Question about LaCie (301015) 120 GB Hard Drive
My 350gb drive gives me an error message when I try to add something in..."The Finder cannot complete the operation because some data in ".DS_Store'' could not be read or written (Error Code -36)
  • djchrissoul Aug 06, 2010
    I'm using a mac, my cables are fine... I'm unable to add files from either one of my mac's onto this drive...
    The message I am receiving when I try to add something to my 350gb Rugged Drive is
    THE FINDER CANNOT COMPLETE THE OPERATION BECAUSE SOME DATA IN ".DS_STORE" COULD NOT BE READ OR WRITTEN (ERROR CODE- 36)
  • 6,487 Answers
The problem might be due to the use of Firewire, other people have reported problems with other Firewire based devices. So what you can do here first if the drive is connect via firewire check if the drive also has a USB port and try using a USB and check if that will work or better try a different firewire cable because this is a common problem with the cable.
Posted on Aug 06, 2010
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Also remove temp files from computer so your computer speedup and does not give any error.
Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" then restart computer then it fix errors on harddrive. Scan computer updated antivirus it is best antivirus. Download it's free version from below link. Click here Download and install then update it from internet. Then scan computer in boot time avast scanner. Then check. Let me know if you need further assistance. Thanks for using FixYa.
How do i fix error code -36?
The file is corrupted or the sector on the drive cannot be written to.
Feb 04, 2017 | The Computers & Internet
Completed with errors message when creating safety drillll copy
how to recover raw drive data
How to recover "raw" drive data:
When a hard disk drive bracken or loss her partition and if you try open this drive then you got this message "Disk not formatted" .
At the times you should use any "raw" data recover software .
or
use recover "partition damage" software download.
recover everything
Nov 10, 2013 | Maxtor OneTouch 4 Mini 120GB External USB...
Error code 36 TOCA Race Driver 3
Gather your using the Mac, use SMARTReporter as its sounds like it could be your hard drive starting to fail I/O write errors
Oct 12, 2013 | Codemasters Video Game Consoles & Games
My farming simulator 2011 for mac has recenlty stopped enabling me to add it to my computer comes up with this screen saying....... the finder cant complete some data of fs cant be written error 36. is...
Error 36 means that the computer is having trouble connecting to a server.
I think if you make sure the server connection is OK then the program will work again.
Jul 04, 2011 | Computers & Internet
I keep getting error -36 like some of my files are corrupted is there anything I can do?
slyda
If you are getting a corrupted data message you can try to run disk cleanup on the drive to see if this fixes the problem.
How to run Check Disk in Windows 7
If this does not fix the problem then you will need to backup your files off the drive and do a full format. If you still have trouble after formatting the drive this is a sign that the drive is failing.
Issken
http://www.fixya.com/users/issken
Jan 13, 2011 | Western Digital My Book Essential 1TB...
Dell poweredge 2600 server recently display a message " No boot device available Press F1 to reboot or F2 to setup" Please why?
Did you experience a power event? Go to BIOS (F2), and make sure that RAID is Enabled. If RAID got turned off (power event, BIOS reset), then it will give you that message. If RAID is already enabled, then you may need to repair your operating system. If something else happened (drive failures, drives removed, etc.), then the array may be completely gone. Call Data Recovery services if it is critical you retreive the data.
Aug 03, 2010 | Dell PowerEdge 2600 Server
Kenel data in page error
You need to rebuild your operating system from the supplied CDROM that came with your computer. You have the classic BSOD display, Blue Screen Of Death. Its a long job but its worth it in the end to completly repair your operating system and clean up your hard drive.
Jun 13, 2009 | Microsoft Windows XP Professional for PC
My acer aspire 5310 gives blue death screen (Bad pool caller) plus it does not detect the hard drive
If you are getting a blue screen in your Windows operating system that says something about a bad pool caller, you are in for a tough ride. The bad pool caller error means that some piece of software somewhere on your computer has done something wrong. For this reason it is important to write down the error codes that you receive with this message to help in determining what exactly is going on.If you have successfully been able to record these error codes in some way and have access to a computer that is working, the best place to start is on the Microsoft website. Once you get to their website, try entering the error codes that you have written down to see if they can give you more detailed information about the software that is causing the problem and any possible solutions to correct the issue.If you have not been able to find a solution to your bad pool caller error using the above method, then there are a few things that you can try. Often a hardware device can also cause problems that result in the bad pool caller error message, especially USB devices. Start by removing all of your peripherals including printers, scanners, external modems, USB hubs, etc. if you do not receive the error message once you have done this, then add one device back at a time, until you find the source of your problem. If this works and you know what device was causing the issue, you can try reinstalling the software for that device or replacing the USB cable that is connected to that device to see if that will solve the problem. If the problem still persists, it would be a good idea to run MemTest86, which can be downloaded online, to test your RAM for errors. A bad hard drive can also result in bad pool caller messages.If you have recently purchased your computer or have warranty on your computer, perhaps the easiest way to deal with this difficult problem is to take it back to them. Because of the nature of a bad pool caller message, which can be caused by almost anything, it is easier to have them deal with it rather than trying to isolate and correct the issue on your own.If you have built your own computer or are working on an older computer that no longer has a warranty, then you may also be able to get some clues into what is causing the problem by looking through the Windows Event Viewer for error messages or information. If you do not know how to do this, then a quick search online will explain how things are logged in the Event Viewer and how to interpret the information provided.Finally if all else fails and you are sure the problem is not related to a peripheral or other hardware device, then you can reload the Windows operating system on your computer. This can be done without losing your personal data and files, but be sure that you perform a complete backup before attempting this step just in case. There are the odd situations in which a bad pool caller error will occur during the installation of Windows in which case you will need to try and completely reformat your hard drive and start from scratch.
Apr 20, 2009 | Microsoft Windows 2000 Professional for PC
Unable to save Brain Age Data to DS
Likely to be a bad glich.I would sugest to bring
it to the store and get it fixed.
Mar 26, 2009 | Nintendo Brain Age 2: More Training in...
LaCie (301015) 120 GB Hard Drive Logo
160 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
