SOURCE: clean unable???
To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
SOURCE: Ik krijg steeds de foutmelding
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and
select your model printer todownload :-
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
I recently posted that I had a print unable 51 error on my Brother MFC5460 CN All in one.I've read many tips and I was willing to try them all before taking it apart. I'm not sure if the solution I used to solve my problem is like someone else's here but I saw a white piece of plastic behind the print carriage that was still attached but stuck out to the left side when the carriage was in the right side of printer. It wasn't unhooked or looked like what I thought the encoder looked like, but I slid it over to the right side of the print carriage. I was able to move the carriage right to left and back to normal position before but moving that piece of plastic solved the printer error. I cleaned the cartridges,inside where the cartridges go into printer as well as the maintanence tips. Thanks to all the people that take time to post tip solutions that worked for them and ideas thought of to try.
