Question about HP OfficeJet G85 All-In-One InkJet Printer
Hp g85 all in one
The plastic strip inside came off. How do I re apply. It is located above the belt.
  • kwhammo Apr 27, 2008
    thanks for the help but, I don't know what the MFP is.
    Scholar:
  • 87 Answers
Replacement of the encoder strip requires a fairly extensive disassembly of the printer. Before you even consider this repair you need to make sure that the encoder strip is not ripped at either end where it would be held in place by......if it is then you will need another encoder strip.
Inkworks
Posted on May 21, 2008
The "plastic strip" is the position encoder of the print head, it holds itself in place by two latches, one is fixed and the other is flexible, you have to put the encoder in the flexible latch first by holding it at an angle and then in the fixed one, probably you'll have to disassemble the MFP to have access and a better view of the parts.
Posted on Apr 27, 2008
  • Anonymous Apr 28, 2008
    MFP is the Multi Function Printer, (The entire printer).
Printer cuts off print at top of page in spite of over 1" margin and every 3rd or fourth line of print in document is very weak (not much ink)
Hello
Well are you using the external ink-system? even if you are not the disk encoder and the encoder strip needs to be cleaned. Encoder Strip is the plastic strip connecting from left to right inside the printer near the belt. In the same type of plastic there is an Disk encoder on the left side of the printer you can find it if you open the printer only.
Jul 23, 2011 | HP OfficeJet Pro k550 Printer
Plastic strip above the printer head
IT IS EASY TO PUT IT BACK AGAIN. HOOKS WILL BE THERE AT TWO ENDS.
Apr 05, 2010 | HP DeskJet 932c InkJet Printer
Officejet G85
For the paper jam you remove the back cover and clean the 4 rubber rollers with alcohol, you can rotate the rollers forward while you clean. For carriage jam you start by cleaning the encoder strip that runs across behind the carriage unit, the clear strip with black bars on it, you can wipe with a Q-tip damp with alcohol. If no help you may need to take apart and clean dried ink off of the service station on the right.
Feb 01, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
Vista driver for hp g85
Uninstall current driver (if any) before installing the new software from HP support: (choose your OS)
HP OfficeJet G85 Downloads
Jan 08, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
How does one replace the keyboard on a HP dv7 notebook?
No obvious screwws to locate, if similar to mine, you should look at the edges, like double glazing securing bars, there are click/push in place plastic strips, small pressure with a thin broad tool, applied beneath joint should release strip to expose small screws allowing you to lift keyboard, be carefull not to disturb other components or drop screws.
Sorry can't more helpful, just be careful.
Nov 12, 2009 | HP Pavilion dv7-1240us Notebook
Calibration strip location
I got my answer from a very helpful scanner expert from a posting on the newsgroup comp.periphs.scanners. The plastic piece went near the end of the bezel that holds the glass above the starting position for the scanning run. Once I knew the idea, locating where it went was easy because of small indentations in the bezel the shape and size of the plastic piece. Thanks.
Aug 07, 2008 | HP Officejet 5610 All-In-One InkJet...
G85
Gears stripped. Due to cost of new gears(parts,shipping, taxes,etc., approximately $50.00) made more since to buy a new updated all in one for $89 on line.
Apr 29, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
G85 printer making horizontal strips
Check the scanner cable and the status of the LED's in the scanning head. Unluckily, you printer is disposable, to HP that problem will mean to discard the entire printer and replace it for a new one if it's still under warranty.
Apr 11, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Hp g85 grinding noise
You may have spitoons full of ink. Check the Officejet G85 thread on fixyourownprinter.com I also refurbish them as a hobby and have spare parts. I can be reached at doctuh at the yahoo.com domain.
Nov 21, 2007 | HP OfficeJet G85 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
639 people viewed this question
Ben Johnson
