No problem. I just wanted to know how many transmissions/copies our fax has received to justify to the employer the need for a new one.
  • 137 Answers
Should find it in the set up program. If you still have the book that came with it . It would walk you through the program and how to print it out. Good luck
Posted on Aug 14, 2010
How can I get my W2's
contact your employer or the payroll company that writes the checks
Feb 15, 2018 | Heating & Cooling
How do I get my w2's
Transcript or Copy of Form W 2 ' Internal Revenue Service
https://www.irs.gov/faqs/irs-procedures/copies.../transcript-or-copy-of-form-w-2
  1. Cached
Refer to Transcript Types and Ways to Order Them for more information. You can also use Form 4506-T, Request for Transcript of Tax Return. Check the box for Form W-2, specify which tax year(s) you need, and mail or fax the completed form. Allow 5 to 10 days from the IRS received date to receive the transcript.
Missing Your W2 Here is What to Do ' Internal Revenue Service
https://www.irs.gov/newsroom/missing-your-w2-here-is-what-to-do
  1. Cached
If you have not received your W-2, follow these three steps: Contact your employer first. Ask your employer - or former employer - to send your W-2 if it has not already been sent. Contact the IRS. After February 14, you may call the IRS at 800-829-1040 if you have not yet received your W-2. File your return on time.
What can I do if I have not received my W2 from a previous emplo ...
https://ttlc.intuit.com/.../2238273-what-can-i-do-if-i-have-not-received-my-w2-from-a...
  1. Cached
  2. Similar
Feb 15, 2014 - Request or download Form 4506-T. You will receive W-2 transcripts which will have information reported by your employer to the IRS free of charge. Call (800)829-1040 to obtain the form. 3. Request Form 4852 from the IRS or download it and mail it in. How can I get a copy of my W-2? - TurboTax Support 16 Nov 2017 How can I get all my w2 forms from all my employers from more ... 8 Mar 2017 How do I get a new copy of my 2015 W2 from my company. They ... 14 Apr 2016 I haven't filed prior year taxes because I misplaced W2's. Compa ... 17 Jan 2016 More results from ttlc.intuit.com
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
When you print out the activity report and under comment it says TX ECM what does that mean?
Transmission Error Correcting Mode was used. When the sending and receiving fax machines support this protocol, they are able to correct errors in transmission that occur. You can turn it off if it is causing you a problem, but it shouldn't be. It makes the determination about ECM capabilities during the initial synchronization. No positive response from the other and and ECM is not employed during the transmission.
Nov 14, 2010 | Brother IntelliFAX 4100 Laser Fax
Some lines are missing when receiving faxes
Horizontal or vertical? Or do you mean lines of text?
Did you try to copy a document? If the copy is fine, then the fault is on the sending side, or there are severe transmission errors.
If the copy exhibits the same faults as the received faxes, then something is wrong with the printing part of your fax, and solving the problem will depend on the printing technology used (inkjet - clogged heads, need cleaning, or empty ink, needs replacing etc.)
Feb 10, 2010 | Office Equipment & Supplies
It's not sending or receiving faxes, but line is working
May I know what exactly the model that you have?
Initially, first check the settings of the machine if it was set to tel/fax or fax settings. Check if there was an error message appear on the unit or better to print out a copy of the fax transmission status. Fax machine will print out a copy of the transmission if it has a problem or it has a communication error on the line or in the other side whose receiving the a fax.
Kindly update me again here.
micro
Jul 28, 2009 | Canon FAXPHONE L80 Laser
Cant receive a fax
Please use this link :
http://support.lexmark.com/perl/support/support.cgi
Let me know if your able to receive fax again.......
Good luck...
Aug 07, 2008 | Lexmark X5470 All-In-One InkJet Printer
Canon jx200 fax machine
The fax automatically turns off Auto Print and stores faxes in memory when either ink or paper is low. The memory will store up to 30 transmissions or 60 pages maximum, so it is important not to leave this too long if you have heavy transmission volume.
Faxes can be retrieved as follows.
If you want to choose only certain faxes to print:
1. Print a list of documents in memory for reference:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Doc Memory List, and again press Start/Copy.
2. Print a document from memory (using the list printed in #1):
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print Document, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to print, and press Start/Copy. The LCD will then toggle between "1st page only?" and "Yes=(*) No=(#)". Press * to print only the first page, or # to print all pages.
3. Delete selected document(s) from memory:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Doc, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to delete, and press Start/Copy. [Note - if the arrows do not result in another number displaying, there is only one document in memory.] The LCD will show "Yes=(*) No=(#)". Press * to delete the document. Continue to select documents until each document you want to delete has been handled.
If you want to print all unprinted documents in memory:
1. If you want to have a list of documents in memory for reference before performing this procedure, to be sure you have them all, follow step 1 from the above procedure for printing selected documents.]
2. Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print All New RX, and again press Start/Copy.
3. Delete all printed docs from memory:
Immediately after printing all documents, you will have the choice of deleting all documents. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory.
To delete all documents at a later time:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Printed RX, and again press Start/Copy. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory. To finish then, press Stop.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 06, 2008 | Canon FAX-JX200
Totally black transmissions
Copy lamp has blown, light should shine in where original is placed.... it isnt lighting the paper up, so reflection received is black hence black transmit/copy result
It is just a small specilised floro but would probally be more ecomomical to replace machine than to fix it.
Nov 19, 2007 | Brother Personal FAX-190
18 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
