Question about Whirlpool Duet GHW9150P Front Load Washer
My tub has a puddle of water in it, Why? - Whirlpool Duet GHW9150P Front Load Washer
Your tub is not levelled
Posted on Aug 23, 2011
  • matthumplik Aug 23, 2011
    Level the tub so that water drains or wipe the puddle up after each use
Tip
Mildew smell, gray streaks, won't drain, puddles on floor, burnt motor smell
I have had various issues with my fisher paykel top loader (GWL10US) and didn't realize they were all due to a plugged drain. I had mildew smell from excess water that never drained, gray streaks on clothes from dirt and residue that remained in tub, water left in tub and wet clothes after spin cycle, puddles on floor, and finally it wouldn't drain at all and the motor smelled hot/burned out.
This was all caused by a sock that got in between the outer/inner tub and went to the lowest part of the drain and finally blocked things so a leak was created and water dripped into the motor and caused a burn out.
To repair, bail water out of washer and unplug the washer. Tip machine back so you can see the motor/white plastic housing unit (pump) on bottom of washer. Where this unit attaches to the bottom of the washer, look for a clip/tab that you can pull with your finger (like a childproof cap) and twist the unit off the machine and unplug the connectors (there are 2). Once this unit is removed, you will see a quarter-sized hole into the bottom of the wash tub. this is where i found the elusive SOCK and pulled it through the hole.
When you order the "pump" it comes as one unit--motor and white plastic--and you twist it back onto the machine and plug in the connectors.
another website I've found helpful is ths.gardenweb.com/forum/laundry
on Oct 21, 2008 | Fisher and Paykel IWL12 Top Load Washer
My kenmore elite topload washer is leaking underneath washing machine leaving a puddle whats causing this?
depends. first and foremost, I would fill the unit up about halfway with water, with tub being empty of any clothing. Tilt the machine back where you can look underneath it real good. see if you see any leaks with it half full of water. If you don't see any leaks, put the unit back on all fours, and put it into drain/spin. After tub empties of water, tilt unit back again and check for leaks near the drain pump and hose. If you need any further assistance, look for me on 6ya
Nov 27, 2015 | Kenmore Washing Machines
Washer leaks in the spin mode
where are you noticing water is it alot of water or only a little the pumps are pretty known for going bad #3363394 pump usually small puddle dead front center of washer .... aswll as detergent dispensor hoses get plugged that drain into the wash tub
Jan 26, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Small puddle of water underneath washer when wash cycle was completed.
That could be 1 of a couple things.
1) During the agitate cycle... some water could've made it out of tub.
2) Possible Tub Crack (or overflow line)
3) Check your inlet lines
I would run it again watching it very carefully to determine if any of these are the problem.
Dec 02, 2009 | Whirlpool LTE5243D Top Load Stacked...
Puddle appears in washer after clothes have been removed.
This sounds like a check valve for the drain hose has failed. This check valve is in the pump discharge port and prevents water left in the hose from draining back into the tub.
Charlie
Sep 09, 2009 | LG WM2301H Washer
I have a 1.5 yr old Fisher Paykel ecosmart washing machine. During the past 2 loads there has been a notable water leak (significant puddling on the floor). I haven't witnessed the problem, but there is...
the play in the tub in normal, it sounds like you have an over sudsing issue, run an empty load with 3 cups of vinager in the tub, set the water temp to hot, cut way down on soap, if you use liquid dont even fill the cup 1/3 of the way, I know this sounds dumb but try it, I have one and this happened to me
Jul 10, 2009 | Fisher and Paykel Washing Machines
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
