Question about LG LDS4821 24 in. Built-in Dishwasher
Dishwasher starts and after a while the LE error appears and the diswasher shuts down
  • 4 Answers
Take the front door panel off and check and see if your wires are melted into this black spray on insulation. If they are you need to free them from this mess and check for any broken wires. Make sure your plug is unplugged if you need to fix the wires, cut them and splice them back together. Then insert the bundle into a cut bicycle tube and secure it together. Put the door back on and check it to see if the LE code comes up again. Then call LG and let them know what you found. They act like this is something new and it is not. They need to come up with a better solution. The only true fix is to get rid of the LG and buy a better model.
Posted on Aug 07, 2010
HOW TO FIX LE ERROR CODE ON SAMSUNG DISHWASHER DMR78AHS
An LE error code on your dishwasher stands for "LEaking."
There is, what I call, a drip pan on the bottom that the water is dripping into. Remove your dishwasher and take off the lower the side panels to get a look inside the drip pan. If you have water in there, try to find out where it's coming from.
If there are no signs of water, tip the dishwasher over on its side and remove the plastic panel on the bottom of the dishwasher. Once removed, you can disconnect the connector to the leak sensor (it's mounted upside-down, with 4 wires coming out of it. If I remember right, the wires are blue and red).
Flip the dishwasher back upright and plug it in and see if your LE error code pops back on. If it pops back on, then you have a bad board. If it doesn't, then you either have a leak, or the "fangs" on the leak detector are shorting out, somehow.
Oct 29, 2014 | Samsung Dishwashers
My dishwasher starts, then "LE"
The LE error code indicates a motor error. This can be caused by a foreign object that is jammed in the impeller, a failed pump motor or a bad electronic control board.
Refer to page 26 on this link: Dishwasher/LDS5811_Service_Manual.pdf
I would check your warranty and see how long the motor has a warrany.
Hope this helps; remember to rate and comment this free answer.
Jul 28, 2011 | LG Dishwashers
"LE" Error Code appears on control panel
LE is a motor error Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked. REMEDY Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB.
Sep 24, 2009 | LG 24" Built-In Dishwasher - Black
The clean light is blinking diswasher won't start
Push these buttons in this order High temp wash > Heated dry>High temp wash >Heated dry all the lights will come on and this will reset the board and run it through a short test cycle but more than likely it will come up again,It's a failure in the heating cycle either the heater itself or the turbidity sensor which sits mounted up into the tub right behind the drain pump...hope this helps
Sep 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
I have an LG Diswasher LDS5811BB Bought in 2006
LE is a motor error The Motor is working abnormally.
Aug 29, 2009 | LG Dishwashers
Hi there I have a silver LG dishwasher..I am intermittentleey getting the Code PE. I have take the pump off the exit water pipe and chaeck for blockages etc... there are none. Any ideas?
Please confirm the model number of this LG diswasher.
On recent LG units, the avaiable error codes are: IE OE E1 FE tE LE
The PE code is abnormal. Can you confirm.
I would expect to see the error OE if water is not fully pumped out. Remove the filter from the sump area beneath the bottom rack. Look closely for debris causing a blockage/lock. Please get back to me with your findings and ask more questions as needed.
Jan 25, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
ERROR CODE "LE " ON LG DISWASHER
You should check for that the pump motor turn freely. You will have to remove the sump cover in the bottom of the dishwasher and manually turn the pump impeller. (note: screw holding the impeller on the motor shaft is a left hand thread) There may be an object there or at the cutting blade a bit lower down that is preventing the motor from turning. Motor should turn easily, smoothly, and quietly. There have been issues with magnets in the motor windings cracking, resulting in hard to turn or noisy motors. Also, models produced with serial numbers 501KW_____ to 702KW_____ may have wiring which has become embedded in the door insulation material, softening the wiring insulation, and causing a short to the motor. The fix for that is to replace the wiring harness and outer door liner with one with a different type of insulation. (not much fun to do)
Aug 15, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
LE trouble code
The LE error code can be an indication of several different issues. The most common cause is over-sudsing in the machine. Many times owners experiencing the LE error code are using regular detergent. It is recommended to use a high efficiency or low sudsing detergent. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire, dislodged ball sensor, or if the shipping bolts are removed prior to situating the washer. Good luck!
Sep 13, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
No power light comes on
bone, you probably have a blown thermal fuse that is located on the control board, easy fix. First check your wiring to the diswasher behind the bottom panel. I will attach a photo..Catriver..post back.
Sep 28, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
LG LDS4821 24 in. Built-in Dishwasher Logo
154 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
