Question about Samsung LE40R74BDX 40 in. LCD Television
The words "Digital Noise Filter Off" and "digital Noise Filter On" appear on the top left and right and side of the screen and the words " Auto Visulisation" appear on the bottom of the screen all the time when watching normal T.V.
Press menu. picture options. set digital noise filter to auto. and mpeg noise filter to auto.
Posted on Aug 26, 2010
  • deepakhajari Jan 31, 2011
    It is working for some time only, after some time it is appering again. Need a permant solution.
I always have inacurate focusing of the camera.. is it fixable or its totally damaged?
Your camera has a possibility to change focus mode.
The easy way is Easy shooting, everything should be automatic. When you lower the lens cover, to switch to shooting mode, you can see some words and logos to the left of the screen. On top is just the word HOME. bottom is MENU. Just above menu, it says AUTO or EASY. If not, go there and change it to easy or auto, so the focusing should be compete automatic. If that works, you were not shooting in Automatic. You could check on the right side of the same screen. Top is for flash, middle for focus and bottom for display
If the middle logo is a flower with or without auto or with a magnifying glass, you are not in the Intelligent Auto Adjustment mode. and that explains a lot. If the settings don't change a thing, you have to fear the worst.
But before going to a dealer, check the manual, because there are so many settings, and only with the camera in your hand it is possible to see what is relevant and what not.
Jan 15, 2014 | Sony Cyber-shot DSC-T90 Digital Camera
How to remove Digital noise filter from my samsung lc450 lcd tv
hello, to remove that problem you can use this method;
1. Enter to menu - plug and play - than follow instructions 'til home use and store demo appear.
select home use. or,
2. Push volume button on side of tv until volume bar appear, than push menu button 3-5 second.
good luck.
Mar 27, 2011 | Samsung LE40R74BDX 40 in. LCD Television
What setting do I use to shoot close up (macro) pictures of my items?
1) switch camera to "on"
2) Using the fwd, back etc control switch, located to the right of the screen, set it to "macro"
This is the left hand side of the ring switch. (back arrow). The macro icon (looks like a flower icon)will appear in the viewfinder in the top left hand corner.
3) to cancel macro, press this "back arrow" again.Or switch the camera to off.
Feb 10, 2011 | Fuji FinePix S5000 Digital Camera
How to connect samsung LED LA40C6200 TV Audio to Sony 5.1 DigitalAudio video Receiver which has no Digital Audio connection it has only 5.1 audio connection
Hi gentleman:
I am from IRAN and I have a Samsung TV 6200 LED
Since 3week ago the text (digital noise filter on) was appeared in top right hand and (digital noise filter off) was appeared in top left hand also the text (auto visualization) was appeared in down stream center.
I have tried to clear top mentioned text from menu, but they come again after few minute .it seams our changing isn't saved.
In addition when we watch satellite program we haven't any problem but in TV programs is different.
Your kindly support is greatly appreciated.
Feb 02, 2011 | Samsung Televison & Video
The words "Digital Noise Filter Off" and "digital Noise Filter On" appear on the top left and right and side of the screen and the words " Auto Visulisation" appear on the bottom of the screen all the time when watching normal T.V.(series 5 lcd) and if we make changes regarding in setting in picture option in mode.then after 20-30 min againg it displays same message
Feb 01, 2011 | Samsung LE40R74BDX 40 in. LCD Television
Check in the tv menu look for the OPTION go down look for PROGRAM TITLE DISPLAY to turn it off.
Jan 31, 2011 | Samsung LE40R74BDX 40 in. LCD Television
Turn off flash
With the camera ready to shoot in Auto mode - you will see a little lightening symbol in the top right hand corner of the screen. This indicates the flash is turned on.
On the left side of the circular dial at the back of the camera you will see a similar little lightening symbol indented into the dial. Simply press on this side of the dial to turn the flash on or off as you desire.
The symbol on the screen will go off when you push this to indicate flash is off and return if you press again to turn it on.
Thanks for using FixYa.
Dec 30, 2009 | General Electric A950 Digital Camera
How do I get the date to print on the pictures
To set datestamp to appear on your pictures:
Hit FUNC SET (middle of wheel on back)
Hit Right side of wheel to SELECT the mode you would like to have (Auto, Man, etc)
Hit Bottom of wheel to get to bottom of Left Menu on screen
Hit Right side of wheel to SELECT fifth selection (Postcard 1600x1200)
This is the only mode I have found that supports the date stamp on the Canon Powershot SD600.
P.S. Don't forget to set the correct date and time in the screen MENU under the Tools tab!
Nov 07, 2008 | Canon PowerShot SD600 Digital Camera
When takining photos all the shot recently appear with a blue tinge. Before taking a photo, the screen displays the following; 'P' left hand top right corner. light bulb left hand side and along the bottom...
You are in Program mode most likely, with some sort of white balance setting that is not sunlight. Go into menu and try to change back to auto mode,or reset all or default. Sometimes removing the battery for 12 hours gets it back into default mode. the HQ is just the resolution that it is shooting in.
Apr 22, 2008 | Cameras
Samsung LE40R74BDX 40 in. LCD Television Logo
1,627 people viewed this question
Jerry Greenberg
Jerry Greenberg
