Question about HP Pavilion dv9000z Notebook
My computer can not identify a extrnal bluetooth device when inserted, what can Ido?
  • 808 Answers
Update ur bluetooth driver and use reginout regcleaner it will solve ur problem
Posted on Aug 16, 2010
  • 62 Answers
You have to install the driver CD that came alng with the external bluetooth adapter for that to function properly. Insert the CD and complete the installation. Once the installation is complete, insert the Bluetooth device to the USB drive and you will see at the lower right side of your screen showing the status of the driver setup for the device for that particular USB port.
Hope this helps. :)
Posted on Aug 06, 2010
Tip
How do I remove Bluetooth Drivers?
<p>When a new Bluetooth device with your computer, you generally need a driver for the work to install. Once you stop using a Bluetooth device, you may need to uninstall it before it is used by other Bluetooth devices that you still use. Bluetooth drivers and other drivers are removed from the Device Manager that is built into all versions of Windows. <br /> <p><br /> <p>1. Click Start&gt; Run. When the Run text box, type "devmgmt.msc" and click "OK" to open the Device Manager. <br /> <p><br /> <p>2. Scroll through the menu of categories device in Device Manager and find "Bluetooth devices." Expand this category by clicking the "+" sign next to it. <br /> <p><br /> <p>3. Scroll through the list of devices in this category and identify those that you do not plan more. Right-click and choose the first "Uninstall" option in the pop-up. When Windows asks you to confirm the deletion, click "Yes". <br /> <p><br /> <p>4. Repeat step 3 for all other devices with Bluetooth driver you want to delete. When finished, close the Device Manager. <br />
on Jun 26, 2011 | Computers & Internet
Tip
How do I detect a Bluetooth Worm
<p>Bluetooth drivers can safely talk while driving through the network of your mobile phone with GPS devices or other machines, but there is a problem: hackers, worms and viruses were discovered Bluetooth navigation. Now the same security as war ravaged conventional Internet connections is through Bluetooth. A good Bluetooth security means more creative and think ahead of hackers. <br /> <p><br /> <p>1. Make the scan speed. Many scanners Bluetooth device on the market that allows users to find and protect vulnerable Bluetooth connections. Tools like BT Scanner, Audit and sweeping blue BT are among the many options. Find what suits you best for your own research. <br /> <p><br /> <p>2. Learn more about how Bluetooth devices worm priority target. The researchers say the virus finds devices in 'visible to all mode ", and selects the first available. Know the difference between the visible and invisible Bluetooth connections, and how to change them. <br /> <p><br /> <p>3. Select an area and time for a test. Set scanning transmission and environment monitoring. The revised list of devices in range and control their visibility settings: whether yours is vulnerable. Identify problems that would invite hackers and worms, and come up with solutions. <br /> <p><br /> <p>4. Look for data corruption on the device. A more low-tech solution to a worm or hack Bluetooth identifiable data to realize when they are damaged in a single device. It is a sign that something is probably wrong with the software. Especially with cell phones, corrupted data indicates that the device has been compromised. <br />
Install bluetooth peripheral device
Hi, if you haven't tried the Bluetooth ("Wizard") to install the device? Go to the "Start Search" window, Type: Bluetooth, the Icon appear, select to open. In the "Views (column) there will be "Add Wireless Device" and "Bluetooth Settings," add the device to be identified; if not present, and (Setup / Install) the device. Restart the computer when finished! If this did not "fix" the problem?, go back to search: Type: Sony, "if a Sony Application Installer appear in the seach?" select to open, and in the (Bluetooth Device), and restart the computer to finish! " If the solution helped? Rating it is appreciated, thanks."
Feb 28, 2010 | Sony Computers & Internet
I have a Nokia 5800, cant connect ido bc3100 headset
Got it. Press VOLUME +, VOLUME -, and POWER ON, and the blue light turns on, still. then search for it with the phone.
Oct 27, 2009 | Cell Phones
Cannot send from computer to my phone via bluetooth
Have you formatted the memory card? You will be able to do this via the menu and settings. It could be phone is not recognising the card as it is not formatted.
Also look in menu ( iam not too familiar with menu of this phone) for the option to change default save location for files. Some phones have the option to change this. If its set to phone that could be the reason?
Another solution is does your PC have a SD card reader? If you have a Micro SD to SD converter you could insert memory card straight into PC and just drag and drop files. Its a lot quicker than Bluetooth. (be carefull which folders you drop into, as for phone to recognise the files the MP3's & sound files need to be in a 'music folder' - MP4's & 3GP's need to be in 'video folder' and so on.)
Hope that helps?
Apr 27, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Imate jama
just switch on the blutooth of the device and make ur device visible to others in bluetooth settings from where u switch on the bluetooth and then scan from other device from where u want to rec the file and then pair up ur both devices when it ask for code put 0 zero on both devices and then recieve the file there is no need to pair up again next time when u recv file from the same device
pls rate if i fixya problem
Feb 27, 2009 | i-mate JAM Pocket PC
Inability To Activate MOGO
I solved the problem by upgrading the Bluesoleil software I was supplied with (Bluetooth) to the most recent version (at the modest cost of 19 Euros). After I did that, the proper menus came up to search for the mouse device and a connection was established! Of course, the user manual was no help.
Feb 03, 2009 | Newton Power MoGo (MG-100-01-0012-01)...
Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Dec 14, 2007 | Motorola Mobility RAZR V3
Lg prada phone
it only store downloaded or blutoothed files on to the phone's memory
Aug 17, 2007 | LG Prada KE850 Cellular Phone
HP Pavilion dv9000z Notebook Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
