Question about GE GBS18HBR Bottom Freezer Refrigerator
My refrigerator is not cold. There is frost in the freezer and it is running constantly.
  • 525 Answers
Remove form the wall 5inchs, unplug for 30 mins, clean behinnd. let it in that position and plug back.
Posted on Aug 06, 2010
Freezer part are too cold
Why is my freezer too cold? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
The freezer freezes the food rock hard. There is frost throughout the freezer part. Today I noticed a half inch of ice on the bottom of the freezer. I cannot slide out ...
[Appliances] Freezer is too cold? - Home Improvement ' DSLReports ...
www.dslreports.com > ... > Home Improvement
DSLReports
Jul 31, 2014 - 16 posts - ‎12 authors
I'm guessing food won't last as long if it's too cold? ... Freezer is too cold? I get a build-up of ice in some of my frozen items in my freezer. .... If no recent changes, then maybe you are seeing only part of the frost build up. Maybe ...
Freezer to refrigerator vent frozen (1) - YouTube
? 1:30
https://www.youtube.com/watch?v=8g_39UHYeEA
Feb 9, 2012 - Uploaded by Dal4us
Our freezer was getting too cold and refrigerator was not cold. ...Refrigerator Repair - Fresh Food Section Is Not Cooling , Kenmore , Whirlpool ...
Jan 03, 2016 | Whirlpool W8RXNGMBD Universal Silver 17.6...
Tip
Simple thing you can do if the ref is not getting cold enough.
1. Defrost the freezer if you see ice on the inside wall.
This is a very common problem. Before you call a technician do this.
Defrost the freezer completely, and when you put the items back, make sure that the vent are not being blocked. The fan needs to circulate the air inside the freezer to keep it from having frost. Ice build up causes circulation problem which causes the ref and even the freezer to not get cold enough. Since the thermostat senses that it is not getting cold enough the refrigerator runs constantly and producing even more frost. Then the owner turns the refrigerator to coldest setting which actually do not help, or maybe make the problem even worse, all the while running up the electric bill as well. So there you go.
on Feb 18, 2010 | Refrigerators
Freezer fan stays on constantly. temps ok in both sides. will this cost much more electricity and should i really worry about it.
If the freezer fan is running constantly, and things aren't too cold in either section, it means the frig thinks its not cold enough to shut off, so it runs trying to get to the proper temp. you have control set at. Check for any frost buildup on freezers back panel inside freezer. If there is you have a defrost problem.
Oct 01, 2011 | Hotpoint HSS25GFP Side by Side...
Refrigerator not cold, running constantly, freezer was cold but noticed its not as cold. cleaned everything in front, pulled it out and looked at back, no frost on everything, fan is running, not sure if...
This could be cause by several different problems. Here they are. Not enough R-134a freon. Severe frost behind back panel (inside freezer section) Conderser motor not running or running too slow to cool off compressor. Very dirty condenser. Excessive heat wll cause the compressor to over heat and warm up frig. It take about an hour for it to cool off and come back on. if you find out this problem let me know
Mar 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Runs constantly, freezer isn't cold enough, bottom of fridge is freezing
Do you have a heavy frost build up on the back wall of the freezer section toward the bottom. If you do your defrost heater has gone bad and will need to be changed. If you do not have frost build up the other problem would be with the evaporator fan or the main board. Let's hope for heavy frost build up.
Mar 09, 2010 | Hotpoint HSS25GFP Side by Side...
Upright Frigidaire freezer with warning buzzer on constantly
If your'e positive the temp is ok then your freezer cold control may be bad. Slowly turn it toward off. If the compressor doesn't cut off before it gets to off, the control is probably bad. Test it here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 12, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer not freezing properly
You have a manual defrost freezer . Ice build up of over 1/2" can act like insulation on wires . If you have no frost build up , and runs constantly , then compressor or refrigerant leak is the problem . Advise to replace freezer . Only 2 parts on manual defrost freezer...compressor and cold control . Compressor will not run if bad cold control . If you have a leak , very expensive to have repaired .
Jul 10, 2009 | Whirlpool GD2SHGX Refrigerator
Fan running but not keeping cold
check to see if the compressor is running, if not you may need a start kit, (relay,overload) If the compressor is running take the back freezer panel off and check to see if there is a frost pattern, might be out of gas if frost pattern has receeded
Nov 08, 2008 | Whirlpool ET1FHTXM Top Freezer...
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
GE GBS18HBR Bottom Freezer Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
