Question about Craftsman 3/8" Pro Air Ratchet Rapid Reverse 19888
I have a rarely used Craftsman 3/8" air ratchet. It runs as soon as it's connected to the air hose and will not stop running when I release the trigger. There's an access hole for the trigger mechanism which contains a spring and a pin but nothing else. Could something be stuck or missing here?
    President:
  • 2,030 Answers
Run some carb cleaner through it an use an air tool oil in it and blow it through good a few times...should free up the trigger vavle
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 06, 2010
  • jeffrey johnson Nov 25, 2011
    You are missing the valve, it is made of polyurethane and has probably disintegrated.Here is the link to the replacementhttp://www.searspartsdirect.com/partsdir...
I bought a used ratchet and it won't spin the air blows out the exhaust what can I do to fix it?
on the end where the socket goes there a fap that swings back and forth when you operate it somethimes it will stick to one side you need to peck it on the side and it will free up and run
Sep 28, 2014 | Craftsman 3/8" Pro Air Ratchet Rapid...
Where do you oil the air ratchet
Put a few drops in the end where the air hose connects every time you use it. Put oil in the air inlet end and squeeze the trigger to force the oil through to lubricate the rotor vanes and bearings. Also do this before you store the ratchet in the drawer so that oil sits in the ratchet protecting the internals when not in use keeping the rust away.
Jan 20, 2013 | Campbell Hausfeld 3/8" Ratchet
3/8 air rachet will not stop spining
The ratchet needs repair. I would check the throttle lever valve inside. Either the spring inside or the valve o-ring are worn out.
Nov 08, 2012 | Craftsman 3/8" Pro Air Ratchet Rapid...
Earthquake 3/8" Air Ratchet will not operate . I left it in my garage. I go back to using. After two months and it doesn't work is never been used. But once.
Did you put a few drops of oil in the air inlet end? Then connect to the air compressor hose. Make sure you have at least 90 ft lbs of air presssure.
Sep 21, 2012 | Campbell Hausfeld 3/8" Ratchet
I have a Craftsman compressor Model # 919-15292 2. The compressor stopped building pressure because air was continually being released through the unloader valve. I have replaced the unloader valve,...
you must have wired the new pressure switch incorrectly .when the pressure switch opens it will release the head pressure so your compressor must be running with the pressure switch contacts open should be 4 connections 2 marked motor which is from your compressor and 2 marked line which is your power coming in
Jun 15, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Craftsman 3/8 inch air rachet model number 875.188020, stuck on as soon as you plug it into the air supply. any ideas on fixing this issue or where to get a diagrahm of this tool.
sounds like the trigger is gooed up from water and **** from the compressor
if you can pull trigger apart and clean it problem probably be resolved
Dec 14, 2010 | Craftsman 3/8" Pro Air Ratchet Rapid...
The compressor turned on pumped up and shut off and wont start up
Inccrease the line pressure to 90 PSI, a air ratchet is a very high volume air tool and the compressor may not be able to keep up with it.
Jul 14, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 Gal. Air Compressor 1 HP Hortiz
Does it run? Does it stop running? Does the pressure gauge read anything at all? Is there a regulator on it? Can you take the reg off? A bunch of things to check, get it running and let me know what you find, and I will try to tell you what's next.
Feb 27, 2010 | Craftsman Air Tools & Compressors
The trigger stop working the ratchet works but i have play with the air hose on and off to use it. i oil it.
sounds as if it needs servicing ,not expensive -----what do you oil it with ? if you dont have the correct oil use auto transmission fluid DONT use wd40 or the likes the o/rings will go in no time
Sep 29, 2009 | Craftsman Mechanics Air Tool Kit Impact...
Craftsman 3/8" Pro Air Ratchet Rapid Reverse 19888 Logo
201 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
