Question about Maytag MGS5775B Gas Kitchen Range
Hi, our broiler is intermittent, it sometimes starts up and then goes out. It sometimes doesen't want to start up at all. The proceedure we use to start it up is we push broiler then autoset. Could you please help.
    Guru:
  • 310 Answers
First check the Broil Ignitor p/n 74007498.
Posted on Aug 06, 2010
I have a 200 1.6 glxi in thailand, have intermittant engine shut down, electrical as all goes off, sometimes instant re start, back fire, and away, otherwise start off the key whilst rolling, i have c
check the battery terminals and posts are shiny clean and tight. Check for loose wires and other terminals that may be dirty or loose.. Have the fault codes read
Mar 25, 2014 | 1998 Ford Laser
My car wont start sometimes i can push start it but it wont jump start is that clutch pedal lock switch?
sounds like clutch switch, Check under dash follow clutch pedal up and see if there is a switch under dash, should be Purple wires going to it Heavy gauge wires, need to unplug it and put a jumper in from one side to other and cover with tape so it doesen't touch and ground out and blow a fuse, then see if it will start and if it took care of your problem, if so replace switch
Jan 05, 2012 | 1999 Saturn SL
Intermittent starting problem. Turning key does nothing.
Sounds like you could have a faulty switch, but I would check the starter selenoid first. Sometimes when the selenoid goes bad it will behave in the way you describe. If, with your key in the on position, (not on start), you can jump power from the hot wire, (positive), post on your selenoid to the hot wire that goes from the selenoid to the starter and the starter then engages, but doesn't otherwise, it is a selenoid problem. Good Luck! I hope you find this very helpful!
Dec 16, 2009 | 2003 Subaru Legacy
Triumph sprint rs 955i,all correct lights come on during start up proceedure but there is only the click of the relay switch when you press start button and no ignition, started as an intermittant fault...
try charging up the battery, the starter needs around 60 amps to turn over compared to the lights that only need around 5 amps, maybe it just doesnt have enough power to turn it over... hope this helps
Sep 13, 2009 | 2001 Triumph 955i Speed triple
BATTERY GOES DEAD WHEN SITTING OVERNITE HAS AN INTERMITTENT DRAW OF 3.2 AMP
I think that you first need to independently FULLY charge the battery..., then tell me what the charing rate is, how many volts, at say 2000 rpm... Need 13.8 to 14. 5 or so... How many amps can the system charge at?
disconnect the battery over night, is it still fully charged in the morning. one issue with batteries is once they fully discharge, often they never really fully recover...
After these answers, diodes in the alternator are suspect areas...and sometimes act inconsistantly, but essentially failed ones allow path to ground...do not just replace, these need to be read on a scope. or disected and individually tested.... Then a methodical test proceedure should be undertaken connecting one circuit at a time, overnight and see which one is offending..
Mike
Aug 26, 2009 | 1999 Cadillac DeVille
FGF374 - Broiler and Bake does not stay on
The flame sensor has to prove the flame to stay lit. When it fails, the valve closes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore gas range model# 362.72321 Oven will not ignite (sometimes)
Range Oven Temperature Sensor Part Number WB20K0004 Sears PartsDirect
This will be why the oven acts up. The broiler doesn't rely as much on this as the bake part does. Replace this and it should fix your problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jun 14, 2017 | Ovens
Broiler has gas burning problem
clean all the broiler burner ring holes with toothpicks then clean the burner ring with dishwashing soap and, rinse with clear water. wait until dry then: try the broiler again; sometimes the holes the gas comes out of gets plugged with grease and the burner ring/rod makes a whoshing sound when the excess gas pressure builds up and the gas escapes the burner ring all at once then the cycle begins again
Nov 29, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Broiler works intermittantly
It sounds like you have an intermittent disconnection either because of a dirty contact on or in the switch or something loose like a wire or the element contacts, maybe not plugged in all the way--possibly greased and dirty. If you feel comfortable try moving stuff around with the switch on and see if anything makes it change -- otherwise get somebody knowledgeable with a test meter.
Dec 21, 2007 | Amana ACF4265 Electric Kitchen Range
Maytag MGS5775B Gas Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
