Question about ASUS Computers & Internet
Cpu overheating on asus x50vl laptop. Do you have
Cpu overheating on asus x50vl laptop. Do you have any disassembly instructions on your site or any service manuals?
  • 6 Answers
SOURCE: NEED TOSHIBA 2400 SERVICE MANUAL OR DISASSEMBLY INSTRUCTIONS
Hello you can tye following url. http://repair4laptop.org/disassembly_toshiba.html Try it.
Posted on Jun 29, 2007
SOURCE: Manual for disassembling
I got mine open in under 30 minutes. It's really pretty easy. I don't know how far you got, but there's only a few tricks here. Take the hard drive, CD drive, and battery out, first. There are four screws hidden by the battery. Then also, you have to unscrew and remove the heatsink/fan assembly before you can get the mobo out, so you have to remove the large panel on the bottom. Finally, once you remove the heatsink/fan and all the screws holding the mobo to the bottom of the case, it may still feel stuck. You have to wiggle the audiojack ports out first, then lift it out minding the wirewire port.
Posted on Feb 24, 2008
  • 21 Answers
SOURCE: CPU Overheating
While I am not familiar with this exact model, (is it a laptop or desktop?), Overheating quite often is a symptom of not just needing a cleaning but of a fan failing, I wish I could tell you what exactly to do to open your unit up to clean it... When you do AVOID using any canned or compressed air on the cooling fans, as this will spin them up to speeds far faster than they are designed for, and if they are failing this can take them over the edge.
Posted on Apr 13, 2009
drcspy
  • 10 Answers
SOURCE: Disassembly manaul
the a8tC manual stuff is here: http://www.asus.com/product.aspx?P_ID=dfauiID9501E0QiZ&content=download and the a8tM stuff is here: http://www.asus.com/product.aspx?P_ID=slXo9M85Yb6PbADX&content=download
Posted on Sep 03, 2009
  • 17 Answers
SOURCE: Disassembly guide for an ASUS A8J
Here is the disassembly guide for the ASUS A8J:
http://www.mediafire.com/?9utgx3g2gvy
Posted on Apr 13, 2010
Asus u50f where is bios battery located
It's right under the CPU fan. Try this tutorial to get the full disassembly steps
http://www.insidemylaptop.com/how-to-disassemble-asus-ux50v-laptop/
Mar 02, 2015 | ASUS U50F Notebook
Display goes off after few seconds
Possibly you have an overheating GPU or CPU problem. If you can do it, then disassemble the laptop and:
- Clean up everything (use canned air),
- Replace the cooling pad or cooling paste of GPU (if applicable) and CPU,
Reassemble the laptop.
Before you disassemble this laptop, you can check the air inlet, air outlet and the fan, and clean them up using canned air. I hope it solve the problem.
Mar 06, 2014 | Lenovo ThinkPad SL400 Notebook
How do Ifix an overheating problem on a eee 1015pe
The most easy way is to buy a notebook cooler stand. If it's overheating again you must open the case and clean cpu cooler and put some thermoconductor paste on cpu and graphic card.
Nov 17, 2012 | ASUS Eee PC 1015PE
My laptop turns itself off after 5mins
Unit is overheating. Disassemble, clean fan, ducts, and apply new thermal compound to the CPU and GPU. Check Hoosier Newman's Blog 'Getting In Too Deep' for video on doing this or on YouTube for instructions.
Not really technical, but you should have some technical skills disassembling the unit and putting it all back together right.
Apr 09, 2012 | HP Computers & Internet
It restarts itself every after 15minutes
At this time you need to check first the CPU fan if it is spinning to prevent overheating. Some cause of this problem is the RAM check also the RAM or you may remove it and try to turn on if it will provide sound. But specifically this is a CPU problem you need to disassemble the CPU. If the CPU fan is not spinning and faulty already you need to replace it. When you reassemble the unit you need to put a thermal paste between the CPU and the heat sink so that the heat from CPU will absorbed by the heat sink.
Oct 08, 2009 | ASUS P4B266 Motherboard
My asus notebook m6b00 keeps overheating and tunring off why?
Laptop overheating has become a more common problem in recent years as both the CPU chips and the video chips in laptop computers have become more densely packed with transistors, all of which generate heat. With both CPUs and graphic systems generating more heat, laptops can overheat if they are not properly designed or if ventilation and cooling is interfered with. The problem is compounded when manufacturers put desktop components in mobile systems, or when laptop design does not properly provide for laptop cooling under foreseeable normal use of the systems.
Laptop overheating most commonly signals itself by sudden, otherwise unexplained shutdown of an operating computer. If your laptop computer suddenly shuts down for no known reason, there is a high likelihood that the fail safe software in the computer is shutting it down when the computer temperature gets too high. Other signs of overheating notebook computers include constant or excessive fan operation, unexplained memory or operation errors, and inexplicable “blue screens of death.”
The problem often arises when you are using your computer intensively in ways that keep the CPU operating at high capacity and the hard drive and video systems busy as well. Gaming often leads to laptop overheating. Virus scans, compiling software and similar intensive tasks can also bring on the problem. The problem also, not surprisingly, sometimes occurs when the temperatures are high in the setting where the laptop is being used.
The consequences of overheating laptops can be quite serious. Your computer can be damaged, and may end up requiring expensive replacement of major system components, such as motherboards or graphic cards. In addition, medical researchers have reported health issues ranging from sterility to burned genitalia related to use of overheated laptops by fully clothed users.
If you have an overheating laptop and your computer is still under warranty, you should promptly report the problem to the manufacturer and seek their help. Because many manufacturers seem to engage in denial rather than cures with regard to this particular problem, you should also read the information on laptop overheating on this and related sites so you can better understand the causes, the consequences and the possible cures for notebook computer overheating.
Here is the to see some tips on why your laptop is overheating.
www.yboyandrei.com/notips
Aug 08, 2009 | ASUS m6n Notebook
CPU Overheating
Apr 13, 2009 | Computers & Internet
I HAVE P5RD1-VM ASUS BOARD NOW COMPUTER STARTED PROBLEM
several reasons for this.
1:) CPU Overheating.
2:) RAM Overheating.
3:) Motherboard Component Overheating.
4:) FAN not operating correctly.
These are a few things that can shutdown a computer after a few minutes, also viruses/trojans et,c.
can shut off hard-drives. and even instruct the bios to change settings.
Check that the CPU And case fans work correctly.
Mike @ compurepair.
Nov 17, 2008 | ASUS P5RD1-VM Motherboard
Dell Latitude D600
Check that the cpu fan is working. In easynote usually you uncrew a panel at the back of the laptop. If it is not that may be a common system problem, in that case reinstall your system.
Mar 13, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
289 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
