Question about Maytag ZigZagW / B Side by Side Refrigerator
I would like to find the manual for Maytag fridge/freezer model: GZ2626GEKB Please
  • 62 Answers
SOURCE: Fridge not keeping cold
check the controls and make sure they are set properly, so that you are getting air into the ref. also a common thing is that the evap fan motor could be bad and not blowing air into the ref area. it could also be the start of a defrost problem
Posted on Sep 06, 2008
  • 19 Answers
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
Posted on Nov 18, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Freezer and Fridge temperature not very cold
I can find only one good reason why your refrigerator may not be cooling. There is a control board inside the fresh food compartment and no signs of a defrost timer. If there is someone that go through some test to eliminate other possible problems would be good. If the refrigerator is still running, unplug and open the freezer compartment. Remove the back panel so we can have a look at the evaporator coils. Clean or are they frozen with a large piece of ice? Let me know, Thanks Sea Breeze
Posted on Mar 23, 2009
  • 531 Answers
SOURCE: my maytag fridge model number msd2657hes wont cool
you have defrost problem
Posted on Apr 06, 2009
  • 4 Answers
SOURCE: Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Posted on Apr 19, 2009
Good Morning. I have a Maytag F,F model No. GZ2626gekb and I am looking for the 'Tech Sheet' or Service document to run tests to see why the fridge isn't cooling properly. Many thanks. Adrian
Most of the time there is a tech sheet attached to the refrigerator for the maytags. It is usually found by removing the kick plate and is usually taped in a plastic bag to protect it from dirt and debris.
I was able to find a wiring diagram for this model but no tech sheet so there may not be one or maybe I just couldn't find it.
Feb 09, 2018 | Maytag Refrigerators
MY Maytag Fridge Freezer GZ2626GEKB is not working the fan is constanly working and the compressor on works for a couple of seconds before cutting out for about 3 minutes
The first thing to check would be the overload/relay that is plugged to the side of the compressor. You will need to unplug first,remove the the cover plate/board from the bottom rear of the refrigerator (You will need pliers and 1/4'" nut driver). once the cover is removed you will see the round black compressor. The relay/overload is the black box connected to the side, remove it and you may see it has been burn or melted if so replace it and you should be back in business. The new part # for that relay is 67006660.
Dec 24, 2013 | Maytag Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Need find out what is missing from fridge due to buying at auction for a maytag gz2626gekb
there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console....
Click here to download repair guide
Dec 26, 2010 | Microsoft Xbox 360 Console
Hello - came back from holiday and my maytag gz2626gekb had defrosted and all food was lost, we thought that one of us had left the door open by mistake so switched it off at the mains then back on and...
If the entire freezer section had warmed up i would be looking at either the condenser fan motor (located behind fridge in compressor area) or the relay and overload assembly (attached to the compressor) as your most likely suspects.
Usually if the relay and overload fail the compressor simply will not run or you will hear an audible buzz and click sound from the component.
The condenser fan motor should be running whenever the refrigerator is on. If the fan is stalling it will cause the compressor to overheat and shut off.
Now if some of the freezer items were still frozen, you may have a defrost issue causing a restriction in air flow within your unit. Your most likely culprit for this would be the defrost control board located in the refrigerator compartment top right corner above your control housing. Part number 61005988.
Jun 13, 2010 | Maytag ZigZagW / B Side by Side...
The fridge does not seem to be cold.
if just the refrige isnt cold,check the damper door located between the freezer and refrige compartments and see if its open to let in cold air from freezer,if not sometimes they freeze shut and cant operate with temperature setting changes/if nothings cold,then replace the ptc overload relay located on the compressor body,it just unplugs off the compressor
Mar 23, 2010 | Maytag ZigZagW / B Side by Side...
Admiral GC 2027 HNKBS
Hi i had the same problem, if you ring Maytag on 08444990101 they are the uk supplier for admiral fridge freezers. hope this helps
Mar 29, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Mar 23, 2009 | Maytag ZigZagW / B Side by Side...
Maytag ZigZagW / B Side by Side Refrigerator Logo
144 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
