Question about Frigidaire GLWS1233A Top Load Washer
No water going iton washer, hoses and screens are clear
    Sergeant:
  • 216 Answers
This is generally caused from a faulty fill valve, this is the valve the hoses connect to on the rear of the washer. These valves work on the electromagnetic principal using a coil and a metal plunge which is pulled upon when the fill valve receives current. no water going iton washer, hoses and screens are - 7300c91.gif
The part is about $45.00 and looks like
8842480.jpgthis. It fairly easy to replace.
Posted on Aug 06, 2010
Cold water comes out as a trickle, hot water comes out fine. how do I get the cold water to come out faster?
It sounds like you may have a clogged screen in your water valve. Turn the water off going to the washer and remove one hose at a time from the back of the washer and look inside the body of the water valve, you should see a small metal screen inside the valve, and they should be clear of any debris. If you see any debris built up on the screen, carefully remove the screen, I usually use a small flat blade screwdriver, and then use a small brush, like an old toothbrush, and scrub it under a stream of water in your sink until it is clear of any debris. Carefully put the screen back in and put your hose back on and then turn your water back on and you should be good to go. If you do not have any debris on the screens, then you could have a bad water valve and that would need to be replaced. Hope this helps!
Sep 22, 2015 | Whirlpool Ultimate Care II LSQ9549L Top...
Model 11026955690. Why does screen indicate LP?
I am not familiar with any error code referencing "LP". Could you be seeing "LF"?
Below are the error codes listed for your washer:
  • "LF" (Long Fill) Inlet hoses are kinked or clogged or water valve screens are not clear. (Solution: Straighten inlet hoses or clear screens of any foreign material.)
  • "LD" (Long Drain) Drain hose is kinked or clogged. (Solution: Straighten or unclog hose.)
  • "FF" (Fill Failure) Problem with water level sensing system. (Solution: Call for service.)
  • "OL" (Open Lid) Lid Is open during drain or spin. (Solution: Close lid.)
  • "PF" (Power Failure) Power to washer went off during cycle. (Solution: Press any pad to clear the display. Restart the washer from the beginning of the cycle.)
Source: Kenmore 11026955690 Manual
Aug 25, 2015 | Kenmore Washing Machines
The cold water line now takes a long time to fill for a rinse. Yes, I checked the hose to its wall outlet.
FYI, Only 3 potential issues would typically cause this problem.... in order of simplicity to correct:
1. Clogged screen in the water connector(s). Remove the cold water line going to the washer - both ends. Inspect and clean the screen(s) and blow through the hose to varify that it is clear.
2. Solenoid that allows water into the washer is failing. Reverse the cold and hot hoses. Does the problem move to the hot side? If so, the problem is the solenoid-replace it.
3. If number 2 does follow the hose transfer, the faucet washer has broken and is blocking the water flow. SHUT off the water supply to the house, open another faucet to relieve the water pressure, replace the washer in the cold water shut off valve at the wall.
Jun 02, 2011 | Kenmore 22622 Top Load Washer
Why does my washer start with a forcful stream and then cut doyn to minimum flow ?
Check for kinked or clogged water supply hoses(s). Be sure to make sure that if there is a screen-like filter in the supply hoses or at the inlet on the wash machine, that it is clear.
Shut the water supply off. Start the washer to fill on warm wash / rinse to relieve the water pressure in the hose. Shut off the washer. Unscrew the hose connection from the washer and direct both hoses into the washer tub (or other container). Turn the water supply on. Both hoses should discharge water evenly and forcefully, then shut the water off. If the flow was uneven, slow or poor - clear obstructions in / or replace the hose(s). Next, inspect the water inlet on the washer. Clear any obstructions, dirt, etc. Reconnect the hoses and try again. If flow is still lacking, there may be obstructions in water lines or valves INSIDE the machine.
I hope this helps - please rate my reply. Thanks.
May 06, 2011 | Craftsman Garden
Cold water tricles in . no normal flow does the washer valve need to be replaced
There are debri screens in many styles of washer fill hoses that can block up. And the end that connects to the back of your machine also has a reachable screen filter up inside the water valve inlet that can also block up.
Disconnect the water fill hose at the machine and check screens ... clean or replace if needed.
The screen are usually attached to the hose washer and will pop out manually with a small screwdriver or knife. Then turn the water valve on with the free end of the hose aimed into your washer tub to make sure you have free water flow from the faucet to the water valve. If all screens are clean and clear but still no water pressure going into the washer after reconnecting your hoses then you can suspect the water valve inlet assembly.
Dec 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Cold water dribbles into the washer. The cold water line is clear with LOTS of pressure. Is there a filter in the washer that needs to be cleared. If so, how?
sometimes on the hose there is a filter, "screen "check the hose at both ends to see.and somtimes the unit at the hose connection has screens on the unit where the hose connects to the unit,look to see if the screens are clogged,if so just remove them this will help your water problem.
Aug 04, 2009 | Kenmore Washing Machines
Slow cold water flow
Hi, Did you clean the screen inside the mixer valve or at the valve end of the hose at the wall (not always applies)? If the screen is clear and there is good pressure to the washer, you will need to change the inlet valve.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 30, 2009 | Kenmore 22422 Top Load Washer
No cold water Whirlpool top load washer AP595033
Your cold water celenoid has gone out. There is no way to just replace the cold itself, So you have to buy the whole water valve. That will fix ya up!
Nov 17, 2008 | Whirlpool GHW9100L Front Load Washer
LG WM2016CW front load washer
Check to make sure that the filters in the water valves are not clogged up.  Go behind the machine, turn off the water supply and disconnect the hoses on the machine side.  Look inside the water valves and check the filter screens to make sure they're clean.  Get a large bucket and open the water valve to clear out the hoses and make sure you have good water flow coming out of the hoses.  If both of those situations are cleared up, your machine should work properly.
Aug 07, 2008 | LG WM-2077C Front Load Washer
No hot water
Replace the valve if you have no hot water at all.
Please Rate This !
Jul 13, 2008 | Frigidaire CWS3600AS Top Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
26 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
