Followup to sherwood receiver problem
Well .. im listening to a beautiful mozart concerto thru the AUX channel of the receiver - i shoot it from my PC ... i'm relieved (shouldn't i be) .... but what does this mean for the DVD and cable sound problem/gone?  thanks so much,TB
  • TomPGB Apr 27, 2008
    i think by "accepting" your first comment i lost your help - is that true?  is it supposed to be $10 per solution? what's a smart way to use the site ... because i'm lost again ...
    Genius:
  • 3,587 Answers
Nope..It just takes time to get through the matrix
that means your amp is fine, and your other inputs are unhappy..
you have a warranty on this beast?
Posted on Apr 27, 2008
Can i play records through my sherwood rd6108 receiver? When i try to play a record i get no sound no matter which channel i use.
Record players require a PHONO input on an amp.
Most amps no longer have this, so you will need to source out a pre-amp for the record player, and then you can plug the record player into the pre-amp and then hook the pre-amp into a tape, DVD or AUX input.
Feb 27, 2011 | Audio Players & Recorders
I have a RD-6108 5.1 Channels receiver that want to connect to my flat tv. Can you help me?
If you consider that a TV is just a lightshow, it's not that complicated...
Composite Video Out to composite video IN on the TV would be the minimalist absolute necessary connection for managing the receiver through On Screen Displays.
Unless you intend to dub video to a VCR or something, there is no reason to bring TV video into the receiver.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sherwood-RD-6108-Receivers-manual/id/516ci958/t/2/
My preference is to send the BEST version of any medium (audio or video) directly from it's original source to the BEST ELECTRONICS that uses it; then send minimalist versions across for convenience and lo-fi watching/listening.
Any self-respecting modern TV has multiple hi-def video inputs, so run the Bluray, DVD, cable box video straight in and run the audio from those devices to the Sherwood.
Fewer expensive cables, no excessive connections to go bad, no unnecessary handling of the material.
I'm pleased to see the manual for this one (and the product's limited video capabilities) don't tempt the user to route everything through it on the way to the TV.
Feb 23, 2011 | Sherwood RD-6108 Receiver
How do I reset the defaults on my Sherwood RD-8108 AV receiver?
I just got a tip from Sherwood tech support on resetting my Sherwood receiver, and it solved my problem perfectly. It's not the same model number but here's what I did: Put the receiver on Standby. Press and hold the Setup button for 3 seconds. When you see the model # on the display, press Enter. The word "Cleared" should show on the display. Hope it works for you also.
Feb 03, 2011 | Sherwood RD-8108 6.1 Channels Receiver
LG 55LH90 TV to Sherwood RD6500 receiver
That's what manuals are for.
Video Out on the receiver goes to Video In on the TV. That's all you really need.
I recmmend you grab any TV-related audio from wherever its source is for the highest fidelity sound (NOT the TV).
Apr 18, 2010 | Sherwood RD-6500 Receiver
Would like to hook up two recievers to push all my speakers comfortably. I have a pioneer vsx d490 and a sherwood rd 6500. How wud i accomplish this?
I think you mean Pioneer VSX-D409.
Since the two receivers are similar and capable of driving everything else in the room, I guess you want to treat one receiver like a basic amp, like for a passive subwoofer, right?
However, still guessing your intent...
The VSX is a basic 5-channel amp (5 x 100w) but only has digital multichannel inputs. It has optical and coaxial digital inputs and an optical digital output.
The Sherwood has coaxial and optical digital inputs and no digital output, but it has analog inputs, so it would be easier to selectively use any or all of its amplifiers, which are about the same as the Pioneer's (gotta read the fine print - Sherwood uses a 6-ohm load instead of 8-ohm to get the numbers).
Choose the one you like to use for the control (master). Run its Sub Out to the other receiver's AUX input using an RCA splitter to feed both input channels. Attach the sub to one set of front speaker terminals. Configure theat receiver for NO SUB so it won't steal LFE from theis channel. Designate the FRONT speakers as Large.
Setup would be tricky because you have to choose a volume setting on the slave amp and stick with it. It might get changed after you set the levels and negate the setup efforts. OTOH, you would have the flexibility to change it independently if desired.
My $.02... If subwoofer power is all you need, why not just get a nice Carver 2-channel amp on eBay (2x100w would suffice), bridge it to 200 watts and blow the house up, figuratively? Then you could redeploy or sell the unused receiver.
Jan 18, 2010 | Sherwood RD-6500 Receiver
Sherwood RVD-9090R Left Rear Channel Failure
its due to your player there is nothing wrong with fuse... don't crack the case...try this just connect M1 & M2 to the aux input of your home theater
May 23, 2009 | Sherwood RVD-9090R
Conecting a mp3 player to receiver?( Sherwood RD-6500)
The front panel jacks are Video 3 according to my manual. Aux is on the back panel.
Jan 31, 2009 | Sherwood RD-6500 Receiver
FM Tuner in Sherwood RX-4105 stopped working
Check your antenna connections. Make sure your FM antenna is hooked up to the FM antenna terminal or jack on your Sherwood receiver. If you have the antenna hooked through the coaxial cable, check your coaxial cable with an ohmmeter for continuity. You can buy a volt-ohm meter as little as $12. Usually bad connection occur between coaxial cable and the the coax cable connectors. If that doesn't solve the problem, then there may be something wrong with your tuner card inside of your Sherwood receiver.
If you receivers display does not change channels or frequencies or AM or FM mode, when you try to change the channel or frequencies, or AM or FM mode, there may be something wrong with the front board of your receiver.
If there is something internally wrong your Sherwood receiver, you need to take it to a qualified technician that can fix it. Do not try to repair it yourself. If you don't know what you're doing, you can do far more damage to that Sherwood receiver to the point that would be very costly to repair.
Before you take your Sherwood receiver to a technician, try to unplug the receiver, and leave it unplugged for several minutes, and then plug it back in. If that doesn't solve the problem, then you need to take your Sherwood to a qualified technician.
Dec 02, 2008 | Sherwood RX-4105 Receiver
No Sound
O1 is the OPTICAL input. C1 is the COAX input. Try pressing the DIGITAL INPUT button to cycle to the analog mode.
Nov 27, 2007 | Sherwood RD-7103 Receiver
Left channel out
probably I would say no. Unless you know how to read a schematic or know how to do certain small static checks on the output devices and the drivers as well as the power suppy feeding these devices.
Apr 05, 2006 | Sherwood RX-4103 Receiver
61 people viewed this question
 Grubhead
Grubhead
