Oct 07, 2010 | GE 26928GE1 Cordless Phone
Tengo un tv que tiene la falla en la convergencia de colores
Hola, gracias por visitatar fix ya.
Mira, tienes un fusible abierto, que no te permite entrar a los ajustes.
A un lado del fly back hay tres pastillitas colo cafe ( fusibles), el de enmedio es el que tienes que cambiar (400ma), pero tienes que resoldar toda el area del fly back, por que ahi tienes falsos o loose connections.
Si tienes alguna pregunta, aqui estare.
Gracias.
Jul 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No enciende el tv y una resistencia no se el valor de ella
la resistencia es 112-1124 maxima los valores se depende al parte y numero de control tombien esta telivision tiene una marca de modlo por favor mandame los datos gracias,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 30, 2009 | Televison & Video
Green pantalla
Checa las resistencias que tiene el conector de la pantalla probablemente una esta reventada
Oct 02, 2008 | Insignia IS 20" TV040919 TV
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
Noggin
Cual es el numero de chassis?
Me parece que la r414 esta conectada al yugo y su valor es de 0.18 ohmios y 2 watt y el dz402 es un zener de 5.6 voltios.
Si la resistencia se esta quemando es posible que hay un corto circuito en el yugo.
Jan 31, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
