Question about HP Office Equipment & Supplies
Cartreidge problems on hp deskjet printer says missing cartridge despite this latter is well installed on printer
    Genius:
  • 2,785 Answers
If possible plz try with another cartridge
Posted on Aug 06, 2010
HP Deskjet 3050 missing lines when printing
Since the print head(s) are installed into the cartridges themselves, it makes this easier to troubleshoot. First, are all colors affected or just black? You don't say whether or not the cleaning pages and alignment pages are printing properly so I assume they have the same problem. Next, are you using genuine HP cartridges or are these remanufactured/aftermarket units? Non-genuine cartridges are often remanufactured many times over and eventually fail in use. If they are genuine cartridges, and if the problem appears to be only with either the black or the color cartridge, but not both, try another cartridge. New cartridges can be defective. IF that is the case, contacting HP about it should get you credit for a new one. If the problem is related to both cartridges and new ones don't fix the issue, then the problem is in the printer itself and there isn't much you can do about it other than replacement since printers are so inexpensive that repairs are not cost effective.
Sep 30, 2015 | HP Deskjet 3050-J610a
What to do when the carriage of the cartridges HP Deskjet 350 doesn't move?
i think your not using this printer log time...?????
just conform before its working or not after replacing new cartridges it showing this erorr??
if it is not working when you installed new cartridges, your new cartridges fault other wise problem with carriage PCA board
Apr 20, 2014 | HP Deskjet 350 InkJet Printer
The device will miss lines of print when printing a document despite cleaning the cartridges and ensuring all connections are plugged in. Any ideas?
Try this only if nothing else works.
Hold the nozzles of the cartridge in a jet of steam (may be from a kettle). Then hold a soft rubber tube to the nozzles and **** air. This might clear the blocked nozzles.
Best of luck!
Sep 24, 2011 | HP Deskjet D1341 InkJet Printer
HP Deskjet 5550 quit printing red color. Installed new color cartridge HP57. Quit printing red again after 5 pages. Is it a printer problem or cartridge problem?
Have you check your color cartridge if they are properly installed.
Make sure your are not using a refill cartridge.
Replace your tri-color cartridge with original an HP tri-color cartridge.
Aug 26, 2010 | HP DeskJet 5550 InkJet Printer
Not printing although going through the motions!
Are you using the origianl cartridge, Some refilled cartridges may create such problems.
Jan 21, 2010 | HP DeskJet 895cxi InkJet Printer
I can't reset ink level indicator for HP Deskjet F4280
AFTER REFILL PRINTER STAY IN ERROR CARTRIDGE BLINKING
Dec 30, 2009 | HP Office Equipment & Supplies
Install cartridge missing on Deskjet 6940
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
May 27, 2009 | HP Deskjet 6940 InkJet Printer
Changing ink cartridges
hi! there might be two possibilities...
1) the device drivers you have installed is corrupt.. try uninstalling n then installing the drivers
2) if that is not working out then your printer must be having some problem.. you may have to get it serviced.
Oct 15, 2008 | HP DeskJet 990cxi InkJet Printer
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
Light is flashing
check cartridge compatibility first:- HP Deskjet 810c HP15................black cartridge compatibility HP 23 ....................colour cartridge compatibility Issue ---A print cartridge is missing. Solution Install the missing cartridge. Issue --The printer detects a faulty, incompatible, or improperly installed print cartridge. Solution 1. Open the top cover of the printer. 2. Make sure the correct print cartridges are installed. Click here to go to the printer/cartridge compatibility chart. 3. Replace or reinstall the print cartridges. 4. Close the top cover of the printer. Issue ---The print cartridge contacts are dirty and the printer does not recognize the print cartridge. Solution Clean the contact points on the cartridges with a dry, lint-free cloth. 1. Open the top cover of the printer. 2. Remove the print cartridges. 3. Clean the copper-colored contact points on the cartridges with a dry, lint-free cloth. NOTE: Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. 4. Use a dry, lint-free cloth to remove the moisture from the contacts. 5. Insert the cartridges back into the printer. 6. Close the top cover. 7. Try printing again.
Sep 11, 2007 | HP DeskJet 810c InkJet Printer
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
