Question about Husqvarna Garden
Hi I have a Husqvarna ride-on mower CTH160 which now has a problem. I am in rural France and it's difficult to find an engineer. BAsically the problem is that when you engage the cutting deck by pulling back the control knob on the dashboard, nothing happens. IE the cutters won't engage. The engine runs fine. It was intermittent for a few minutes but now doesn't work at all. I suspect the Clutch Ele EVX80 W/Hard Brake. Any help you could offer me I would be grateful for. Thankyou
    Loyalty:
    Visited the website for 30 consecutive days.
  • Husqvarna Expert
  • 220 Answers
These machines used to use a Noram clutch brake, there are no service parts for these clutches so assumming the cable is pulling the engagement arm on the clutch then the friction plate in the clutch is shot and a new replaement is required.
Posted on Aug 23, 2017
  • 109 Answers
SOURCE: lawn tractor won't stay running if clutch is released.
There is an operator presence switch under the seat...it is more than likely faulty and must be replaced in order for the mower to run right.
Posted on May 03, 2009
  • 246 Answers
SOURCE: I need instructions for the assembly of the cutter deck components etc for this machine.
Hello:
A Breakdown should Assist you in Assembling the Deck Components.
The Following Site Addy has a Breakdown of this Unit. Simply use the Site as if you are Looking for a Part for the Mower and then go to the Breakdown for the Deck.
http://www.partstree.com/parts/
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
  • 16 Answers
SOURCE: my mtd pinto mower engine cuts out when cutters engage - why?
it sounds as if your carb is dirty remove bowl on carb i"ll bet it's it's dirty if so you will need to remove the carb and clean it
Posted on May 30, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 127 Answers
SOURCE: Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
Posted on Jun 30, 2009
Diagram of drive belt for husqvarna rz4623
Hi Willard, The link below is a web page with the diagram for your lawn mower.......CHEERS..
Diagram of drive belt for husqvarna rz4623 Google Search
Apr 17, 2016 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
How do you lock differential?
The locking is automatic:
Husqvarna riding lawn mowers, lawn tractors, garden tractors
www.husqvarna.com/us/products/riding-lawn-mowers/
Husqvarna GroupThe available, electronic or automatic locking rear differential increases ... forHusqvarna lawn and garden tractors, you are ready for every season. ... Why use your ride-on mower only for lawn mowing, when it has the capability to do so much more. ...Kawasaki V-Twin engine; Fast hydrostatic transmission; Cruise control ...
Husqvarna Riding Lawn Mowers YT48XLS CARB
www.husqvarna.com/us/products/.../960430205/
Husqvarna GroupBy using this site, you agree to our use of cookies. Learn more. Got it. Close .... Wedeveloped our LS series yard tractors with the discriminating landowner in mind. Engineered for added ... Automatic locking rear differential increases traction while cutting wet grass or on slopes. ..... WORKING FAST WHILE STAYING SAFE.
Husqvarna Riding Lawn Mowers GT54LS
Dec 06, 2015 | Husqvarna Fast Tractor YTH24V48 48" 24HP...
My cth160 drives ok for about 15minutes and then dies on hill. is this a transmission problem?
Does this unit have hydraulic drive? If so it could be that the oil heats up and then escapes thru worn drum surfaces. I had to replace my whole transmission on my John Deere X300R because it would not go upslope after 211 hrs work. I fitted K66 transmission which needed rebuilding the rear of my machine. If you are not an engineer with complete workshop, lathe mill etc do not attempt this. Buy a mower with a decent warranty and off a company which will honor it!!
Jul 17, 2014 | Husqvarna Garden
Husqvarna YTH 2448 shuts off when I let out clutch or engagae mower blades
Hi, check or replace the switch on the seat, basically its not telling the safety system that you are on the seat. Regards Phil.
Jul 07, 2012 | Husqvarna Garden
I use synthetic oil in my cars and want to know if it is recommended or not in my new YTH2348 riding mower?
Hi, synthetic oil is not recommended in your lawn tractor. The reason for this is its basically too good for the load and conditions your mower engine operates under. Using synthetic oil would lead to your engine glazing the bore and consuming excessive oil. Regards Phil.
May 02, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Need service manual for husqvarna zth6125kaa
Hi and welcome to FixYa, I am Kelly.
You can locate the service manual here for the mower chassis:
http://www.mymowerparts.com/pdf/Husqvarna_Service_Repair_Manuals/W0203003.pdf
For the engine manual I need your engine model number to pass you the repair manual for your Kawasaki or Kohler engine.
Thanks for choosing FixYa,
Kelly
Apr 14, 2011 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Husqvarna GTH2250B riding mower leaking gas tank
Hi there
The tank on that machine is a Husqvarna tank . The part # is 532 15 13-46 and you can get it @ your local Husqvarna dealer. To find a dealer near you just check the link below
http://www.husqvarna.com/us/homeowner/support/dealer-locator/ . About any recall on the tank you probably have to contact Husqvarna direct . Use "contact" on the Husqvarna site .
Hope this help
Sep 03, 2009 | Garden
I need to change the two drive belts on my Husqvarna LT112 garden tractor. My manual is in French and l need an English version. Could you advise where l can download one or obtain it in the post, here in...
IPL, LT 112 (H1236D), 954000392, 1992-06, Ride Mower
IPL, LT 112 (H1236A), 954000191, 1990-11, Ride Mower
It appears you now need to pick a year.
US website search engine wouldn't take lt112 nor lt-112 but it appears it might have taken
lt 112 because I only got the above when entered just 112 and sifted thru 4 wrong choices. The international website had no such shortcomings but did not any english manuals that I could see.
Jun 21, 2009 | Husqvarna Garden
Drive belt
I don't have an answer for you, but Do you have a diagram of the Drive Belt?
Mar 14, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Garden Logo
88 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
