Question about Amana NGD7200TW Gas Dryer
Dryness sensor not working, how to fix? - Amana NGD7200TW Gas Dryer
Ge profile harmony model number gpgt9360eoww will not sense the dry load. How do I fix this
The dryness sensor may be dirty. Cleaning should get it working again.
Sep 19, 2016 | GE Dryers
Dryer shuts off during cycle
DOES IT START RIGHT AWAY OR ABOUT AN HOUR LATER? IF LATER U MAY HAVE A BAD MOTOR WINDINGS PROBLEM? OR A BAD CYLING THERMOSTAT, MOISTER SENSOR NOT DETECTING DRYNESS OR DETECTING DRYNESS WHEN ITS NOT DRY?
Feb 27, 2015 | Whirlpool LER5636P Electric Dryer
We have a Kenmore 592-89157 drier. The sensor for dryness must have failed. Timed dry still works but not sensor dry. How do I fix this?
have to replace the moister sensor not to difficult a job nor costly, usually located on the inside of the door
Sep 11, 2014 | Kenmore Dryers
Dryers - My Timer is not Advancing
You must have a dryness sensor similar to this9a2ef08.jpg Wet clothes rub the sensor and this chff9524f.jpganges the resistance of the sensor. The dryness board sends power to the motor to move the timer towards the end when no more dampness is detected. 2 things you can do before buying any parts is clean the sensor and yank out the little board next to the timer,clean the contacts and get rid of the corrosion. If you do not have a control board then you need to replace the heating element control klixonc21ad26.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 08, 2010 | Dryers
It won't shut off and the dial won't move on it's own.
Look inside the drum and find the sensors.ccbad47.jpg Give them a good clean with alcohol. They might have something on them preventing the resistance readings from being sent to the dryness board. Next find the small computer board by the time and yank it out. Clean the terminals(might be corroded), with any luck you might not even have to buy a part. How about a manual? I have one that features electronic dryness sensors HERE
Feb 21, 2010 | Dryers
LG Dryer Sensor
The moisture sensor is in the lint filter. Remove 4 screws from inside the drum and you have the sensor attached by 2 wires. On my dryer I disconnected then reconnected these 2 wires, reassembled the lint trap and auto dry works fine again
Sep 27, 2009 | LG DLE2514 Electric Dryer
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
Drying cycle
To start ensure that heating element and fan are working.
The element can be tested reading ohms with a multimeter.
The fan can be tested evengizing it.
If the fan and element are Ok, then test and eventually replace dryness sensor and timer board.
Dryness sensor can be tested using a multimeter.
Jun 21, 2009 | Miele G848I Dishwasher
LG Electric Dryer DLE2515S - dryer timer is stuck on 6 minutes and continues drying until I manually switch off - sensor dryer does not appear to be working either.
OK, test the dryness sensor for its operational value. if the test confirms sensor function, you will need to replace the main PCB board in this case.
Now, if the sensor test reveals a faulty sensor device, simply replace the sensor. In most cases, this iwll be a fualty PCB main and, replacing it will usually fix this issue.
Jun 01, 2009 | LG DLE2515S Gas Dryer
Amana NGD7200TW Gas Dryer Logo
51 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
