Question about Craftsman Garden
I have a craftsman blower 358.797130 and the pull core broke .i have taken everything apart but can not get the pully off the seal o ring seems to be stoping it help the manual is no help
    President:
  • Craftsman Master
  • 1,545 Answers
Yes, owner operator manuals cover very little in the way of repairs. If you have the unit taken apart down to the starter/recoil unit and you want to replace or rewind the rope on the pulley...it shouldn't have to be removed, unless the starter spring has broken. These units have a cheap starter system that wears easily and causes the problem you have. If you can, preload the spring (before installing the rope ) by turning it several times in the tension direction and then hold it in place and install the rope, Observe how the old rope is looped around the inner core of the starter if you install new rope.
Posted on Aug 08, 2010
Pull cord broke, broke it down, can't get to it??
You will have to take the trimmer apart go to Parts tree Repair Clinic they will have a video
Jul 12, 2014 | Craftsman WeedWacker Gas Trimmer 29cc...
I put reg gas in it & it ran rthen quit now the cord will not pull
Could have scored the rings, broken ring, or just cooked the piston to the sleeve, maybe melted the connecting rod to crank, damaged needle bearings. Most likely needs to be taken apart.
Mar 20, 2014 | Weedeater 25cc Gas Blower ()
How do i change the drive spring on my craftsman 4/21 snowblower
Is that the spring under the plastic hood behind the snow throwing shoot?
Dec 10, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Craftsman Leaf blower with new carb won't start
check the head bolts to make sure they are tight
Dec 16, 2011 | Craftsman Garden
The pull cord on my leaf blower will not re-coil. I have it torn apart but can't figure out what is wrong. Any ideas? Craftsman 32cc 360 cfm gas
How far did you take it apart? It is more than likely just jammed, take a small screw driver and stick it in one of the fins and try to work the pulley back and forth. When you pulled it, it went past the end and pulled the rope back in when it should be pulling it one way now it is pulling it the other way and it is locked. Or the spring is broke. Not likely. Here is a video on it.
http://www.youtube.com/watch?v=zelPN20xVrM
Oct 01, 2010 | Craftsman Garden
Rear Axle Shfat. How To?
C Clips you mean. there is a pin in the middle of the ring gear. this pin must be removed and then you push in on each axle, then the clip may fall out, or you will need to remove it from the end of the axle. then you can pull the axle out. You dont say "why" you are replacing it, replace the axle bearing and seal.
Jun 13, 2010 | 1999 Jeep Grand Cherokee
Firing pin will not return up, but will return when air hose is removed, have taken top of head off and pulled pin out, cleaned everything but still does not work.
There is nothing to see, it won't look broke, it just is. You have to get the kit, replace every o-ring and seal in the gun. Sometimes the trigger is a separate deal, and sometimes that is the one you want. But they are fairly cheap, and they make your gun new again. Hope this helps.
May 21, 2010 | Porter Cable-Cable FN250C 1-inch...
Blower will not start.
Sounds like old or stale fuel stuck the ring. This will reduce compression and prevent the unit from running. The only fix is to fix (unstick) or replace the ring.
I recommend using the pre-packaged fuels to prevent this type of problems.
Mar 24, 2017 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Pull cord stuck in the out position
this can be caused by sevral things inside the pull cord hub assembly. examples: Dirty inside & needs taken apart & cleaned. something logged inside, plastic spool tabs broke, spring/s broke, levers broke or any of these items could just be to worn. replacement parts should be available.
Oct 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Craftsman 2cyl leaf blower wii not start
it sounds like vapor lock, trying giving it a couple pulls with the spark plug taken out
Nov 13, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
258 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Mike Squire
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
